My computer boots up very slowly. What can I do to get it working faster?
    Genius:
  • 1,354 Answers
There are a number of steps that you can take to attempt to speed up your system. Most require simply tweaking the software you already have, not adding more.
However, if the information you've provided is accurate, the problem with your system is much more fundamental.
I just checked a Window XP with SP2 box, and Microsoft calls out a minimum RAM requirement of 128Meg. Not only are you below that, but I consider Microsoft's requirement totally impractical if you actually want to do anything with your machine. I would recommend a minimum of 256Meg of RAM, and ideally more. In machines that I've recently purchased, I've configured them with 1 or 2 Gigabytes of RAM.
Windows XP loves RAM. If you have 256Meg of RAM or less, that would be the first place I'd turn to in order to increase your system's effective speed.
"Windows XP loves RAM." The next place I'd look is at all the software that loads and runs automatically when you start your machine. If you've never adjusted it, and you've simply accepted default installations for software you've installed, it's likely there's a lot of software actually running that doesn't need to be. Unfortunately identifying what is, and is not, required can be a difficult process, since it depends on how you specifically use your computer.
My previous article What's all this stuff running after I boot Windows? will help you at least identify what gets launched automatically when you log in. The article What's this program running on my machine? includes some of the steps I go through when I try to understand exactly what a program is, or what it's trying to do. (In short ... Google is your friend.)
Windows Services is another area to examine, but unfortunately things get even more obscure. There are lists of services that you can review and determine for yourself if they are appropriate for your machine.
Other things you could also try to increase your system's performance include:
  • Defragment your hard disk(s).
  • Clear your Internet Explorer cache.
  • Consider using a lower resolution, or a lower color depth for your monitor.
  • Consider using a plain color instead of a picture for your desktop - the picture takes up memory that could be used for other things. (This is also extra important if you connect to your machine via Remote Desktop.)
There are, naturally, many, many other tweaks of various and dubious value out on the internet, but these are the ones that I focus on as getting the most bang for the effort. I expect readers will add some of their favorite tweaks to the comments on this article, so be sure and read any of those that are present.
Posted on Jun 03, 2010
  • 1 more comment
  • ttherese Jun 06, 2010
    how can I find out how much RAM I have?
    I want to try the tune-up America - I thought I downloaded it but now how do I get it to work?
  • HI
    open your CPU on motherboard will will find your RAM
    Start your computer and locate the My Computer icon.
  • Step 2
    Right-click the My Computer icon, and select Properties from the menu that appears.
  • Step 3
    Look under the General tab where it gives you information about the size of the hard drive and what operating system you use to find the amount of RAM in megabytes (MB) or Gigabytes (GB).
Booting of my pc is very slow. Programs are also opening slowly. how to make booting fast .
Hi.
I recommend using a tune up program like Tuneup utilities... with that program you can Choose the programs to run when windows starts. That software also allows you to run a scan to boost up all your pc.
YOu might also try Ccleaner a FRee program to clean all the trash in your computer and make it faster.
Good luck....
Aug 26, 2011 | Microsoft Windows XP Professional for PC
My computer is too slow - how do I make it faster?
Slow Start Up
There can be a variety of reasons to Windows loading slow during start up. Go to Run, type msconfig and hit enter. Under the 'Start Up' tab, uncheck the unwanted programs and press OK. Things should be a bit fine the next time Windows boots.
Another program worth mentioning here is StartUp Delayer which will help in setting after how much time programs should be loaded after Windows boots. For instance, you could set your instant messenger program to load 50 seconds after Windows starts up.
Slow Loading Start Menu
If the Start Menu items are loading slowly, you can open the Registry Editor by typing in the Run menu 'regedit.exe' and pressing Enter. Go to HKEY_CURRENT_USERControl PanelDesktop. Look for MenuShowDelay, and double click to edit the value. The lower the number specified, the faster the Start Menu will load.
Slow Right Click Context Menu
Probably the Windows Right Click menu on your computer is loading slow because too many programs added unwanted entries there. Just download this program called Mmm, install it and then modify your context menu to remove unwanted items to speed it up.
win-fixes-send-to.jpg Slow Send To Menu
If the Send To menu loads slowly, you can type 'sendto' in the Run Dialog, and remove unwanted items in the Explorer Window that appears. This should add some speed to it.
Slow Defragmentation
The Windows Defragmenter can't get any slower. You need to have an alternative to the Windows Defragmenter, and Defraggler is just one of the best ones available in the market. It's free, and works like a charm and can speed up defragmentation manifold. For some alternatives, see Five Free Programs to Defragment your PC.
Aug 11, 2011 | Computers & Internet
Working slowly
download CCleaner. It will delete stuff you dont need, this should help clean things up and speed up your system. At the same time you should uninstall unwanted applications and delete files you dont need.
Mar 01, 2011 | Computers & Internet
After installing new video card it takes a long
Without more info it's hard to say for sure but here's a few suggestions.
Turn your power completely off, unplug your computer, double check all your connections, memory, cards, cables, the works. Any loose connections can cause multiple rechecks.
Check your BIOS for quick memory test and set it to "yes" or "enable".
Look to see if you can skip some of the memory tests, if so, skip them, you don't need them unless your having problems.
Set your boot sequence to check only the drives you normally boot from. If you usually only boot from your hard drive set it to only check your hard drive, you can change it latter if you need to boot from a different drive, this is faster and more secure.
Turn off "floppy seek at boot" unless you use a floppy drive.
Turn off your serial ports if you don't use them.
If your computer has unused IDE controllers you can turn them off too.
Be sure to make notes of everything you turn off, it can be a real pain to trouble shoot a problem for something you turned off and forgot about.
May 24, 2010 | Biostar P4M900-M4 Motherboard
I am trying to reinstall my visioneer 4800 old scanner on my XP. I am told it doesn't find Twain and I do not know how to instll it safely. I think it was uninstalled at a time when the computer was...
Before you install try this.
1. Start -> Click Run
2. Enter msconfig and click ok
3. Click Startup tab
4. Uncheck program that you don't want to startup
You can disable programs that you don't want automatically load when you start your computer. By disabling these programs will help your computer startup faster.
5. Click Ok and restart
Now you should notice that your computer startup faster.
My Hot Tips to Make Your Computer Faster:
* Regularly check your startup folder to prevent malicious programs installed itself without your knowledge.
* Delete the temporary files from Temp folder (Start > Run > %temp% > delete all files).
* Upgrade your RAM to makes your computer boot faster : )
I hope this helps you to make your computer faster..
Sep 16, 2009 | Visioneer 4800 Flatbed Scanner
Optiplex gx280 won't boot and cpu fan goes faster
Sounds like a bad motherboard, I try resetting the bios , removing everything but the video , could be a bad power supply too (if you have one jump the wires in there as a test). you can buy those dell MBs cheap on fleabay.
Eric
Jul 30, 2009 | Dell Computers & Internet
Xp booting screen slowly get appear
maybe your computer might at risk such as your computer might have a virus or worm...
Mar 22, 2009 | Microsoft Windows XP Professional
How win xp boot faster
Dear
If u dont wanna to exceed ur RAM...
1. click start-run than type "msconfig"
2. go to startup tab uncheck all than ok
3. Pc will reboot now
4. uninstall  unuseable  programm
its working
Oct 18, 2008 | Computers & Internet
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
