Question about Cub Cadet Street Sign- tractor lawn riding mower parts
Appears to not be getting fuel.
I have a cub cadet and have had nothing but trouble with it. It has 50 hours on it and while mowing died like it ran out fuel. I filled up the fuel tank and it still wouldn't start. I noticed the fuel filter does not appear to have much fuel in it. It appears to not be pumping any fuel?
  • 177 Answers
Fuel pump gone maybe, running rich
Posted on Jun 07, 2010
3 Suggested Answers
  • 11 Answers
SOURCE: cub cadet zforce
hello
check mower deck is not caked up with grass if it is it will not get enough air movementto force the grass up the chute
also try cutting in 2or3 passes so that you are not forcing too mush grass up the chute
hope this helps
Posted on Mar 15, 2009
  • 246 Answers
SOURCE: cub cadet 1610 rans the battery down went mowing.
Hello bigdave1138:
From your Description it Sounds like the Stator/Charging Coils are Bad or the Voltage Regulator (if Applicable) is Bad.
For Testing the Electrical (Charging) System on Mowers you can Use this Site Addy; http://faqs.custhelp.com/cgi-bin/faqs.cfg/php/enduser/std_adp.php?p_faqid=3438&p_created=1101706364&p_sid=4fQ1f8Xi&p_accessibility=0&p_redirect=&p_lva=3443&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NTEmcF9wcm9kcz0mcF9jYXRzPTAmcF9wdj0mcF9jdj0mcF9wYWdlPTEmcF9zZWFyY2hfdGV4dD1Wb2x0YWdlIGFuZCBTdGF0b3IgQ2hlY2s*&p_li=&p_topview=1 and Use the Link for AC Volts/DC Amps Meter Setting Chart. This is for Briggs Engines and Works Well for Kohler and Other Engine OEMs.
Please, Do Not Hesitate, If you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 12, 2009
2008 cub cadet rzt 50 run for 20 min than dies while mowing put new pump on, new fuel filter, new air cleaner, new plugs. has a 22hp kawasaki engine. fuel lines clear
When it stalls out did you check the spark? I suspect the engine is losing spark due to an ignition system failure.
May 17, 2017 | Cars & Trucks
Wh;y does my cub cadet 1554 tractor mower lose power when engaged?
  • Does deck turn freely? Check and be sure mowing deck is not jammed or bad bearing etc. If nothing is wrong with deck, then check fuel filter, air cleaner element, dirty fuel system, bad gas, water in fuel, restricted fuel flow. Lack of fuel will cause engine to have lack power.
Aug 15, 2014 | Cub Cadet Garden
25 hp kholer engine will not stay running without the choke on
if the fuel is newer than 30 days you need to rebuild the carb if not try fresh fuel first
Aug 11, 2012 | Cub Cadet Garden
Mower will start up cold, i will mow for a half hour then it sputters and dies. After it sits for a while and cools it will start again, but not as easily as the first time. It will again mow for a while...
The valves DO NEED adjusting every 250 to 300 hours of service. That is why it dies out beleive me. It is not that hard to do if you have a service manual to help you along to perform this task
Jul 09, 2011 | Cub Cadet Riding Lawn Garden Tractor 25hp...
We have a 2166 Cub Cadet. After mowing the lawn around 30 minutes or so it starts to hesitate (like it wants to die out) and eventually it does.Can anyone tell me what is causing this problem. Thanks!
Could be couple of things...blockage in fuel filter....tank cap has blocked bleed hole pressurising fuel tank....magneto either coil or condensor on way out
Aug 13, 2010 | Cub Cadet Garden
Cub cadet RZT 42 shuts down after about 30 min of mowing.
Check your magneto. I have had them cease to function whenever they would get hot. When cooled down, they would work.
Jul 23, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet 2165 Mower Shuts Down
did you happen to check the gas cap if the vent is clogged in it ? when it stalls loosen the gas cap and see if it makes a whoosh sound
Aug 31, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cub Cadet Street Sign- tractor lawn riding mower parts Logo
618 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
