Question about Jenn-Air JSD2695KES Side by Side Refrigerator
My Jenn-Air JSD2695kes. The refrigerator side is not cooling.
My Jenn-Air JSD2695kes side by side frig is doing the following: The freezer works just fine, the regrigerator side is not cooling properly. Opened it up Saturday and it was 49 degrees.
Cleaned everything, back and under, removed the back wall of the freezer and the colis were frozen solid. Melted ice off with hair dryer and it worked for a day. It started warming up again and melting the ice from the coils worked again.
I need suggestions as to how to pin point what part needs to be replaced.
Need step by step directions, and a discription of the part that needs to be tested.
Have never done this before, need exact and very descriptive directions.
thanks. What do you suggest I do?
    Problem Solver:
  • 13 Answers
You most likely have a defrost cycle problem. Either a bad defrost heater, timer or thermostat. Jenn Air has put an Adaptive Defrost circut in the top of the Refrigerator section. You can find troubleshooting directions at ACMEHowTo.com
Posted on Jun 03, 2010
Jenn air JSD2695KES. Freezer is -2. Fridge side 45. Air movement is decent on freezer side Minimal on fridge side.
You may have a defrost problem starting. You can also clean your condensor coils if the are dirty it will affect the refrigerator temps sometimes.
Jul 24, 2015 | Refrigerators
How can I force defrost a jenn aire refrigerator jsd2695kes
Check manual to see if there is a manual technique for activating the defrost timer cycle. If not, and you are in rush, remove back cover of freezer, and after unplugging unit use hair dryer to melt the ice built up on the evaporator.
Nov 26, 2013 | Jenn-Air JSD2695KES Side by Side...
Fridge and freezer not cooling
clean conderser coils and make sure both fans are going ( the one in the freezer and the one by the compressor . . if this does not help there is a small and a large line common out of the compressor . the dmall one should be hot and other ( larger one ) cool . if not heat in small oine it;s low on freon . and may need recharge .. **** hope this helped mm feed back pls ..
Jan 16, 2010 | Jenn-Air JSD2695KES Side by Side...
I have a Jenn-Air side by side frig. The freezer side cools too cold, the frig side not enough. 2 weeks ago I took all the food out of freezer and noticed ice build up on back. I unplugged unit, let it...
If the freezer is staying cold it sounds like a defrost system problem. A bad timer, heater or thermostat can cause frost to build up on the coils and block air flow to the refrig side. Check out ACMEHowTo.com for troubleshooting the defroster problem.
There is a small duct between the freezer and refrigerator side if this is blocked the frig side won't cool.
Jan 09, 2010 | Jenn-Air JCD2389G Side by Side...
My Jenn Air JCB2285HES not cool on both sides not frozen line
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
jljhfjg
Oct 21, 2009 | Jenn-Air JCB2285HES Side by Side...
Neither freezer or frig is cooling properly. The
yes you have a defrost problem.. whirlpoolpartssurplus.com free tech advice i can simply walk you threw the process i recommend you do not defrost intill you find the problem
Jun 24, 2009 | Jenn-Air JCD2389G Side by Side...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
I have installed the main control board, I need to reset the frig
if you will pull the kick panel off of the front of the refrig and feel under the frig you will find a plastic envvelope with a tech sheet that gives step by step instructions for setting the cntrl board. thx peyton
Mar 26, 2009 | Jenn-Air JSD2695KES Side by Side...
Jenn-Aire JCD2389GES Side by Side: Frig not cooling fully - freezer fine
i'm thinking that maybe an air duct is either blocked or the damper isnt opening. In the freezer compartment at the top right side there is a cover that is held in place by 1 screw. (look at item number 35 here). remove this cover and make sure ice is not blocking it up. if that is ok, then check the damper control to be sure it is opening and closing properly. The damper is located on the refrig side in the control cover (look at item# 8 here).
Dec 18, 2007 | Jenn-Air JCD2389G Side by Side...
Jenn-Air JSD2695KES Side by Side Refrigerator Logo
476 people viewed this question
Top Jenn-Air Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Jenn-Air Refrigerator Expert? Answer questions, earn points and help others
