Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Cant connect tap to water outlets - Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
    Genius:
  • 1,416 Answers
Posted on Jun 10, 2010
  • Oloyede Monsuru Jun 10, 2010
    hello,
    'am very sorry my first respond to your question
    what you have to do to get to give you an helping hard to be able to
    connect our tap to the position you wish to be get the same size
    of tap of the pipe you want to connect to the out let you will have to
    know the size (serial number )of the pipe in order to be able to get
    the best from the store.
    thank you and thanks for using fixay.
Bypassing softener when watering the lawn. Uses too much salt..can we turn off the water softener when we are watering the lawn and how do we do this.
leave the setting on the water softener alone as it will become a tiresome exercise
place a "t" joiner in the water line before the softener with a tap on the outlet side to the softener and a tap on the outlet side to the lawn hose and fix your lawn hose to that
That way when you want to water the lawn adjust the taps so that the water softener is cut off and the hose is turned on
or when using the softener the tap is turned on and the hose is turned off
use ball valves ( 90 degree action)with a handle and the direction of the handle will determine the direction of water flow
Jun 19, 2016 | Dishwashers
Rheem Model GT-199DVP-1, just installed but will not start up. There is power to the Thermostat. Water and propane are connected. No water runs through the system.
Water doesn't run when you turn on water tap?
Check inlet to see if joint compound or sediment flakes are clogging the water filter.
Check shut off valve to make sure water is ON.
Also check electric outlet with circuit analyzer, and confirm correct polarity and that unit is grounded. Unplug unit and test for continuity between ground plug and gas valve.
Make sure outlet is dedicated and not connected to other appliances and fluorescent lights etc.
Make sure unit is rated for propane. Check gas pressure and flow against rating of water heating unit.
Oct 04, 2011 | Water Heaters
The hot water tap in the kitchen broke. We turned the hot water off coming out of the tank. The stop **** has been reopened. The tap has been repaired but we cant get any water through
There may be some debris in the tap, left over from the old one. Turn the water OFF again, remove the new tap and look for any debris that may be clogging the outlet. Also. make sure the new tap is seated properly and is identical to the old one you had to remove.
Hope this helped to solve your problem, Eddie. Please be kind enough to rate my response. Thanks!
Mar 28, 2011 | Heating & Cooling
The quick connect hose does not fit into any of the taps - do i need an additional adapter, where can I get this? no one seems to have a problem connecting to the water tap - why me>? Alos can it...
these washers only connect to some standard taps, for others you will need an adapter. another thing is the hoses are generally short but you can definitely connect to your laundry taps if the hose is long enough.
Dec 24, 2010 | Danby DTT420 Top Load Washer
What is the proper sequence for lighting the pilot on a whirlpool electric light water heater?
There is not pilot flame on electric water heater! It is electric! You just connect it to the proper inlet (cold water main) and outlet (hot water to tap), then connect it to electrical outlet, switch it on and that is all. it should run automaticaly when you open the tap.
Aug 13, 2010 | Water Heaters
Hi! My hot water taps from the wash hand basin and mixer bath has low pressure. I`ve got a combi boiler in the first floor. Can I install a single impeller pump connected from the hot water outlet from the...
In a word no. Combi boilers work on balanced pressure.ie the mains cold supply to the boiler should be around 1 bar minimum which would give a hot water pressure of the same 1 bar. Assuming the cold water pressure is fine, it sounds like you have a restricted flow on the hot side. If you live in an area with water problems the hot water systems pipework calcify over time effectively reducing water flow. Unless any flexi hoses are kinked, check if there are any filters in the appliances that may be blocked.Also check all valves are fully open and if possible check if there are any restrictions at the valves. Failing all that and the taps are in good order it is possible to fit a pump before the boiler but this may only be a temporary fix overall.
Apr 04, 2010 | Plumbing
Bought a Hoselock Hose Reel today and cant figure
You need to purchase a Hoselock tap connector. There are two basic types, one has a thread that screws on to a theaded tap and the other type is a compession fitting that can be secured to most other taps.
The full range of connectors can be found on their website
http://www.hozelock.com/watering/hose-fittings/connect-to-tap.html
Mar 16, 2010 | Hozelock Garden
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
