Question about Motorola Mobility RAZR V3
The screen is closed!
When I close the flip, it doesn't seem to recognize it. If I am running an application or a txt, it still appears there as if I never closed it in the first place. When it is closed the clock no longer shows up, just the Cingular orange guy, as if it were still open.
  • Anonymous Apr 11, 2008
    well it is a white sreen you cant see anything on it, well i have tooken the bettery in and out, tried to charge it
  • matty bo Apr 14, 2008
    Since my post, I've read on similar posts about a magnet/flex cable problem. I am not too hastily opening up my phone. I assumed the magnet slipped out of its spot so I banged it around a bit more to try and jar it back into position. Now it works right again. I can't say for how long though.... :)
    Brigadier General:
  • 7,752 Answers
You will need to take the phone and have the lcd screen check.
Guest, the flexcable need to be replaced , take it to a mobile service center and have them replace it for you.
Posted on Apr 13, 2008
My villaware waffle model 2010 has an issue with the little metal piviting latch that allows it to turn the waffle bed. It appears that when the lid is closed, it doesn't touch the metal latch that al
the piece that seems to be not working (although you didnt show it on the video) is the top handle, and I think that if you wrap a bread twist tie around the top handle on the waffle iron side of where you grab handle, the twist tie will hit that little lever underneath when you close the lid, allowing you to spin it
Mar 09, 2013 | Kitchen Appliances - Others
I have a Moterolla V3,my LCD screen is not displaying correctly, I see white and red, but I can't make out anything else. When the phone initially turns on the screen displays the Verizon perfect...then it...
The flex that connects your screen to the phone board is bad and has worn out. It is commom with flip phones. All you need do is to replace the flex and be very mindful of how you close the flip phone.
Take care.
Nov 16, 2009 | Motorola Mobility RAZR V3
I keep having an error come up saying Messaging: Memory full close some applications. I have also had an error saying General: Memory full close some applications. I have no applications open can you...
clear your browser cache as well
set your messages in messaging - options- settings - other to 999 and e memory.
restore factory settings *#7780# default code is 12345 that might just might help you a bit and turn off and on your phone when you do all these things see if it helps any.
“Memory Full…Close some applications and try again” is a normal
message that usually comes on Nokia N70. It showed the memory used in the phone doesn’t have space anymore. But if the message still appears although the user already closed some applications it can be theproblem.
Someone who experience in this memory full problem said, an error message of memory full like above is appears each time he’s opened the
Camera. It also happens for a few times when he’s trying to open
messages, Gallery, or other applications. And then it will force to restart the phone.
Seems like it’s a RAM problem and might there are some applications unable to close completely. If your Nokia N70 phone has gone a start
menu button you can try to hold it down. This way will show you
everything that you have open and they can be closed easily so that
you can continue to take your photos.
So if it can resolve the problem you can reset/format by pressing *#7370#
Oct 30, 2009 | Nokia N97 Cell Phone
Text will not send
Sorry about the prompt on your phone, please follow the the simple steps I'll outline to close the open applications on your phone.
Step 1. Press and hold the "Home Key", you would have the open applications show up on the left corner of your screen. Scroll to 1st application you wish to close, and then ok it. Once you do this you would be in that application that is open.
Step 2. when trying to close the application that you are in right now, select on the options on the bottom left of your screen and ok exit. Once you do this that application is closed.
Step 3. repeat the process on Step 1 & Step 2 until you have just one application running on your e71, which is the "home screen".
Hope this helped, please specify if it did.
kind Regards
Jul 25, 2009 | Nokia E71 Smartphone
My mp600 keeps saying close inner cover-which is closed
I had the same issue, turning off didn't solve it.
There's a plastic flap the width of the print tray just inside that I flipped up and it solved this problem. It is directly in front of the ink tanks. I'm assuming we flipped it down and forgot about it. It seems it needs to stay up, although you wouldn't notice it when it flips down when you close the top, as it closes just fine with it down. It's easy to overlook. This took me a few hours to realize.
The top of the flap has a half circle cut out of it in the middle.
Dec 18, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Android broswer
Seems like their could be potentially a mechanical problem with regards to the screen orientation.
Or your settings could be wrong.
Whilst in the Internet browser you can change from portrait to landscape by pressing the menu key, Touching the "more" tab, and then scrolling down to "flip orientation".
Due to this being a possible hardware problem i would advise contacting T-Mobile Customer support to see if they have a remedy. Although, in the near future, an application will be released for android giving the G1 Auto-Orientation features using the phones built in accelerometer.
Hope this helps
Oct 28, 2008 | HTC G1
Not recognizing DVD player
i would say for some reason your dvd player is not compatible from now on with that brand of blank dvd!
get the firmware update from the brand website all you do is download the file burnit on a cd and put it in the dvd player should fix most and eventual problems
Jan 14, 2008 | Panasonic DMR-EH75VS DVD Recorder/VCR/HDD...
Black screen keeps popping up
If a black box appears on the screen, and a small amount of the picture is visible around the border, it means that your closed captions are on and set to TEXT. Go back into the menu, navigate to the closed captions page and set the captions to OFF.
Sep 02, 2007 | Toshiba 50A50 50" Rear Projection...
Motorola Mobility RAZR V3 Logo
19 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
