Question about Panasonic PV-M2089 Combo
How to get to menu without remote
Im tryin to hook up a dvd player without a remote to the tv and dont have cable or antenna . i cant get past auto programming
    President:
  • 1,099 Answers
you can only get the menu without remote, if the menu button is at the front of the television but if otherwise you can can get a all in 1 remote control for to get the menu of the television .
Thanks for asking...
Posted on Jun 03, 2010
I have an old Panasonic tube tv and no remote. I have tried countless universal remotes and none of them will program to the tv. I used to be able to hook up my playstation1 or dvd player and it would work...
You can't, you only hope is to see if a TV repair store that has been around for long time may have a used remote for your make and model kicking around.
Mar 27, 2012 | Panasonic Televison & Video
I just got a new cable box now im tryin to hook up this dvd player it powers up and i get sound but no picture and i cant fiigure it out
you need to check you yellow composit cable, if its hdmi then the obviuosd woukld be a bad cable or it hooked uowp the wroung way.let me know
Aug 17, 2011 | Cyberhome CH-DVD 300 DVD Player
I'm trying to hook up my Panasonic DVD player (model DVD-S29) to a Comcast cable box but have not been successful. My DVD player only has Audio Out connections, with no audio in connections. I...
the cable in should go to the box and cable out from the box to the TV.These should all be coaxial cables correct?Hook up the DVD player to the TV using the red,white,and yellow cables is also correct.In order to watch a DVD,you have to use the input select button on the remote for the TV ONLY to change inputs.If you have a universal remote for the TV and not the original factory remote provided with the TV,you need to use the menu button located on the outside of the TV.I just searched on my flat screen and was unable to find an input select through the menu button.It may not be possible on this TV if you do not have the original remote and if you own a universal.My universal for one of my older TV's is about 7 years old so I do not know if newer ones have an input select option.If they do not,it is most likely due to patents and royalty payments which these cheap remote makers do not want to pay.Anyhow,let me know if this helps.Just comment here and i will get an auto link to your comments.Good luck! Greg
Sep 19, 2010 | Panasonic DVD-S29 DVD Player
I have an older TV with only an antenna hook-up, a VCR, a DVD recorder and a converter box that I would like to hook all together. I can get the VCR to work, but don't really know how to hook the DVD...
Try this. You will need 2 RF cables and a RCA cable that has a red, black, and yellow plug on each end.
  1. Plug the antenna signal into the converter box.
  2. Connect the RF output (TV out) of the converter box to the RF input on the VCR
  3. Connect the RF output (TV out) on the VCR to the TV
  4. Finally, plug the DVD recorder into the converter box also, but use the 3 RCA cables that came with it (audio left, right and video).
Apr 13, 2010 | iLO DVDR05 DVD Recorder
Can't get dvd player to work on this tv!!!
im guessing that you cant go to av mode because you dont have a remote, am I right? if thats the case you need to go to walmart and buy an RF converter. You can plug you dvd into the converter, then run a coax cable from the converter to your tv coax inout aka anteanna input, then depending on your converter switch your tv to either channel 3 or 4 and presto. it will hook up just like vcr's and onld nintendos use to. You can pick up an RF converter cheap at walmart or check e-bay, couple bucks and your watching dvds.
Jun 23, 2009 | RCA F36649 36" TV
Converter box
3/23/09 --- I don't understand why you would hook your converter box or antenna to your DVD Player. Converter box is only functional between an antenna and a vcr (and/or a TV). DVD Player hooks directly to TV (NOT thru a vcr, coding on dvd discs will screww up the signal and make it fade!) Good luck.
Mar 20, 2009 | Insignia Digital-to-Analog Converter for...
Emerson VCR and new TV don't hook up
hey i sort of hav the same problem except, i cant access the "channel" with my sons game stuff on it
if i click menue then it just givs me "Picture" "Channel Set" "Language" "V-Chip Set-Up" "Captions" and if i click channel set i get "CH{TY}" "CH{CATV}" "CH{DTV/TV}" and v-chip asks me for an access code. and i got this tv from a friend and he lost the remote. i only hav an iO Digital Cable remote. help me plz
Oct 28, 2007 | Emerson EWD7003 DVD Player
Cant access "Antenna" in tv menu to change to cable
It sounds like you haven't selected cable in the "pull-down" menu. You see, you physically have to tell your tv if you're selecting "over-the-air" programs(free), or cable. Select the cable option &
then run "auto-select". Your tv will go through it's steps & find your cable stations. I hope this helps.
Feb 06, 2007 | Mitsubishi WD-52725 52". Rear Projection...
Samsung TXJ2754 (27") DVD issues (Sound but no Picture)
Assuming you have picture on the TV when hooked up to cable, antenna or satellite I would take the DVD player to a friends house to see if it worked on their set (using your cables of course). If you can't get a picture on your TV no matter what, then it could be either the Jungle IC or EEPROM IC inside the set. Since it displays "No Video Signal" on the screen, that leaves out the High Voltage section of the TV. My main suspicion would be the video cable or settings on the DVD or TV.
Jan 02, 2007 | Samsung TXJ2754 27" TV
Panasonic PV-M2089 Combo Logo
1,471 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
