Question about Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor
Bostitch compressor won't start
Used it 5 times and now won't even turn on. Tried different power sources. It's at zero pressure. Push/pulled starting knob. Nothing.
  • darren_germ Jun 03, 2010
    If you look at the diagram, I don't see anything under the hood that has fuse/reset button. I also thought the same thing. It's like a sensor is telling it its full pressure and won't turn on.
    http://www.mastertoolrepair.com/bostitch...
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 91 Answers
It has a reset button somewhere and usually a fuse. take the cover off (unplugged) and look for a red reset button or a fuse. if it keeps blowing the fuse or tripping the reset then it will likely need service by a service center.
Posted on Jun 03, 2010
  • das boat Jun 03, 2010
    the regulator may be faulty and telling it is at full pressure. have you set the regulator where you want it to be? maybe the power switch is faulty. if you know how use a meter and see if you have 120 volts ac at the switch from the power line. then check for it at the motor with the switch turned on. if you dont have power to the switch then the power cord is bad. i have seen it all so this could be the problem even if its new.
Can the pressure switch on a Bostitch pancake compressor model cap2000p-of be adjusted so the compressor will come on and shut off at a different pressure than what was set a the factory?
NO unfortunate There is a electric pressure stop on this model !! not an adjustable pressostat (presure switch) pos 21 is the electric stop at maybe 8 or 10 bar
the savety valve is pos 22 (there is mostly a maximum pressure notition on to read) there is nothing to adjust on this type compressor what is made for a group a (Stanley-Bostitch-Dewalt) patented this pump is placed in several types of compressors of this brands.
http://servicenet.bostitch.com/Products/Detail?isId=true&productNumber=CAP2000P-OF&selectedType=25111
Detail
Oct 24, 2015 | Air Tools & Compressors
I have a newer Bostitch Air Compressor and it worked just fine a month ago and now we plug it in and the motor doesn't even turn on. And, no, it is not the outlet.
It is not uncommon for these compressor motors to "burn up". They are especially prone to overheating if a 14g or 16g extension cord is used to power it. Most of these do have a motor thermal protection button. Look carefully around the motor and motor mount frame. Of course, tracing the electric with a volt meter will confirm the location where the voltage terminates. The Auto/Off pressure switch is another possible fault. Taking the motor leads and powering them directly with 120v will confirm a motor problem. If this is an Oil Lubricated pump then double check by removing the back of the motor cover and turning the fan by hand. If unable to turn.. the pump may have froze up due to lack of lubrication. Usually a pipe wrench turning the exposed motor shaft will unlock the crankshaft and a high grade synthetic non-foaming motor oil in the crankcase will help keep it lubricated and it may contimue to work okay.
Oct 16, 2012 | Stanley NEW Bostitch 2 HP 6 Gallon...
Bostitch CPACK300 Motor won't cut off!
First; most repair centers, mine included, are reluctant to instruct users on how to adjust compressor settings because of the dangers of setting levels to high and risking tank ruptures. 15 to 20 psi is considered explosive pressures so when you are dealing with 135 to 150 psi or higher, you have to be able to understand and respect the dangers.
Second; if your compressor was working properly and now isn't and no one changed the setting of the pressure switch, it is more likely you need to replace the switch. If the spring or other mechanisms that controls the pressure the switch turns the motor off and on are damaged or broken they need to be replaced.
Lastly; at your own risk, most pressure switches have directions inside the cover on how to adjust the cut-in and cut-out pressures. I have never seen one that requires special tools, usually a screw driver or nut drive will turn the adjustment screw. When adjusting the screw, turn the screw in half turn steps and cycle the motor at least twice between adjustments to check where the switch is cutting in and out. If your switch does in fact require a special tool you will have to see if it is something the repair center can sell you or take/ship the compressor to them for repair.
Oct 08, 2012 | Stanley Bostitch CPACK300 3-Tool Finish &...
Compresor will not hold pressure
Some are push down to lock so you need to lightly pull up on the knob before trying to turn it. If the regulator itself is bad the correct one is part #AB-9051116 and is less then $10. Any Bostitch or DeWalt (the companies merged) can get this part for you. Here is a link to the parts diagram. It is item 108 and is called a pressure reducer.
Bostitch CAP2060P diagram
Aug 19, 2012 | Stanley Bostitch 2hp 6gal Air Compressor...
CAP 2060P air compressor won't start. How does the red on/off switch work? Ours just turns and hard to tell where it is supposed to be. Also, is there a reset button someplace? Thanks.
The pressure switch installed on your unit is of the pull / push type. Let all the air out of the tank and plug it in to wall outlet. Push red knob in firmly then pull out for desired results. The pressure switch contacts can fail but usually after many hours of hard service. No reset /thermal breaker is listed on the replacement parts list. You can view at WWW.bostitch.com click on service / parts then look for your model number from the pull-down list. Good luck with your compressor.
Apr 17, 2011 | Stanley Bostitch 2hp 6gal Air Compressor...
On a Bostitch CAP60P-OF air compressor I can get 120 PSI easily but get little or no air pressure on the the hose side. Can't even run a stapler.
i also own a bostitch and it works great, the pressure regulator knob on mine is red not sure if yours is the same color but just turn this knob until you get the nail depth that you need , it should be near the pressure gauge, a quarter turn of this knob at a time is recommended until you get the pressure you need, i think you turn it in the loosen direction to get more pressure
Jan 22, 2011 | Stanley Air Tools & Compressors
Hi, i have a craftsman 5 hs compressor and it just started tripping breaker every time i turn switch on. it tries to run several seconds at partial power before actually triping breaker. i have checked...
if the compressor turns over freely then you have a motor fault its likley to be a short in the windings causing it to loos power and therefore pull more amps this in turn pops your brakers as it is a 5hp 110 volt motor will pull nearly 45 amps witch if nearly half the power that my house runs on (but at 230 volts i have twice the pushing power)
Jan 17, 2010 | Air Tools & Compressors
Stanley FactoryReconditioned Bostitch UCAP2060P 105 Amp 2 Horsepower 6 Gallon OilFree Pancake Compressor Logo
2,559 people viewed this question
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
