Question about Bernina Artista 180
Bernina 830- Can't get decorative stitches and zigzag to work
I can't get the decorative stitches and zigzag to work. When I move the stitch regulator (even up to '4') it barely moves the needle for zigzag. And for the decorative stitches, it looks like the knobthingy (and white plastic piece) is not coming out far enough to the cams. I have oiled just about everything!! Any ideas??? Thanks!
RickE1
  • 202 Answers
SOURCE: how do i use the zigzag stitch on my bernina 830
Hi, open the top cover and if you watch what goes on inside from the top when you move the top change lever you will see part of it goes through a fork or U-shape part. This part is probably stuck and needs some oil. After oiling and working it back and forth a bunch eventually it will start snapping into the notches its supposed to. I beleive then you will have your zigzag back.
Either that or you have the stitch width set on zero.
Posted on Feb 07, 2009
RickE1
  • 202 Answers
SOURCE: Bernina 830
Open the top and look below the selector lever. It fits into a forked part that snaps back and forth. This gets gummed up and you need to oil it well and move it back and forth until it is freed up. Then your back in business.
Posted on Oct 18, 2008
  • 30 Answers
SOURCE: bernina 1130 feed dogs won't feed fabric
Could you have accientally lowered your feed dogs?
Posted on Jun 21, 2009
  • 13 Answers
SOURCE: old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Posted on Aug 29, 2009
  • 980 Answers
SOURCE: My Bernina 830 Sewing Machine is not sewing the
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Posted on Oct 24, 2009
Bernina 830: When making a buttonhole... the zigzag #1 stitch on left side looks nice... then the #2 bottom bar tack looks good...
Please tell us which Bernina 830 you have--old mechanical Record or new computerized?
Here's a recommendation from a Bernina owner (Ellen Rosenthal on Yahoo Group "BonosBerninas":
I agree about the buttonholer. The reverse stitching never looks as good as the left or forward side. I “hack” this by pivoting my fabric and only
going forward-avoiding the reverse stitch. Also helps to do the whole process twice and to use some tear away or wash away interfacing.
There is another Yahoo group called "BerninaThirtySomethings" that is a great resource.
Jan 25, 2018 | Bernina Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
The zigzag on my Bernina record 830 bought in the '80s does not work properly. What can I do to get it to stitch wider than 1/8?
Your machine is seizing due to lack of regular oiling.
Here is a diagram of the oil ports for your 830 Record:
http://www.fixya.com/support/r25625872-bernina_930_record_oil_diagram
Following is the process I used to "save" a few older Berninas:
Wheel on right side that controls the needle up and down is very tight...
Apr 29, 2017 | Bernina Sewing Machines
Have replaced cam gear on Bernina 830. Needle pendelum is fine on regular zig-zag stitch, but is out of sinc on the other decorative stitches..How can I fix this problem?
Its working maybe not timed anymore sometimes its the same way like a mode-select switch on the timed intake of a function on a videorecorder when its getting dirthy contacts it will function so that it worked in the wrong way outside the borders of the end of the circuit and can caused several damage or have only a missing link. but beware to take the problem that caused the problem out on this otherwise it is only for a short while suc6
SOLVED Bernina 830 service manual Sewing Machine
Dec 23, 2016 | Bernina Sewing Machines
Bernina 1630 Can't adjust stitch length - any ideas.
Hm, the 1630's are still mechanical machines with some electronics, right? Could be the mechanics have seized due to old oil solidifying and preventing things from moving like they should. This is the method I've used on completely mechanical Berninas that have seized. (Use caution in not getting oil on the computer components!)
How can fix stuck needle bar on my Bernina 730
Will not zigzag or decorative stitches New to these newer plastic style...
Nov 18, 2016 | Bernina Sewing Machines
I cant get my stitch Width Zig zag knob to turn om my bernina record 930. Any one have this problem?
Most likely because your machine has not been serviced (oiled & cleaned) in a long time and the old oil has turned to glue and seized. This is probably the most common problem with mechanical sewing machines. A mechanical sewing machine should be regularly maintained..ie every 40 hours of sewing use or at least every six months when not in use. You may want to take it to a Bernina service technician. Ask for a bottle of Bernina oil for CB hook machines and ask if they will show you how to oil it.
My machine Bernina 830 does not run
Bernina 830 won zig zag won buttonhole no decorative stitch
Bernina 930 Record oiling diagram
Questions Answers for Bernina seized Sewing Machines
Aug 14, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
How do I enlarge decorative stitches on a Bernina 830?
The only way (that I'm aware of) to enlarge decorative stitches is by increasing the stitch width and the stitch length. You might try a thicker thread that will cover more. The only other way might be to use embroidery software.
May 09, 2015 | Bernina Sewing Machines
Can't do zigzag on 830
You need a repair shop - sounds like a part is worn out.
Jun 09, 2017 | Bernina Sewing Machines
Sewing Machines Logo
158 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Chris Wetmore
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
