Question about Hitachi UltraVision CineForm 55VG825 55" HDTV
How to remove closed captioning on a hitachi ultra
How do i remove closed captioning on a hitachi ultra vision tv?? i have tried going to the menu and the closed captioning option is turned off. any other suggestions??
    Top Expert:
  • Hitachi Master
  • 14,553 Answers
Closed caption can also come from a cable or satellite box if you are using one--either it is from the set or the box----either can cause it.
SD TECH
Posted on Jun 03, 2010
How do i get caption only on mute
On newer Sony TVs you press the CC button to cycle through the available settings for Closed Captions (CC): On, Off, and On when
Muting.
However, it looks like your factory remote control lacks a CC button and your TV menu appears to have a simple Off/On option for what Sony calls Caption Vision. If that is the case then you would need to manually turn on Caption Vision when you mute the television. That hardly seems like the solution you're after.
If you had an aftermarket remote control that could record macros you might be able to program it so that when you press the mute button the TV would mute and also turn on Closed Captioning. This would require the proper remote control and some expertise.
Aug 19, 2014 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
How do you get rid of closed caption?
Depending of what model of TV you have, the option to turn off the Closed Captioning is usually found in the MAIN MENU under the heading of AUDIO OPTIONS.
Look in the AUDIO OPTIONS menu and try to find where it says CAPTION VISION, or CC1, or CC2, or XDS, or TEXT1, or something similar for the display setting, then switch that to OFF.
Otherwise look on your remote control for a button to turn off the Closed Captioning (CC).
It may be a button called DISPLAY, and you just press that repeatedly until DISPLAY OFF appears on the screen.
If you provide the exact MODEL NUMBER for your TV next time in your question, more precise instructions can be provided in order to help you out.
Good luck.
Mar 10, 2011 | Televison & Video
Okay, have Hitachi 1080 HD. Called several times to Customer Service but they couldnt help. Cannot get the words in English to appear on screen for hard of hearing.
Look in the tv menu for SET UP or AUDIO options.
Look for CAPTION VISION and set to CC1.
Now exit the menu screen.
Now use the INFO or DISPLAY button on the remote to activate the closed captioning.
It should say something like CC1 ON once you get it right.
That should be about it.
Note that not every single channel has closed captioning for every single show and that the words usually take a few seconds to show up on the screen when you change to a new channel.
Good luck, hope this helps. Keep us updated on your progress.
Jan 21, 2011 | Hitachi 42PD6600 42 in. HD-Ready Plasma...
HOW DO I REMOVE THE SUBTITLES FROM MY SONY BRAVIA
The Subtitle option is available only with the connected devices like DVD Player, Blu-ray Disc Player etc. The option avaialble in the TV is known as Closed Caption. The Closed caption option can be turned off by selecting the options below:
Press Menu button on the TV Remote. Select, Setup settings. Then select Caption Vision option to OFF. This option is for turning off the Closed Caption option in the TV to OFF. For disabling the Subtitle option in the connected devices like DVD Player and Blu-ray Disc Player, press the SUBTITLE button on the supplied Remote continuously to select OFF.
In few of the TV broadcasting channels the Subtitles cannot be turned OFF as this is being broadcasted with the channels.
Good Luck! KenSolutions
Oct 28, 2010 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
We have a 40" Hitachi ultra vision model # 42HDT52 plasma screen TV. We have never been able to remove the " written words" off the screen used for the deaf. We have comcast if you need to know that. Terri...
Closed Caption has to be in the menu on the set. Go under the Audio section, find CC and turn it off. This will be the same if you are using a Cable box. They also will have a closed caption setting.
Sep 18, 2009 | Hitachi UltraVision 55HDS69 55 in. Plasma...
How do you install closed captions
Press the Display button on the remote several times until Caption Vision appears. See page 16 of this manual for info about Caption Vision: http://www.docs.sony.com/release/KV32S40.pdf
See page 20+ for info about Setup menu and Caption vision menu.
Sep 16, 2009 | Sony KV-32S45 32" TV
Picture with black window
go in menu to closed captions--set is switched to TEXT--switch to off or CC1 if you want closed capton
i do this here for free so if this helps you give me a vote here.
etower.766@netzero.net
Aug 23, 2009 | Televison & Video
Closed caption stays on even though the set up menu states the "caption vision" is off
if you are on a cable or dish box caption is coming from the box, on cable turn TV on, box off press menu, get box service menu, turn caption off pretty simple
Aug 09, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
How to turn off closed captioning without orginal remote?
well if it has a menu option go into menu then set up and change cc okay if does not have menu button try to find universal remote w/ menu option and try to change okay
May 18, 2009 | Insignia NS-RTV32 32" TV
Hitachi UltraVision CineForm 55VG825 55" HDTV Logo
489 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
