Question about Kenmore 64802 Top Freezer Refrigerator
Lights on not cooling
Can here motor barely running
  • Kenmore Master
  • 43,501 Answers
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
fggf
Posted on Sep 29, 2010
Barely cool, fan running and one tubing by compressor warm and one cool on and the cool
Is fan inside the freezer running with the light switch pressed in? To confirm a Freon on a refrigerator that still cools yet not well remove the rear panel inside the back of the freezer APPLIANCE911
Apr 17, 2016 | Refrigerators
I have a 1994 Buick Park Ave and the interior lights have just started coming on and off during the night for no reason and the car is not running.
These lights are actuated only by connection of the ground wire(white) to the body to complete the circuit. The only place these connections are made is at the door buttons and the rheostat on the dash that dims the dash lights also when knob is turned counter clockwise to dim the dash lights and clockwise to brighten them and on past that bright point to turn on the interior lights. One of the door wires may be bared and close to the body and arcing, making the lights come on and when the wire warms it pulls away from the body and lights go out. You need to remove the kick panel to access this wire and see if it's still plugged onto the back of the button connection and check for bare spots on wire.
Dec 01, 2014 | 1994 Buick Park Avenue
Why is there no condensation?? My portable a/c Technitrend model TN09E has been running for several hous , and there is no condensation. And the temp controll is barely droping. Can you plase help o
The blower fan may be running, but the equipment isn't removing heat from the space. Apparently the compressor is not working. Don't confuse the noises of the blower motor with a running compressor. Check for cool air at the registers. No cool air = no condensation. Cool air, then check your plumbing from the pan under the indoor coil (evaporator). The drain line could be clogged.
May 15, 2014 | Heating & Cooling
GESS25LGMB WW Side-by-side fridge/freezer won't cool.
call a repair service it probably need freon added to system and that is not a consumer FIX
Aug 27, 2017 | General Electric Refrigerators
Whirpool wgi fridge freezer, fridge not cooling?
Most frideges get all their cooling from the freezer. There will be a fan and duct in the back of the freezer that pushes cold air down into the fridge. If the duct is blocked with ice or the fan motor has quit. Your freezer will work fine but the fridge will barely cool at all. Check that the fan runs when the compressor is running, ( turn both temp knobs to the highest cooling and leave door open until comp. comes on). If the fan runs your duct is plugged. If not you need a new " Freezer Fan Motor". Most are simple to replace and cost around $100.00.
Jan 01, 2012 | Whirlpool Refrigerators
Freezer works fine, fridge barely cool. Hotpoint HTS22GB
If you cannot here the fan running in the freezer, you will need to replace the evaporator fan motor. Here is a link to the part you will need.
Aug 02, 2011 | GE Hotpoint Top-Freezer Refrigerator
I think i have a bad fan motor bearing. Unit is very loud and barely cooling.
The bearing may be going bad, but that should not effect the cooling much if the fan is running...there must be other problems...
Here is a tip for other things you can check....
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Jul 30, 2010 | Goodman CKL24AR24 Air Conditioner
Inside strip of fridge is very hot. cleaned out behind fridge and the coils, etc. fan is barely moving/not moving. any suggestions???
Replace the fan. The strip has a freon line running behind it, and when it is hot, this tells us that you have a dirty condensor, bad condensor fan motor, bad evaporator fan motor, defrost problem, or a freon system problem. When you say your fan is barely moving, I am assuming this is your condensor fan motor, which sucks air through the hot freon lines in the condensor coils, and cools the freon off. If it is barely moving, it can't cool the freon. In some brands a slow moving condensor fan can be caused by a bad main control board. Good Luck, Appliance Specialists
Jan 28, 2010 | Refrigerators
Cooling Fan
sounds like to me your motor in your fan is going. that is y your 4 runner ran nice and cool when its cooler outside. the hotter it is outside the harder your fan will work
Apr 25, 2009 | 1995 Toyota 4Runner
Kenmore 61042 fan motor replacement
hi! you mean there is ice on the part of evaporator or some in other part? its normally cool your refrigerator inside part.If ice is present your fan have insufficient air neede to frost free your evaporator its not the same with the origina you replace,beside your thermostat is not working have check this one.
Nov 23, 2008 | Kenmore 61042 Top Freezer Refrigerator
Kenmore 64802 Top Freezer Refrigerator Logo
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
