Question about Kenmore Kitchen Ranges
Kenmore Power Miser 5, 40 Gal. Electric Water Heater leaks at the seal of the lower heating element. papionc@hotmail.com
  • Christopher Papion Jun 03, 2010
    Excellent! Worth the investment in getting the answer and saving expense of plumbing repair by a technician for simple mechanical labor.
  • Christopher Papion Jun 05, 2010
    Sir, having difficulty removing the heating element, however, the pin hole leak appears to be coming from behind the rubber boot - not from the threaded seal where the element is screwed in. Once I remove the heating element will the gasket seat where the leak is, or not?
    Any suggestions for loosening the heat element? I'm reluctant to try the clockwise turn with the element wrench. I tried tapping the wrench handle with my hammer, no give and not enough bite on the element wrench, it keeps slipping unless held absolutely perpendicular over the short hexagonal head. Chris
  • 2,841 Answers
You can easily replace the seal and I would advice you just replace the element with a new one if they water heater is over 5 years old. Purchase a seal from Sears or new element, or any other appliance dealer. Purchase Pipe Dope and an element wrench at a plumbing supply store. Warning: Turn off the power to the water heater before you do anything. Turn of water supply to the water heater. Drain all water from the heater using drain at bottom which you can hook a water hose to. Open the hot water heater relief valve to speed the draining. Put on gloves as the area around the element is sharp and you can get a bad cut. Remove the cover from element attached with 2 screws. Push the fiberglass or cardboard out of the way. Remove wires from element and write down how they are connected. Remove the element by turning counterclockwise. If you have a hard time removing it try turning clockwise a little. If it still will not turn you may need to purchase that element wrench at a plumbing supply store if you failed to do so. Sometime you can use a pipe wrench. Remove the element, clean the area, and replace the gasket and the element. Put pipe dope on the element threads before reinstalling. Remove all the aerators at all the faucets to prevent debris from clogging them when you turn the water back on. Shut the safety valve. Turn the water back on and turn on one hot water faucet farthest away from the water heater to allow the trapped air to escape. Once you know the water heater is full, shut off the faucet and turn the power back on. Replace all the faucet aerators. This will solve your leak problem.
Posted on Jun 03, 2010
  • NOT ME Jun 05, 2010
    Try using a pipe wrench if you can get it into place so you can have more leverage. Otherwise you will have the use the element wrench. You may have to heat it slightly with a propane torch. Sometimes that can be very stubborn especially on an older unit. Just be very careful with the torch. The new seal will stop the leak if a bad seal was causing the leak. Sorry but, if you have a hole in the tank itself then you will have to buy a new water heater as it is not repairable.
Water only stays hot for about 5 min or
Gas or electric?
Electric water heater ... then test for crossover, check for water leak, replace thermostats, test elements
Gas water heater ... test for crossover, check for water leak
http://waterheatertimer.org/Crossover.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
http://waterheatertimer.org/How-to-test-water-heater-element.html
water leak: turn off all taps and put ear against pipe and listen for water leak... check if water meter advances when all water taps are off.
Gene
Oct 09, 2014 | Water Heaters
Rheemglas standard energy miser electric water heater model #81vr-80 gal serial #RH0501c00664. Does it have two heating elements and where are they?
it does have 2 elements they are located under the 2 panels on the heater you will find them under the covers on the front they will be connected to the thermostats follow the wiring. besure to turn off the power before working on it and use a tester to double check
May 31, 2014 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water Heater Issues
An electric water heater contains two elements (usually upper and lower). Normally hot water is maintained at a certain temperature to assure an immediate supply. When hot water is turned on at the fixture, the second element is turned on to boost the temperature. From your description one of the heating elements may be defective or set to incorrect temperature.
Apr 28, 2017 | Water Heaters
No power to lower heating element
Test elements.
If elements test out, then replace both thermostats.
More resources:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Otherwise, if you have some hot water, then power to unit is good and probably at least 80% rated voltage, breaker is good, and upper element is at least functional and probably working perfectly, reset button is not tripping so tank is not overheating.
Mar 27, 2013 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Water heater does not produce as much hot water as it use to. Could it be, that one of the heating coils is out. If so is ther a reset switch? Before I have someone check the coils.
Ordinary tank-type electric water heaters are fully repairable by homeowner.
A) Rheem electric water heater website:
http://www.rheem.com/products/tank_water_heaters/electric_water_heaters/
Find age of Rheem: look 3rd and 4th digit of serial number, for example 06 is 2006
B) Water heater has some hot water.
That says certain things: upper element is working, water heater electricity is working, reset button is not tripped, and heater is not experiencing run-away overheating event.
http://waterheatertimer.org/How-it-works.html
C) That leaves 4 suspects.
1) TP valve is running hot water out of tank, or leaking faucet is running hot water out of tank.
Check for leaks
http://waterheatertimer.org/How-to-replace-TP-valve.html
2) Lower element is burned out.
Test lower element using inexpensive multi-meter from Home Depot.
Replace element with same wattage shown on label, and clean out sediment:
http://waterheatertimer.org/How-to-clean-sediment-out-of-electric-water-heater.html
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
2) Upper or lower thermostat is bad.
Replace both thermostats for about $25.
3) Burned or shorted wire located between upper and lower sections of tank.
Turn off power. Open covers on side of tank. Remove insulation. Inspect parts for signs of high heat and burning. Especially check lower element. Tighten any loose wires. Replace part that shows signs of burning.
Put insulation and cover back over thermostats so cooler outside temperature doesn't cause thermostat to misread tank temperature.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 11, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Rheem 49 gal model 81V400B - hot water lasting only 5-10 minutes then takes an hour to heat back up.
A) Basic info on Rheem
Find age of Rheem: look 2nd and 3rd digit of serial number, for example 06 is 2006
C) That leaves 4 suspects that cause lower amount of hot water.
1) TP valve is running hot water out of tank -or- leaking faucet is running hot water out of tank.
Check for leaks
Feb 03, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Wiring an electric water heater
Hello,You are correct! Black/blue=black & Yellow=white 220volt single phase power.There are 3 wires for 3 phase power connection NOT the case in a home.Also an "off peak"timer option would use (black) only controlling the bottom element and (blue) controlling the top element.
Apr 21, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Kitchen Ranges Logo
195 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
