Question about LG WM-1832C Front Load Washer
Door wil not unlock and will not drain - LG WM-1832C Front Load Washer
  • 1,531 Answers
USe a wet dry shop vac attach it to the end of the drain hose and remove the water,this will allow the door to unlock.
Once all the water is removed then you can check all the hose and connections to the drain pump for any thing that will stop or restrict the flow of water.
If you do not find any blockage you may need to replace the drain pump
Posted on Jun 03, 2010
Key won't unlock driver door
the key or fob?
the key is bad,
use the spare key that came with all new cars.
always keep a spare. or get stranded.
Feb 22, 2014 | 2007 Honda CR-V
My 323i was stored for 2 years. I am now getting it road ready and the passenger front, and both back doors wil not unlock. can you help?
Hi, try this as it may or may not apply to your model.Get in, open and close the drivers door, put key in ignition turn 2 clicks and take back out again, within 5 seconds, hold the 'lock' button in the middle of the key and press the 'unlock' button 3 times, then let go. Quickly repeat the lock and unlock button sequence on the spare key. All doors should lock and then unlock when it has worked.
Jan 24, 2011 | 1999 BMW 323 Series
Amana tandem 7300 stopped ,door is locked wash light is beeping
Door won't unlock
Did all of the water drain out of the washer during the spin? Select DRAIN & SPIN to remove any water remaining in the washer. The washer door will unlock at the end of the drain.
Is the door locked and is the "Add Garment" light on? Press START/PAUSE once. The door will unlock.
Nov 28, 2010 | Amana Washing Machines
Unlock code
the provider wil give you unlocking code after 1 year use ask the provider by giving the imei code you wil find it under battery or pre *#06# the phone wil display it
Sep 22, 2009 | Sony Ericsson W200i Cellular Phone
Door wil not open after self-cleaning cycle.Code
Unplug the unit or shut off the circuit breaker for 5 minutes. Plug the unit back in or turn on the circuit breaker. Set the clock and gently try moving the door lock lever (is so equipped) or opening the door.
or
Set the self-clean cycle again and only allow it to work for 15 minutes. Cancel the self-clean cycle and allow the oven to cool. Gently try moving the door lock lever (is so equipped) or opening the door.
If these procedures fail to correct the condition, the lock must usually be accessed and moved manually to open the door.
Some model ovens require the oven door to be manually unlatched before the controls are returned to the OFF position or else the door may not be able to be unlocked. Check the owner's manual for proper operating procedures.
Sep 18, 2009 | Kitchen Ranges
Range Rover Passenger Door Will Not Open
I have a 2002 land rover discovery and my passenger front door won't unlock with the interior lock button on the dash or with the key fob. The only way to unlock the door is to pull the handle on the inside of the door. Is the actuator bad?
Please help
Rover2163
Jun 18, 2009 | 1998 Land Rover Range Rover
Door would not unlock - got an error code f-22 what does that mean?
your door switch may be going bad.try pushing the door in and hit drain spin and if that works then it will unlock.I need to know what code is flashing to help further.hope it helps.
Mar 05, 2009 | Whirlpool WFW9200S Front Load Washer
Drivers side door wil not unlock
There is lock linkage inside the door panel. many of the parts are plastic and are designed to break if someone attempts to break into your car (I had this happen to my 87 camery) I replaced the green plastic "knuckle" and it fixed it.
Feb 03, 2009 | 1993 Lexus Es 300
Water will not drain out completely
You probably have a partial blockage in the drain line or the drain pump. This is not difficult to check. Just open up the panel below the door of the dishwasher and look for the flexible drain line. It is attached to the drain line pump. Unscrew the pump from the dishwasher frame, disconect the drain line and take a look at the pump and the drain hose. You may find a piece of glass or other hard object that is causing the problem. good luck.
Jan 27, 2009 | Whirlpool GU2400XTP Built-in Dishwasher
Door on washer will not open
Select Drain/Spin to remove any water remaining in the washer. The washer door wil unlock at the end of the spin.The washer door will not unlock if the unit has not drained.
Nov 09, 2007 | Whirlpool Duet GHW9150P Front Load Washer
LG WM-1832C Front Load Washer Logo
103 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
