Question about Whirlpool Ultimate Care II LSQ9549L Top Load Washer
Haier HLP21E agitation and spin problem
I think I need your help WITH MY Haier HPL21E portable washer.
WASH CYCLE: The tub agitates 3-4x then beeps with the 3 flashing lights [wash; rinse; spin]
The flashing stops and the wash starts again. This time 1 agitation followed by beeps & flash for only a few seconds;
then it starts the wash again.
SPIN CYCLE: The only way I get it to spin for at least 5 seconds is turn the machine OFF; Turn it back ON: select SPIN cycle only; press START and 5 seconds later the spinning stops.
I just heard water sloshing underneath the tub. Is there a way I can check to see if there's a lot of water pooled under the tub?
Could this be the reason for the agitating and spinning problem.
I wish I could afford a repair service, but I'm stuck figuring this out by myself. Any help is greatly appreciated. Thanks in advance.
Ps. There's oly a small load of clothes so its not an overloading probem
  • 15 Answers
SOURCE: Agitator moves slowly on wash cycle/not at all on spin cycle
it sounds like the dogs are worn. try twisting the agitator post by hand,it should move freely in one direction then lock up going the other.its a pretty easy fix if they are.pry off the top of the agitator post off then remove the cap inside,there is a bolt that holds the post down.i'm pretty sure it's 7/16 in. once the bolt is loose,lift the whole agitator out of machine and with your hand inside post turn it upside downand let the dog holder slide out.watch how the dogs fit into the holder, replace with new dogs and reverse the removal process.
if the machine wont spin, check the lid switch. thats usually the cause of a no spin situation.other than that a wet vac is your best bet.hope that helps.
Posted on Nov 30, 2007
jonniewalker
  • 1029 Answers
SOURCE: Whirlpool top Loading washing machine won't spin on spin cycle
If the washer won't finish a spin cycle, it probably means that your timer went bad or stalled. You can take the control panel off and look at the contacts for scorching or corrosion.
Posted on Sep 21, 2008
jgwhomeequip
  • 1902 Answers
SOURCE: Whirlpool LXR9445JQ having trouble with spin cycles.
Check the motor and make sure that the RPMs are high enough, Also check the tension on the belt
Posted on Feb 12, 2009
mastatech
  • 478 Answers
SOURCE: agitator only turns clockwise (Whirlpool top load)
You will need to replace the dogs under the agitator, they are pretty easy. Just pop the cap, take out the center bolt, remove it the dogs are 4 teeth looking items.
Posted on Mar 13, 2009
  • 686 Answers
SOURCE: LSR9434PQ3 Washer stops in cycle
weak capacitor. Bolts onto motor
Posted on Apr 06, 2009
Washer tub does not move to spin or wash
You either have a bad solenoid, timer, loose belt, or water level sensor.
Dec 15, 2013 | Haier HLP21E Top Load Washer
Water is coming in through the entry hose and running straight out the drain hose. No agitate, no spin, just constant water. Happened after I tried to wash three towels & got an imbalance alarm. R
Is the discharge hose higher than the machine? If it is Lower it will never fill. Don't think there is a shut off in the hose to stop the water discharge.
Nov 08, 2013 | Haier HLP21E Top Load Washer
WASHER DOES NOT SWISH DURING WASH CYCLE AND DOES NOT SPIN. IT APPEARS THAT THE ONE BELT IS IN GOOD CONDITION, NOTICED A HOOK BELOW THE BELT THAT HAS NOTHING ATTACHED TO IT BUT I PULLED IT AND IT SEEMED...
It is possible that the BELT IDLER PULLEY WHICH HAS A TENSION SPRING CONNECTED TO THE CHASSIS HAS COME OFF.
So please check if the belt is tight around the agitator pulley and the motor. If not there is spring which could have jumped and so the belt which is free over the motor does not rotate the tub.
So look for a hook or spring on the sides and pull it to give tension to the belt.
Jul 25, 2011 | Haier HLP21E Top Load Washer
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Tub rotates CW during agitation, out of balance, hits side of metal cabinet, but no error code
Hello srcoray,
Did you replace the clutch, just trying to get a feel for your hands on experience with the machine? If you did the work did your machine use the upper roller clutch bearing along with the clutch pulley mounted roller clutch bearing?
The FAV6800AW uses a reversing motor and motor controller that powers the motor and clutch pulley to rotate CW in Wash/Agitate cycle and CCW in Spin Cycle.
In Wash/Agitate cycle the roller clutch bearing should rotate freely CW allowing the agitator shaft to drive the transmission in wash cycle driving the tumblers to rotate only not the wash basket. In spin cycle the roller clutch bearing will lock up (one-way roller clutch bearing) driving the spinner shaft to rotate the wash basket and transmission CCW. Unless my thinking is wrong it sounds like the one way roller clutch bearing is frozen or dragging and not rotating freely in wash cycle rotating the wash basket CW. I’m an owner like you and will try to help.
Just a few other questions;
If you have a load of wet clothes in the wash basket and you select Spin Only cycle will the spin cycle complete with out dc/UC errors?
With the lid raised can you rotate the wash basket CW? It should not; it should only rotate CCW and do that with very little resistance.
Rich
May 22, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Spin cycles doesn't work, tub full of water
HLP21E Haier Portable washing machine will not spin and drain water
Jul 08, 2008 | Haier HLP21E Top Load Washer
Drum spinning during wash cycle
if when in the wash cycle the tub spins then the brake in the cluch assembly is worn and to be replaced. this holds the tub from moving when in the wash cycle. thanks tallpaul
Apr 14, 2008 | GE WBSR3140DW Top Load Washer
Whirlpool Ultimate Care II LSQ9549L Top Load Washer Logo
97 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
