Question about Refrigerators
Broken Ice Machine
Ice machine not making ice, water in freezer
    Genius:
  • 1,073 Answers
Check the fill cup on the back of the ice maker if it is full of ice then thaw it out, if it has ice in the fill cup no water can get into the ice maker cavity
Posted on Apr 10, 2008
I just had a similar proble with a kenmore elite fridge, in that the ice machine stopped making ice. I called the sears repair service and was told that the ice machine needed to be replaced. The diagnostic fee was $99. I googled the ice machine and it was only $99. I should have just replaced it from the getgo. It is VERY easy to install, 2 screws and a plug. The company that sold the ice maker is called Marcone http://www.marcone.com/Default.aspx?M=L
Posted on Aug 08, 2008
Ice machine working but very slowly
I am not sure about the commercial ice, but I would check to make sure the water tube that goes into the maker does not have an air bubble in it. That can cause the water not to come into the freezer to make the ice cubes.
Aug 25, 2012 | Hoshizaki Freezer Commercial Ice Machines...
Hoshizaki km - 280 mah ice maker not making enough ice
A few simple things to check is the condenser for dust. Blow it out. If their is a water filter going into the unit change it. Get some ice machine cleaner and follow directions. Do these things before calling anyone out.
Aug 12, 2012 | Hoshizaki Freezer Commercial Ice Machines...
My ice machine model f-450 mah makes ice but once it's full the water keeps running and runs out of the machine how do I fix this?
Make sure the plug in the water tray is secure and not allowing water to drip out. Check to make sure the float turns off the flow water once up to level.
Mar 01, 2011 | Hoshizaki Freezer Commercial Ice Machines...
I have a model # f-450 mah ice machine. After the bin gets full of ice it stops making the ice but the water continues to run and runs out of the machine. Any ideas on how to stop this?
Sounds like the water valve is stuck. Probably needs replacing. Turn off water after machine shuts down and see if water stops. If it does, water valve is most likely the issue.
KM-500MAH water keeps cycling thru when in ice making mode.
if this is a water cooled machine, the head pressure flow controller need to be replace/adjusted.
Jul 12, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Installed new filter and machine will not make any ice
check the plastic manual water dump valve.MACHINE will not start ref mode until valve is set properly.
Jan 15, 2009 | Hoshizaki Freezer Commercial Ice Machines...
Ice cube shape
hoshizakis make ice cubes depending on the amount of water in the sump. if you are starving for water the sump only partially fills in the fill time allowed . then it makes ice until the water is used up and the float switch drops and the cubes are little slices. you can adjust the size of cubes you want by raising or lowering the float assembley in the sump. if its to low the water rises and the float rises and tells the machine you happy with little slices. if you raise it up to max height you can max fill before float satisfies and max ice cubes. But if you are starving for water the time to fill will run out before the sump fills and cubes will be small no matter where you set the floats assembly. water starving can be due to crud in the water line, to small a water line, most hoshizes take a half inch line ,or a clogged water filter. if you suspect a filter take it out . if fill is drastically improved you need a new filter. be aware that starving for water on a hoshizaki will eventually lead to broken evap plates. big time expensive.good luck. i put in a new machine ruined by starving water and the new one made little chips of ice real quick. i finally pulled the filter out and voila! big cubes and great production.
Oct 28, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Please Heal
starving for water. clean or replace water filter or adjust water float assembly that determines how big cubes are. probably not getting abundant water during timed fill sequence. no water equals little ice.
Sep 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Harvest cycle on ice machines
My ice machine Hoshizaki km-500 mah is cycling to fast. Causing poor production of ice it's real small and it doesn't produce enough ice aswell. Wha seems to be the problem.
Jun 20, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Ice Maker Model F450MAF make less ice.
water valve is leaking. repair valve or replace.
May 22, 2008 | Hoshizaki Freezer Commercial Ice Machines...
Refrigerators Logo
991 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
