Question about IBM NetVista PC Desktop
Alarm goes off when it starts up
MY IBM Netvisa Model 8307 tower computer SOUNDS AN ALARM SOMETIMES WHEN I START IT UP SOUNDS LIKE A SMOKE DETECTOR THEN I SHUT IT OFF UNLESS I WAIT ABOUT 30 MINUTES OR SO IT WILL KEEP ON WITH THE ALARM BUT I DID NOTE THAT EVEN WHEN THE ALARM IS SOUNDING IT DOES BOOT UP TO WINDOWS XP SO I'M THINKING THAT IF I KNEW WHERE AND HOW TO FIND THE ALARM PERHAPS I COULD JUST TURN IT OFF...PLEASE ADVISE IF POSSIBLE HOW AND WHERE I FIND THE ALARM ON /OFF BUTTON AND HOW DO I GET THERE
AND PLEASE DON'T SAY ...BY CAB...
THANKS IN ADVANCE FOR YOUR HELP....RALPH
ralphnadolny@sbcglobal.net
    Novelist:
  • 155 Answers
The alarm is a BIOS alarm. It is warning you of either a cooling fan failure or the processor getting too hot. Either way, you need to fix the problem, not just ignore it!
I would check that all the fans are running correctly and would also recommend that you give the insides of your computer case a clean out - you'll be amazed at how much dust can build up in there! This may well cure the problem.
If it is a processor temperature alarm, rather than turning it off, you may want to adjust it so it doesn't sound until a higher temp. is reached. You can adjust this from the BIOS screen, but I would check the maximum temp. that your processor is designed to run at before doing so.
To get to the BIOS screen to turn it off, press the delete key (repeatedly) while the machine is booting.
I can't tell you exactly when to find it in the BIOS, as this can vary from one computer to the next. Just navigate you way around until you find the relevant section.
**** WARNING ****
Changing settings in the BIOS can affect the computers performance, prevent it from starting, or even cause permanent damage to hardware. Unless you know exactly what you're doing, I wouldn't recommend changing things!
Hope this helps,
Matt
Posted on Apr 09, 2008
Why does my smoke alarms not all go off when I push test button?
I am assuming that your detectors are interconnected to all sound at the same time.
Pushing the test button is not the same electrically as an alarm activation.
The Kiddie manual does not mention the sequence of operations when the test button is pressed. You may want to contact Kiddie to find out if this is ok.
You can also test your detector with smoke to see if they all sound like they are supposed to.
Feb 08, 2016 | Kidde i12040 Hardwire Smoke Alarm with...
New smoke detector, new batteries, red light flashing is that normal
copied from the manual, available at the kidde website
RED AND GREEN LED INDICATORS This smoke alarm features separate red and green LED indicators. The LEDs indicate the following: GREEN LED CONSTANT ON - AC power is present. OFF - AC power is not present. RED LED - Can be seen through the Push-to-Test button. Blinks once a minute - Indicating presence of a working battery. Blinks once a second - Smoke alarm senses smoke and simultaneously sounds an audible alarm. Blinks once every 10 seconds - Smoke alarm is quieting an unwanted alarm (Model ADC only). (Interconnected system only): OFF - Another smoke alarm in the network has sensed smoke and is signalling this alarm.
Nov 14, 2015 | Kidde 4618 Firex Hardwire Ionization Smoke...
Had customer with CO detector sounding quick double chirp about every five minutes. What is this?
This is not a beeping smoke detector. It is probably a CO detector that was installed by your alarm company. GE model 240-COE will give a double beep every 5.5 minutes when the device reaches end of life. Call your alarm company to have it replaced.
Jun 07, 2014 | Kidde DC Voice-Alert CO and Smoke Alarm
My smoke/carbon monoxide detector keeps saying "low battery". I have replaced the batteries in all (5) detectors. They are hardwired. The one downstairs goes off continually and now the one...
My Smotec 3786A indicates not to install it in above 85% humidity.
One of my three seems to go off annually or so and this is what
recently put it down to. I was making an espresso coffee on the
stove and it generates a lot of steam and off goes the fire alarm.
I did change the battery to no avail.
Mar 28, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
The alarms are hardwired together with battery back up. At random times they will sound with no obvious reason. Sometimes a couple times a day then may not sound again for a week.
They simply may need cleaning, due to a dust, lint or spider buildup in the sensors. You can accomplish this by using canned compressed air (like you clean your computer with) Attach the straw nozzle to the canned air, remove the detector cover(s) and with short bursts of air, clean the interior of the detector. When that's completed, blow out the detector cover. Before, your replace the cover, you should change the backup battery(s) in all the units, if it's been a year, since you last did it
Doing the above should solve your alarming problem..
Feb 18, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
Kiddei12040 goes off maybe once or twice a day. it goes sometimes for 10 min at a time. It is hardwired and its not a chirpping sound either. house was built 3 months ago.
It may simply need cleaning, because there's dust or lint in the sensor.
What you'll need: A ladder to reach the smoke detector and a can of compressed air that has a straw nozzle (like you clean your computer with).
Carefully remove the cover of the smoke detector. Use the canned compressed air with the straw nozzle to blow out the interior of the detector. Be sure to hold the canned air as upright as possible while using it. Once you've cleaned the interior, clean the outer cover. Replace the cover and push the test button. Then detector may false at first, because the canned compressed air is cold. However, once the detector reaches room temperature it should stop.
That should help solve your alarming problem. Smoke detectors should be clean like this, at least once a year. More if it's a dusty environment.
Feb 17, 2011 | Kidde i12040 Hardwire Smoke Alarm with...
Kiddie fire alarm model I12060, beeps once every
This happened to me, my smoke detector started chipping so I changed the batteries. A few seconds later it started chirping again. The answer is in the way you put the batteries in. The smoke detector allows you to put the batteries in wrong and makes a slight connector. This slight connector tricks the detector into thinking the batteries are weak. Simply turn the batteries around so the fat connector of the battery touches the skinny connector of the device. Mine was, fat side on the right.
Jan 28, 2010 | Kidde i12040 Hardwire Smoke Alarm with...
My first alert smoke detector went off at midnight last night. It is doing the three beeps, pausing and then another three beeps. This happened for about 3 minutes, stopped and then started again...
Change brand new battery,every three months.Take some rubbing achahol clean the test button metal contact inside the detector.Well works correctly after these steps.
Dec 15, 2009 | First Alert SA302 Dual System Smoke...
IBM NetVista PC Desktop Logo
472 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
