Question about Maytag Atlantis MDE7400AY Electric Dryer
The clothes only get half dry when the cycle finishes, i have to put the clothes through a second cycle to dry them. maytag atlantis dryer - it has a sensor - maybe the sensor has gone bad?
  • 166 Answers
The first thing to do would be to check your vent. If the vent is partially blocked or crimped and is not venting properly, this would cause your problem. people sometimes have their dryer pushed to far up next to the wall causing the vent to partially collapse. also check your outside vent to make sure good air flow is coming out there. may also have a lint build up inside the pipe. check for this as well.
Posted on Jun 03, 2010
My maytag atlantis dryer heats up but on any cycle the dryer doesnt run long enough to dry the clothes i have to turn it on two or more times to dry clothes
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Mar 21, 2011 | Maytag Atlantis MDE7400AY Electric Dryer
My dryer will only slightly dry my clothers
make sure you have the required 240 volts to the unit,then check the high-limit and cycling thermostat(s) on the element case and make sure you have good air flow through out the unit,if its plugged with lint air won't flow and it won't dry right
Apr 26, 2010 | Maytag Atlantis MDE7400AY Electric Dryer
Damp clothes at end of spin cycle
Time to check out and clean your filter...........
Mar 01, 2009 | Maytag Atlantis MAV8551 Top Load Washer
Inside of my maytag atlantis electric dryer...top layer is erodin
I WOULD NOT WORRY ABOUT THE FINISH COMING OF EXPOSING ANYTHING TOXIC. WHAT COULD HAPPEN IS THAT WITH TIME, THE DRUM MAY RUST AND TRANSFER IT ONTO THE CLOTHES. DEPENDING ON ITS CONDITION, IT SEEMS NEW ENOUGH TO WARRANT INSTALLING A NEW DRUM. I DONT KNOW IF A COATING OF PORCALINE SPRAY PAINT WOULD STAND UP TO THE CONDITIONS IN THE DRYER BUT IT MAY BE WORTH A SHOT AS I DONT KNOW OFF HAND WHAT A DRUM SELLS FOR.
Jan 23, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
More dry/less dry setting on atlantis dryer
The more dry less dry settings are basically how much heat you want to use. This is the sensor drying. There is a moister sensor in the dryer that senses the moister on the clothing. When it senses no more moister it will shut off and tell you your clothes are done. The trick with this is that you want to make sure you don't mix your heavy clothing with your light stuff. A t-shirt will dry much faster then jeans and it will sense that the shirt is dry and shut off. I put mine on about the second or third line on the more dry setting and my clothes come out fine. If you are mixing your clothing just put it around the third line. It all really depends on what is being dried. If it's heavy set it for more, if it's socks and such set it lower. Let me know if you have any other questions and let me know if this was helpful for you. Good luck.
Jan 22, 2009 | Maytag Atlantis MDE7400AY Electric Dryer
Maytag atlantis dryer model # mde6400ayw
sounds like the timer is not completing the cycle in this mode will the dryer shut off if you manuelly advance timer in that mode
Oct 21, 2008 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Jun 14, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDE7400AY Electric Dryer Logo
120 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
