Question about Hotpoint 24 in. HDA3400G Built-in Dishwasher
My dishwasher is not working and is clogged. What can I do? It does not drain.
  • 1,531 Answers
Use a wet dry shop vac and attach it to the end of the drain hose to remove the water then you need to check the drain pump and make sure that there is nothing stopping it from turning
Posted on Jun 03, 2010
My GE Triton dishwasher won't drain. How do I de-clog it?
Remove the dishwasher drain line from the under sink connection. Direct that end to a bucket and run the drain option on the dishwasher.
1. Does water drains to the bucket. Then your under sink hook up to the dishwasher is clogged. Clean it with a screw driver.
2. No drain water comes to the bucket then
2.1 When on drain do you hear a humming noise. If yes then your drain motor working. That means mostly your dishwasher drain line clogged.
2.2 If humming noise is like a fan (impeller) running then drain line clogged.
2.3 If humming noise is like a small struggling to run. Then something stuck in the drain motor impeller.
Apr 24, 2015 | GE Tritonr XL GSD6260JCC Dishwasher
Dishwasher stops working., all indicator lights go on and display shows OE
Hi
OE in your LG dishwasher is a drain error and dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If it's still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller. Hope this helps... Please post back for any further assistance.
Daniel
Jun 07, 2011 | LG Dishwashers
Water in dishwasher, will not pump out. Noise when machine is turned on
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Daniel
Mar 25, 2011 | Tricity Bendix 24 in. BDW53 Free-standing...
What would cause my dishwasher not to drain?
not sure if you have posted the model number of your dishwasher.
There are several reasons for dishwasher not to drain.
1. faulty drain pump
2. clogged kitchen sink drain
3. drain cycle is not reached due to faulty dishwasher controller
4. clogged drain hose
5. the wash cycle is not completed due to heater not heating water - (try rinse cycle to confirm)
Happy to help if you can provide some details on when the drain cycle is not working. do you get any alarms on dishwasher..etc.
Feb 25, 2011 | GE Nautilus 24" Built-in Dishwasher
My portable GE dishwasher is clogged and wont drain
Hi
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Feb 13, 2011 | GE Profile 24 in. Built-In Dishwasher...
My GSD4020Z07BB dishwasher isn't draining out the water at the end of the cycle. This problem started all of a sudden as the unit was working properly before.
Check the drain located in the bottom of the dishwasher by removing the tray. It may be a clog. If there is no clog you can remove the drain hose from under the sink, get a bucket hold the hose in the bucket and try to drain it into the bucket. If it drains in the bucket the clog is in the sink drain, if not it can be a clog in the hose. If none of that works it could be the pump on the dishwasher. Good luck.
Jan 07, 2011 | GE 24 in. GSD4020Z Built-in Dishwasher
My dishwasher is not draining. I've checked the drain and hose and they are not clogged.
Hi
Daniel
Nov 26, 2010 | Bosch SHX46A07UC Built-in Dishwasher
Dishwasher is not draining
Hi
Oct 20, 2010 | Jenn-Air 24 in. JDB2100AWS Built-in...
GE profile dishwasher (2004) will not drain properly. Is the drain clogged? If so, how do I open and clean it?
check the hose first alot of times the hose canbe clogged . disconnect the hose hit the drain on the machine and normally the clog will be seen. if that doesnt work then its the drain pump thats clogged.
Mar 06, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Dishwasher did not drain all the water
Your sink drain is clogged and the back pressure is not allowing the dishwasher to drain competely. Do not use a liquide drain cleaner, it will damage your disposal. take apart p-trap hopefully the clog is there, otherwise the line will need to be snaked.
Sep 22, 2007 | Roper 24 in. RUD4000M Built-in Dishwasher
Hotpoint 24 in. HDA3400G Built-in Dishwasher Logo
419 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
