Question about ASUS K8V-X SE Motherboard
When i install a fresh os the hard disk is not detected, what should i do?
  • Circe Denyer
    Circe Denyer Jun 03, 2010
    How can you install the OS without seeing the disk?
  • Circe Denyer
    Problem Solver:
  • 13 Answers
In BIOS settings switch SATA controller to IDE mode
Posted on Jun 03, 2010
What do i do when my computer shows the message non system disk or disk error
If your hard disk can detect on BIOS Setup,There is a problem on your hard disk. Whether the installed OS is corrupted or the hard disk itself have bad sectors. Sometimes Master Boot Record (MBR) issue. Try to make fresh install of OS
Feb 23, 2013 | HEWLETT-PACKARD 620 XT964UT Notebook PC
HARD DRIVE NOT EXIST ERROR!!!
If you installed Linux successfully on your hard disk then the hard disk is OK.
If you are installing Windows Xp and it does not detect the hard disk but the BIOS detects the hard disk then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
May 01, 2012 | HP Computers & Internet
How to reformat my MSI notebook?
You need to have an valid Operating System installer CD/DVD. This could be a Windows or Linux installer or whatever Operating System that you prefer.
  1. Turn your laptop on.
  2. Open the CD drive and load the CD Installer.
  3. Reset your laptop to manually reboot it. If you loaded the CD fast, this step is no longer required.
  4. The setup program will then load. Follow the onscreen procedure.
  5. At the point of selecting the hard disk drive, choose "Delete Partitions" to completely remove all data.
  6. After deleting partitions, create new partitions for your hard disk. You can choose to divide your hard disk capacity into 2 or more partitions depending on your requirements.
  7. Format the root partition now (Drive C) to continue the installation.
Mar 03, 2010 | Computers & Internet
I am not able to instal OS in my home PC. Asking me to install scsi drive. my hard disk seagate. where download this flopply disk bios drive software
hi
Checked the Bios Setting and check whether the Hard drive is recognizing or not -
Check the Boot sequence
Check Boot from the CD Drive
Format the Hard drive
it will work
Feb 23, 2010 | Seagate 500GB Maxtor Diamondmax21 SATA2...
Hard drive not installed if os not found re-install hit any key to exit
This usually happens when your BIOS fails to recognise your hard disk or else it is not enabled in BIOS or else there is a loose connection which makes your computer unable to detect the hard disk, You could try and use your BIOS to check if your hard disk is detected. In case it is not, then check the connections of your hard disk or ask your technician to do that
Jun 02, 2009 | IBM ThinkPad T20 2647 Notebook
Hard drive cannot boot in dell inspiron with bios system password
It seems ur OS gets corrupted try to install a fresh OS in ur hard disk...if not worked then u have to replace ur hard disk
Dec 09, 2008 | Computers & Internet
Harddisk not detected
Hi, I think that your os has been crashed. So insert your disk and boot your system and check that your BIOS will boot from CD (Boot preference - CD ROM). And install a fresh copy of your os. Let me know the result.
Nov 29, 2008 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
My computer windows wont start up
go to the BIOS and check whether the hard disk is detecting or not, if detecting then its the problem of your OS , install a fresh os
Nov 24, 2008 | Toshiba Computers & Internet
No operating system found
Good day most often this happen when the hard disk or the DVD/CD rom attached complicate each other.Try this solution remove the cable attached to the hard disk and re insert it (be sure it is in shutdown mode).If you successfully enter the OS try to run checkdisk on your hardisk to check any damages or run diskmgmt.msc to managed your hard disk.To to it go to run->Type " diskmgmt.msc" without a colon then strike enter.
Oct 12, 2008 | HP OmniBook500 250MB Zip Drive Module...
ASUS K8V-X SE Motherboard Logo
80 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
