Question about Fisher and Paykel Fisher & Paykel Washer
I have a fisher paykel GWL10 washing machine. It shuts off while
I have a fisher paykel GWL10. It shuts off while filling, runs for 1-2 minutes then shuts down. I smelled a burning electronic smell Diagnostic modes reveals no default code. i unplug, wait a minute and machine will power up and try to restart, then shuts down again after 1-2 minutes. I unplugged machine, turned it on and advanced to spin cyle. The spin cycle worked fine.
  • 159 Answers
At this stage i can suggest that the inlet valve may be faulty & giving off this burning smell.open the control box & see if one of the 2 inlet valves look distorted or brown or burnt looking.I'm wondering if it's not filling very fast also,this could also be an indication of the valve.
Posted on Jun 03, 2010
Gwl10 us won't fill
there's a few possibilities here.
is the water on?
does the machine start and turn the bowl, and not fill? then you have a valve fault.
when you press start, does it beep like normal? if not, you have a start button fault.
Oct 15, 2013 | Fisher and Paykel IWL12 Top Load Washer
Intermittent Draining and Burning Smell
The water will not run in the machine.It will for a few second then stops. What could be the problem?
Aug 15, 2012 | Fisher and Paykel GWL11 Top Load Washer
Fisher Paykel ecosmart starts to drain for a few seconds then stops.
it could be you have somthing caught in your pump and your belt is sliping that will cause the burning smell take of your pump and check this is the first thing to try please let me know
Nov 10, 2011 | Fisher and Paykel GWL11 Top Load Washer
I have a 10 year old Fisher & Paykel GWL10 washing machine. Fault code 1 is coming up. The machine turns completely off. The longer it cools down, the longer it goes before turning off again. This...
Code 1 - usually means on the later models of Fisher & Paykel is a faulty Motor Control Module, often though one would have to replace both as well as the display module.
Anyway - it sounds like the electronics are overheating hence the intermittent problems you are experiencing.
May 27, 2011 | Fisher Paykel EcoSmart GWL15
Burning Smell on Fisher and Paykel GW11 on spin and is not getting up to speed on spin cycle. Motor Bad?
Hi just read your posting.In my experience the only part on a Fisher and Paykel top loader machine that creates a burning smell is the pump.Try looking under the machine and you will see a black fan.This is your pump.Check to see if it has corrosion on it with a torch and try smelling it.I am sure you will find it is the pump that is smelling.Please reply for additional help and tell me how you got on with checking the pump.Looking forward to your reply.
May 14, 2011 | Fisher and Paykel GWL11 Top Load Washer
Fisher & Paykel GWL10 begins to spin for about 15 to 20 seconds, just starts to pick up some speed, then machine beeps and shuts down. Seems like the water is draining. Any ideas? It has also been...
Yes it does seem like a control module fault.Bit concerned about the noise coming from the machine even thou it is not running.Please turn it off at the power point when not in use.Now if and when it faults again please reply back with error code as per 1st posting.
Jun 11, 2010 | Fisher and Paykel GWL11 Top Load Washer
I've got a fisher paykel gwl10 top load washing machine
Check the pipes leading to water pump for wetness also the door seal,If all pipes are dry and look ok then it could be due to the water seal and bearings braking down.
Jun 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Washing Machines Logo
636 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
