Question about Makita 6337DWDE Cordless Drill
Drill runs but chuck freewheels - Makita 6337DWDE Cordless Drill
  • Mr. Wizard Sep 05, 2016
    Ha! For me, it took a while with no answer here, until this one maybe. After exhaustive reasearch, and as I was attempting to remove the chuck, I noticed something obviously wrong, but not so obvious that I could see it upon discovery of the problem. The confusion was due to the drill having worked perfectly when i last used it and then didn't when i grabbed it again days later. You see, when i put the drill in the case, i must have bumped the switch that regulates the speed because it was in the position between the two speeds, this the chuck was disengaged. This is not something i am proud of, but I thought someone else might have the same problem in the next 5 to 10 years, so there ya go.
    BTW, I advise against ever siphoning gasoline with a vacuum cleaner, but that's a different story. :)
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
Back chuck.needs to be replaced or maybe update and get a newer drill with more battery power and torque. they get better every year to where you almost need to replace them every 18 months or so to stay current.
Posted on Jun 03, 2010
Where can i find a 5/8 in. chuck for a Pit Bull CH-16NF Drill press
Take it to a local engineering sales shop. They are all basically the same and fit into the shaft with a morse taper. You just need the correct taper.
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto
    • 4.5/5
    • 2 REVIEWS
    Email Signup. Never miss a sale and receive special online only offers.
  • King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for ... King Canada KDC-58M Chuck, Drill Press, 5/8" JT6 for Milling At East Coast Power Tools
  • 5/8 in. Keyed Drill Press Chuck ' Princess Auto Help others make a decision about this product by sharing your experience.
  • Related searches for 5/8 in. chuck for a Drill press
  • Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 - This item: Woodstock D3455 Drill Chuck, 5/8-Inch by JT33 CDN$ 47.71. In Stock. Ships from and sold by FREE Shipping. ... (Canadian Tire) Drill Press.
  • 5/8 Drill Chuck ' eBay 2q== Suitable for drill presses or lathes spindle accepts R8 shank. Chuck key and R8-JT33 arbor are also included in the package. Special quenching treated ...
  • 5/8" Drill Press Chuck [MAG-DPC58] - $29.99 : KMS Tools ... KMS Tools & Equipment from Vancouver BC 5/8 ... Home > Metalworking > Lathes and Milling Machines > Chucks and Taper Adapters > 5/8" Drill Press Chuck 5 /8 ...
  • 1 32 5 8 Heavy Duty Drill Chuck with Chuck Key and R8 Arbor Amazon com
    Jun 05, 2016 | Drills
    My lithium 20 volt drill is not working. the chuck is will not open and close. you cannot move the front and back sections independently so you cannot tighten a drill bit. How can I loosen the two...
    Hold the chuck and run the drill either forward or in reverse until the chuck is fully closed or open then reverse it while holding chuck.
    Jan 06, 2015 | Drills
    Chuck will not turn
    Make sure the torque selector which is the black ring with numbers and a drill symbol on it behind the chuck is rotated to the drill image for drilling and general purpose use.
    Feb 11, 2012 | Dewalt 18 Volt Compact Drill Kit
    How do I take a bit out?
    It is a keyless chuck. Put the drill in reverse (chuck should spin to the left when viewed from the back) and hold the main body area of the chuck with your hand while slowly running the drill. The chuck will open (unless it is broke) and release the bit. You do the opposite (slowing running the drill in forward) for tightening a bit in the chuck.
    Jul 16, 2011 | Dewalt 18v Battery Hammer Drill Dcd950...
    How do you put the drill bits on this drill?
    Grab hold of the sides of the check and run it in revers to open the chuck and then place the drill bit in the chuck and run it forward while holding the side of the chuck to tighten it on the bit...
    Jul 15, 2010 | Dewalt 18 Volt Xrp Heavy Duty Hammer Drill...
    How do you change the different tools on a firestorm black and decker 12v cordless drill.
    I am guessing that you need instructions on how to use the chuck.
    Put the drill in reverse, grab the chuck with one hand and then run the drill for a moment, this will loosen the chuck so you can insert a new bit into the end.
    Be careful to not spin the drill too fast or you may hurt your hand.
    To tighten the chuck you simply put the drill in regular/forward mode and grab the chuck while running the drill.
    Mar 17, 2010 | Garden
    Dewalt Drill DC728. Chuck came out of drill body
    I would clamp chuck in vise and use a chuck key or a Channel Lock Pliers to loosen the chuck.
    Jun 08, 2009 | Dewalt Drills
    How do i get the chuck off a makita cordless drill
    Most hand-held drills have chucks that screw onto the shaft with a right-hand thread. Reversible drills lock the chuck in place with a left-hand threaded screw inside the chuck. To remove this screw, open the jaws of the chuck all the way and use a screwdriver to back out the screw (turning it clockwise, of course, to loosen it). The easiest way to get the chuck off, once the screw is out, is to chuck the short end of a large Allen wrench into the drill, run the drill backwards at low speed, and let the long end of the Allen wrench bang into a concrete floor or a 2x4 or something until you hear a pop and the chuck just screws off. The impacts seem to loosen stuck threads very well. The problem with my drill was that my clutch was damaged and I couldn't get enough of an impact to loosen the threads. I had to get to the clutch before I could get to the chuck.
    Mar 30, 2009 | Drills
    Keyless chuck question
    this 2 chuck are 3/8 jaw opening,double sleeve u can hold the chuck will opening it at the sametime.the sinlge sleeve u have to runs the drill while running slow rev/for to remove the bit etc.
    i prefer metal sleeve.
    Aug 18, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
    Chuck will not release bit
    the Chuck should be 2 Part.
    Use 2 pair of stillsons Or pipe wrenches, Tight On the 2 Chuck Parts, Crack in opposite Directions.
    Alternative, Use Wrench On Chuck Jaw, Short sharp Blow With Hammer.
    Mike @ compurepair.
    Feb 28, 2008 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
    Makita 6337DWDE Cordless Drill Logo
    161 people viewed this question
    Top Makita Drills Experts
    John Trevino
    Are you a Makita Drill Expert? Answer questions, earn points and help others
