Question about Frigidaire GLRS264ZA Side by Side Refrigerator
GLRS264ZA freezer moisture
I have water running down the front of my refrig. I have opened the back panels to see the coils (light frost) and I hear a noise like a fan trying to run. The fan is running fine. any ideas?
  • craigmed Jun 03, 2010
    I have taken the back panel off and it look like water is running thru the pan fine. I hear a fan trying to kick on and the coils in the freezer have light frost.
    I believe the water is coming from the ice maker thru the dispenser
  • 1,531 Answers
Be suret o check the water line connection under the front kick panel and make sure it is secured.
there is also a chance that the drain hole in the rear of the compartment is blocke and water is not draining into the drip pan.
Posted on Jun 03, 2010
My fridge works fine but sometimes the freezer will stop working and you can here a sizziling sound coming from the back like water dripping and hitting something hot. I unplug and plug back in and it...
Hello, welcome to FixYa.
This is just the normal operation...specifically the defrost cycle every frost free unit must cycle through every 8-12 hours.
You are correct, the sizzle is water (from the melting ice) dripping onto the defrost heater. It is all normal so no need to worry.
Thank you for choosing FixYa today. Please take a moment to rate your experience here.
Regards,
Macmarkus :)
Aug 15, 2011 | Kitchen Ranges
I have a GE model TFX30PPDACC. It had frost in the freezer on back panel. Changed defrost timer and defrosted the coils. Lasted 10 days before enough frost built back up and refrigerator temp climbed....
thats what it will do when nothing frozen is in the freezer,you should hear the defrost heater popping if theres frost or ice melting off the evaporator coil in the rear area of the freezer its working ok
Jun 12, 2011 | Hotpoint HSS25GFP Side by Side...
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Jan 02, 2011 | GE (PSS26MSRSS) Side by Side Refrigerator
Have a GE side by side gsh22sgress unit. Child left freezer door open. Unit ran for days (in non-occupied appartment). Meat thawed. Cleaned unit inside with mild soapy mix. Unit runs but will not cool...
Open door let too much moisture into refrigerator. (The cooling coils, behind the back wall of the freezer compartment, are blocked with frost) If you unplug the refrig for a day or so it will work again, or you can take the back wall out from inside the freezer and melt the frost with a hair blower.
Aug 21, 2010 | GE GSH22SGRSS Side by Side Refrigerator
Have kenmore refig model 59671103101 refrig temperature to low. light work, fans run freezer works good. Cleaned vents & coils ?
if the freezer is fine, check for air flow to fridge. if you get none, see if there is any frost on the back wall of the freezer. if there is some frost, the coils are iced up and need thawing. if there is no frost, there may be an obstruction in the vent. also may be thermostat in fridge- it opens and closes the vent from the freezer.
Nov 13, 2009 | Kenmore Refrigerators
Side by side refridge was dirty and I cleaned
I would pull the refrig out , and remove the back panel , covering the compressor and fan motor . Check to see if the fan is working . Fan not working , causes the divider panel , to get very hot . Also , fan not working , causes the compressor to over heat and cut off on the overload .
Sep 29, 2009 | GE Refrigerators
GE side by side. Freezer cold, fridge kinda cool
Generaly the control board controls everything sometimes you have a bad thermister GE has a help line I beleive it costs 20.00 bucks but you will need a meter and know how to use it and they willl talk you thru the repair .
May 30, 2009 | Refrigerators
Fridge on top of freezer is not chilling
if you have a french door (also known as bottom mount, freezer on bottom) and your fridge sections(cold air blows from freezer to refrig) is not cooling try this
1. ensure you hear the fan running, its it not, thats it(most likely fan motor
IF fan is running check these things
1. ensure refrig section light shuts off by holding down the switch
2. ensure door shuts
3. clean conderser coils (usually accessed from front through base grille)
4. check for icing in vents, freezer section contain them at top or back, and for a bottom mount the refrig sections vents are under your BIG drawer. if iced try a hair dryer from distance. or empty food into another fridge unplug open doors, and plug back in two days later this should defrost all ice build up
May 02, 2008 | Refrigerators
New Refrigerator Past Warantee Not staying cold
is the fan in the freezer running? if not then the air cant circulate and nothing will cool properly. if is running, is there frost build up on the inside back wall of the freezer? if so you have a defrost problem. if no frost on the back and the fan is running, remove the back panel inside the freezer and make sure all of the silver coils have light frost on them. if only part of them are frosted get out your manual and look at the warranty section. then seal system may have a 5 year warranty. if it does then call sear for warranty service. if the coils only have partial frost and its not under a 5 year warranty buy a new frig. because repair will cost more than its worth
Nov 26, 2007 | Refrigerators
Amana French Door Refrigerator "on" but no cooling; freezer still works
There are 2 possible problems. One is the defrost cycle is not working properly this is usually indicated by a large amount of frost on the back freezer panel. If so, the circuit will have to be repaired and the evaperator thawed to remove the ice build up. The other is the fresh food damper is not working properly this is behind the "lump" in the back of the fridge compartment above the top shelf, remove the louver panel to see if it is open or closed. closed will be warm open should be cold. The water dispenser reservoir is probably frozen due to poor air circulation.
Mar 06, 2007 | Amana AFD2535DES French Door Refrigerator
Frigidaire GLRS264ZA Side by Side Refrigerator Logo
116 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
