Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Fast ggreen flashing timer light - Mitsubishi WD-62525 62" Rear Projection HDTV
  • 597 Answers
Count # of flashes. Call Mitsu tech support
Posted on Jun 03, 2010
Fujitsu asta18lcc has a constantly fast flashing green light and the red light flashes slower 5 times with a small gap between each 5 flashes. Unit wont work at all apart from lights.
The red light (operation) flashing 5 times can be one of four things depending on the green light (timer) but the green light should flash at the same rate as the red light, not faster - either 2,3,5 or 6 times. Anything other than these is abnormal and you will need a tech to diagnose.
Could be a faulty controller board or compressor.
Apr 22, 2017 | Fujitsu Heating & Cooling
Hi there I have an r410a and the timer is flashing continuously if I turn the unit off outside ie reset it then it comes on for a few minutes then shuts down can you help please
brand and model number would help here. Flashy lights usually mean error codes. count the flashes or if it is flashing fast or slowly.
Jan 04, 2015 | Heating & Cooling
Tv won't turn on. Timer light fast blinking
either wait until the light stops flashing or press the reset button. if teh problem persist it is most likel several boards that need to be rplaced
Feb 22, 2011 | Mitsubishi WD-52725 52". Rear Projection...
I bought Utilitech #0141224 7 day digital in wall timer. I have just 2 wires at the junction box both of which are painted over but assume one could be black and other white. The 7 day digital timer...
Hello, I bought an in door smart digital timer (G.E.) or Jasco product for my front porch light. I hooked all the wires as instructed and programmed according to instructions. I have a two wire system, so i left the green wire unattached. The light comes on but flashes very fast. What's up with that? This is the second one i've replaced, the first one did the same thing!. Whats wrong?
Thanks,...
M Jones
Sacramento, CA.
Aug 16, 2010 | Intermatic Inc. ST01C Digital In-Wall...
Fast flash timer light
A fast flash indicator is an error code of some sort. Possibly your projection lamp timer indicated a lamp chnage required?
Aug 15, 2010 | Mitsubishi WS-55859 55" Rear Projection...
My timer light is flashing fast. I unplugged set and plugged it back in. I also pushed the reset button front. It is still flashing, but won't turn on.
http://www.tvrepairkits.com/xcart/home.php is your answer. I just did mine and it worked like a charm. For 46 bucks, you can't beat it.
May 21, 2010 | Mitsubishi WD-52725 52". Rear Projection...
1998 Buick Regal GS, Several problems are
start by checking the front wiring harness for corrosion , best is to do a continuity test on all the wires, look for corrosion in connecting harness, time consuming but the only way
Nov 28, 2009 | 1998 Buick Regal
Hotpoint washer dryer lights flashing
Check first the thermal fuse.
Test heating element to ensure is not grounded, and staying always on. Test the fan and ventilation system.
If you find no fault in there , then test the timer control board.
Enter the model number on one of two websites below to get parts and diagrams for your appliance:
Appliance Parts From PartSelect
Appliance Parts Pros
Apr 23, 2009 | Hotpoint Ariston Aquarius WD420 Front Load...
Mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
Oct 18, 2008 | Mitsubishi WD52527 52" Projection HDTV
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
81 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
