Question about Garden
I have a homelite weed eater(20699), and the fuel lines became detached. What line does the fuel filter go on? The line that primes the engine(with the little pump) or the other line!!
  • 1,305 Answers
You want the filter keeping the inbound fuel clean to the bulb and the carb... the other line should be a return line to the tank...to pressure the system... So put it on the inbound to bulb and carb.
Posted on Jun 03, 2010
My weed eater won't prime
check the primer bulb to be sure it is not cracked. check the fuel lines also. they crack and wont pull fuel.
Jun 15, 2017 | Garden
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Primer bulb not filling
    Bulb or fuel line could have a crack or a clog in fuel line/filter or carburetor. Here's a video on how to change the bulb and fuel lines and another video on how to clean/rebuild the carburetor.
    Homelite Tune Up
    Homelite weed eater gas trimmer will not run how to rebuild weedeater...
    May 02, 2014 | Homelite Mighty Lite Lawn Trimmer
    Homelite weed trimmer bogs down and smothers out quits running
    This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
    Homelite Tune Up
    http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
    Apr 27, 2014 | Homelite Garden
    Primer does not work
    Homelite Tune Up
    Apr 22, 2014 | Homelite Mighty Lite Lawn Trimmer
    Bulb will not prime
    Homelite Tune Up
    Hi curtis, i have a craftsman 32cc bushwacker weed eater. i had to replace fuel line in tank with filter. i also replaced the second line in the tank which is alittle larger in diamiter. i have a primer...
    change the fuel lines over on the carby
    you are trying to feed fuel through the primer line when the engine is running and that is why it is cutting out
    Mar 12, 2017 | Garden
    Can't find fuel filter on Poulan Pro weed eater. Acts as if it's fuel starved
    Where is the fuel filter?
    All gasoline engines have a fuel filter on the end of the fuel line in the fuel tank. Weed Eater recommends changing the fuel filter yearly. To remove the filter,
    1. drain the fuel from the unit,
    2. Pull the filter from the tank through the gas tank opening and remove it from the line,
    3. Install the new filter on the fuel line and drop back in tank.
    Jul 08, 2009 | Poulan Garden
    My homelite weed eater sx-135 the fuel filter broke of the tube
    The longer, and sometimes smaller in diameter fuel line, goes from the carburetor to the bottom of the tank. This line, which has the filter attached to the end, should rest comfortably on the bottom of the tank.
    The other fuel line goes from the primer bulb to just inside the tank, (about an inch, with that very small piece of plastic attached to it. This piece of plastic keeps this line from pulling out of the gas tank. this line serves as an overflow from carb.
    Jim
    Jun 07, 2009 | Homelite Consumer Products 4.0 Amp, 13 In....
    Fuel line connections in the tank ?
    The one without the filter is ok just being a little inside the tank. Make sure that line is hooked to outlet on the primer that pushes pressure into tank.
    Jun 06, 2009 | Homelite Consumer Products MightyLite...
    Garden Logo
    103 people viewed this question
    Top Garden Experts
    Dennis Key
    Dennis Key
    roeb
    john h
