Question about Health & Beauty
Most of the time won't start even with fully charged new batteries. Have checked every obvious thing such as reseating all connections, CB, freewheel micro sw. Sometimes it'll start for no apparent reason and other times there seems to be no way possible to get it to go. Please offer suggestions.
  • 1 more comment
  • Neil Wood Jun 03, 2010
    Hi. Is this a mobility scooter or a motor scooter for the road? Neil.
  • mitchl87 Jun 03, 2010
    Hi, Neil, It's a small ,Pride Mobility - Sonic model
    SERIAL
  • mitchl87 Jun 04, 2010
    SERIAL #S4509604089C30. For sidewalk handicap people.
    Voltage is getting to some of the controls in the Tiller except there is no voltage on the speed control pot or the lever pot. No voltage is reaching the motor either.
    The trouble shooting LED blinks once and then 3 times.
    The note for this indication says take it to a certified technician. I am a retired electronics
    technician(IBM) but am 89 yrs old and handicapped.
    Thanks for your help. Do not have a schematic.
  • 177 Answers
Hi. This has got to be a faulty motor. The brushes either wear down and jam, or if the caps that hold them in place are not tight enough, the brushes arc on to the sides of the brush holders and jam.
Disconnect the motor connector and by using a multi-meter, see if there is a circuit through the motor. Be careful screwing in the brush caps, as they are prone to cracking.
If the brushes need replacing, its probably a good idea to have a serviceman overhaul the motor and fit new bearings as well.
In some cases, this fault, can also be caused by a faulty motor connector.
Good luck. Neil.
Posted on Jun 04, 2010
HOW DO I RECTIFY THE FAULT IN MY SCOOTER?
hi Laurie, the five bleeps is related to the brake , you need to check the connections between the axle and the frame and the connection to the brake...
Regarding a circuit diagram... Pride would never supply such a thing, it's propriety information.
Regards
Rob
Nov 03, 2015 | Pride Go-Go Ultra X 3-Wheel Travel Scooter
I have a 95 honda civic ex,wont start.ran fine yesterday,wont start this morning.battery is fully charged,new cap and rotor.would do u think might b my problem
if it wont turn over 1st check the ground s on the car and the battery 1st. your battery can be fully charged and the car will not start even over night this can happen. then look at the starter. Note: if you have over 109K on the car and the timing belt has never been replaced you will need to have this checked as well.
Aug 16, 2014 | Cars & Trucks
What cause the car want start even if u jump it it just cleick
Start with the basics, here. Check that battery cables are not loose and are CLEAN, on the battery AND the starter. Beyond that, check the battery charge with a volt meter. Fully charged should be 12.5 volts or higher, you will lose starter spin at 10 volts. If the battery is low, hook it up to a charger and charge it up completely. If you don\'t have a voltmeter, go to the store and buy one. If you\'re going to try and fix things like this, you have to have one. If you can\'t do that, remove the battery and take it to someplace like AutoZone. They will charge and test the battery for free. If you can\'t take the battery out, or don\'t have a friend that can, have the car towed to your mechanic.
Here\'s the thing- I can\'t tell you exactly why, but some cars you just can\'t jump start. Happens more on side mount post type batteries. Because you can\'t jump your car doesn\'t mean it won\'t start with a fully charged battery. Now there are other things that could be wrong with you car, that it won\'t crank over and start for you.....but we begin the diagnosis with the battery.
Mar 17, 2014 | 1993 Oldsmobile Eighty Eight
Ok my 1983 camaro has a v6 in it and every time I want to start it I have to hook it up to a portable battery charger and start it up like that but now it won't even start up. Even when the battery is...
Sounds as though the battery is no good,
unless you know otherwise & also had it tested
Charging a battery doesn't address it's internal
condition
You have battery cables that corrode inside & can be
voltage drop tested
You have the starter & solenoid,ignition sw & such, to name
a few,lots of possible causes & things to check
Jul 24, 2013 | Cars & Trucks
Battery shows fully charged and the horn beeps but it won't move.
I have the same problem in mine.. But the beep is continous. Mine is a fortress 2000 AT. anybody knows what's the trouble on this one?
Jan 12, 2013 | Electric Mobility Health & Beauty
Won't move with charged batterys
Hi, any bleeping, flashing lights , double check the freewheel lever,
1. Any clicking from the rear .
Please keep me updated.
Regards
Jan 10, 2013 | Pride Celebrity X 3-Wheel Electric Scooter...
Iphone won't start up
Un plug the battery check the connections on the battery and the iphone clean with some stochbrite and wipe off with 90% alcohol let dry and should work fine as long as the battery is fully charged.
Dec 26, 2012 | Apple iPhone 3G
My 2000 Vespa et150 won't start. Battery is fully
try jump starting as well as checking you connections
Sep 17, 2012 | Cars & Trucks
1990 fzr 1000 won't start
check relay switches, earth wires
May 10, 2012 | 1990 Yamaha FZR 1000
My wife has an Invacare Auriga, it was not charged over winter, therefore batteries went flat. I bought 2 new batteries and fitted them, but when I switch the key on, the left hand light on the dash panel...
Check that you are not in freewheel. If you can push the scooter easily and the rear wheels roll then you are in freewheel. Move the lever to drive postion and turn the scooter on to see if that fixed the problem Hope this helps
May 05, 2011 | Health & Beauty
Health & Beauty Logo
59 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
