Question about Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel
Brought a new Monda vega spray sink mixer for the kitchen. Not sure how to connect the mixer hose to get both hot and cold water flow. No pictured instructions were provided which makes it hard
    Genius:
  • 1,354 Answers
Hi
find you spray fixing digrame from folowing link
http://www.grohecatalog.com/product/32999/
Posted on Jun 03, 2010
No hot water pressure in kitchen, low cold pressure
sounds like a bad faucet//only if you had good pressure before it was installed..to cheaply test..take the hot water off from the shutoff valve and spray it into a milk jug to see if theres good flow..then replace the faucet assmbly..dont forget to turn off the shutoff valve first..or you will get a watery surprise!
Jan 08, 2014 | Home
I have a whirlpool washer model #LSQ9549LWO i have very little "cold water" flow but i have great "warm and hot " water flow . What could be causing this ? thank you for any and all...
remove the cold water hose to check the cold water faucet and make sure you have good flow there,, if you have good flow then the problem is the hot/cold water mixer -- this is the plastic mixer that is conected to the washer and both hoses connect to it,, it is held in place by one screw and has two sets of wires going to it. remove the hoses and then remove the rear panel, remove the screw and disconect the wires ( lable to remember what wires go to hot and to cold ) -- you should be able to take this mixer valve to your main hardware store and buy new -- and if they don't have it then go to your local appliance/repair shop and they should have plenty in stock, ( these mixers go out quite often do to internal corrosion ).
c...
Dec 31, 2010 | Whirlpool Washing Machines
Is there any reason why the hot and cold can't be changed over in a mixer tap? Our model is a Monda. The instructions are to connect hot and cold to specific sides of the tap, but this doesn't suit our...
The only way is to get a new faucet. This one was designed for separate hook ups. Any plumbing supply house can get you what you want. Its an easy install, but will have to be a new unit.
Dec 25, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Brought a new monda vege spray sink mixer for kitchen.Not sure how to connect the mixer hoses together.No picture instruction were provided which makes it hard to install.
it does, hot connection goes one side and cold connection goes on other. If you get it wrong then just swap em. It intalls better then you one you took off. I believe it just requires 1 nut to go on bult.I replaced mine in 3 minutes.
Oct 06, 2010 | Grohe 32 999 KD0 Alira Pull-Out Spray...
Installed brand new marielle kitchen faucet with matching srpay and soap... sprayer is not working. please help
If you used the teflon tape to seal the threads on the sprayer connection. Make sure the tape is has not blocked the line.
Check for any kinks in the hose and it is not pinned against something.
Turn on the cold water and hold the sprayer over the sink and activate.
If nothing happens while still holding the sprayer move from cold water to hot. If still no water there maybe something in the line preventing the sprayer from receiving water.
Highly doubt there is anything mechanically wrong but it has happened before. See if you can swap it for a new one.
Oct 06, 2009 | Price Pfister Marielle Kitchen Faucet with...
How to fit POLO PULLOUT SPRAY KITCHEN SINK MIXER TAP 0119 **NDD**
hi i need to fix a pull out sink mixer...but i have no idea how to fix.pls help.thanks
Oct 05, 2009 | Food Mixers
I have very little water press on the hot water side
Dis-assemble the faucet to get to the valve. The handle comes off and you access the valve from the top, usually by removing a screw on ring.
You will robably find contamination in the hot side of the valve.
You can find instructions on the Moen website.
Sep 09, 2009 | Moen 7310 Legend Single-Handle Kitchen...
I have poor water pressure from the faucet, hot and cold, in a single handle faucet
could be a number of things.
most mixer taps have flexible braided inlet hose's make shure there not kinked.
also there may be built pressure reducing valves,usually removerable,a plumbers job really.
is there servive valves on hot and cold if so make shure there fully on.good luck ,any qs ask
Aug 09, 2009 | Kohler K-15160-7 Coralais single-control...
Low flow from Kohler K15160 spray kitchen sink faucet. If I take off the spray handle I can fill a jug through the hose alone (including the filter screen) in 15 seconds while with handle on the same...
Are you sure the spray handle is allowing the valve to open enough to allow enough water through? The problem it seems like is physical or mechanical. I am assuming you get good water flow through the faucet itself.
Mar 01, 2009 | Kohler Coralais Black Single-Control...
Grohe 32 999 KD0 Alira Pull-Out Spray Kitchen Sink Faucet, Stainless Steel Logo
763 people viewed this question
Top Grohe Home Experts
Mike
Donni Steen
Are you a Grohe Home Expert? Answer questions, earn points and help others
