Question about Fedders AEQ07FBG Air Conditioner
Where can i buy a master control switch for a fedders wall unit air conditioner, the knob stem is broken.
SOURCE: Window unit air conditioner leaking water inside home
Hi, I had the same problem see http://homefixfree.com/index.html
they were the big help!
Posted on Apr 14, 2008
IrishDruid
  • 2712 Answers
SOURCE: Fedders Air conditioner
Try a hard reset first.Disconnect the machine for about 30 minutes and reconnect after that to see if the issue is resolved.
Posted on Jun 07, 2008
hemantraj
  • 638 Answers
e5 is comp overload code . if you have infared remote for indoor units point at anyone while pushing all 3 buttons at the same time- 'mode' 'temp up' temp down' this will bring up OO where temp set point is normally displayed. scroll up or down with temp up or down buttons (1st digit only) untill you here the beeping sound change tone, this is the 1st part of the fault code. press mode once to change to 2nd digit, scroll again with up and down listening for change of beep- 2nd part of code ie "E5". press mode again will bring up afunny looking T-test mode. press mode again to exit. THATS VERY ACCURATE SOLUTION.SAVE IT FOR FUTURE.WISH U SUCCESS .REPLY FOR FURTHER ASSISTANCE IF REQUIRED.BYE
  • 3422 Answers
SOURCE: my window air conditioner
Can you please tell me which part you need and also the model no. of the AC
Posted on Jun 22, 2008
  • 3422 Answers
SOURCE: air conditioner window unit {Hampton Bay}
You can get the parts from the below sites:
www.searspartsdirect.com
www.partstore.com
If you need anymore help let me know.Please don't forget to rate or accept the previous premium solution.
Fedders air conditioner A2T18F7C master control switch broken
http://www.ebay.com/sch/i.html?_nkw=air+conditioner+parts
http://www.repairclinic.com/Air-Conditioner-Parts
God bless you
May 14, 2012 | Heating & Cooling
I have a vaillant echo plus boiler and a sign comes up sayiny f.75 what does that mean because my water and heating goes off (COLD)WHAT DO I NEED TO DO PLEASE HELP ME
Underneath the unit there are two white knobs with Closed on them. Open the left hand one, then the right hand one, watch as the pressure rises to about halfway up the dark grey area on the gauge. Then close the right then the left knobs.
Press the "-" button next the the radiator control will show the pressure in the system. This should be between 1.0 and 2.0 bar.
Jan 20, 2011 | Fedders AEY08F2FCOM Wall/Window Air...
My Fedders plug in AC will not start. Is there a reset button? The model # is A6X05F2B
Hi, yes right on you plug, if not, make sure there's voltage in receptacle, check your plug for any damages, your fan should be blowing, it seems to me you have no power in receptacle, check house panel for trip breakers, or you will have to go further, by removing front cover, with power off, and check master switch, sometimes master switch goes bad, if you don't want to go further call mechanic.good luck.
Aug 04, 2009 | Fedders AED24E7F Wall/Window Air...
Knob broke off my A/C with the peg inside!
Simple you either replace the knob assembly or use araldite and fix off the broken knob. It is only a temporary remedy and for a permanent solution please replace the knob assembly and get rid off this problem
Jul 14, 2009 | Heating & Cooling
Fedders wall air conditioner
If the compressor only turns on after the units it's shut off then it is a control board problem (stuck relay)
Jun 19, 2009 | Fedders AEY12F7F Wall/Window Air...
I have a thru the wall fedders ac unit. The heat stopped working when you turn it on it just hums.
no blower !!! or heating element is bad or switch try putting the fan on only if it works than it is probaly the switch not letting the blower on only heat
Apr 01, 2009 | Fedders Y Chassis AEY12F7E Air Conditioner
I have an older unit need to know what the top knob does
One of the knobs controls fan speeds, cooling speeds and an off position. Center knob controls temperature and bottom knob more than likely controls air exchange. As for the front cover it would depend on the units age as to if it would be available.
Jul 05, 2008 | Fedders AEQ07FBG Air Conditioner
Fedders AEQ07FBG Air Conditioner Logo
165 people viewed this question
Top Fedders Heating & Cooling Experts
Dan Webster
Dan Webster
Donni Steen
Bill Long
Are you a Fedders Heating and Cooling Expert? Answer questions, earn points and help others
