Question about Hitachi 53UDX10B 53" Rear Projection Television
My tv just beeps when you turn the power button on with the light flashing as it continues to beep on the power button
  • 597 Answers
Power board. count # of flashes..call Hitachi tech support
Posted on Jun 03, 2010
How to enter safe mode on my ps3
Step 1: Turn off the PLAYSTATION 3 by holding the Power button on the front of the unit till the Power light is red.
Step 2:
  1. Touch and hold the Power button, you will hear the first beep, meaning the PLAYSTATION 3 is powering on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep, indicating the video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a third beep and the system will power off (Power light is red).
Step 3:
  1. Touch and hold the Power button, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  2. Continue to hold the Power button and after about 5 seconds, you will hear a second beep for video reset.
  3. Continue to hold the Power button and after about another 5 seconds you will hear a quick double beep. At that point release the Power button. If you succeeded in activating Safe Mode, you will see a message on the screen saying, "Connect the controller using a USB cable and then press the PS button."
Apr 24, 2014 | Sony Playstation 3 (PS3) Console
When I turn on my PS3 will not load the basic applications, neither the games. When I press the PsS button on the cotroller to turn it off I will get the option but it will not tunr off and i will get a...
Step 2:
Step 3:
  1. Touch and hold the Power button AGAIN, you will hear the first beep, again for the PLAYSTATION 3 to power on.
  4. Connect a USB cable to the controller and the PLAYSTATION 3 and press the PS button to enter Safe Mode.
  5. Then you will see the Safe Mode menu.
*****CHOOSE RESTORE FILE SYSTEM WHICH IS OPTION 3****
and DONE!!
www.1RepairStop.com
Aug 25, 2011 | Sony Playstation 3 (PS3) Console
Ps3 wontplay games
Welcome to Fixya
Try the troubleshooting procedure below:
Step 1 - Turn off the playstation 3 by holding the power button on the front of the unit till the power light is red.
Step 2 - Touch and hold the power button, you will hear the first beep, meaning the playstation 3 is powering on. Continue to hold the power button and after about 5 seconds, you will hear a second beep, indicating the video reset. Continue to hold the power button and after about 5 seconds, you will hear a third beep and the system will power off (power light is red).
Step 3 - Touch and hold the power button, you will hear the first beep, again for the playstation 3 to power on. Continue to hold the power button and after about 5 seconds, you will hear a second beep for video reset. Continue to hold the power button and after about another 5 seconds you will hear a quick double beep. At this point release the power button. if you succeeded in activating the safe mode, you will see a message on the screen saying 'connect the controller using a USB cable and then press the PS button.
Step 4 - Perform the safe mode options in the following order until one of the options works for you. If one option works, do not continue onto the other options.
Restore Default Settings
Restore File System
Rebuild Data Base
Restore PS3 System etc...
Cheers
Nov 25, 2010 | Sony Playstation 3 (PS3) Console
Hi.when i turn on my ps3 it freezes at the main screen.please say i dont have to buy a new 1,i dont have the money. :(
Ok, if it is simply the image that is freezing and it is still staying on then there is hope for the PS3.
If however it is turning off with 3 beeps and flashing the red light then that is serious.
Please try the following if it is just the display freezing :
Turn the PS3 off into standby (red light on)
Press and hold the power button. It will beep when you first press it, beep again 5 seconds later and then beep one more time and turn off into standby mode (red light on)
Release the power button
Press and hold the power button again. It will beep when you first press it, beep again 5 seconds later and this time there will be 2 quick beeps together. Release the power button when you hear these 2 quick beeps.
The PS3 will start up asking you to connect the controller via USB and press the PS button. Do this and then continue.
After doing the above a menu will load with 6 options. Choose option 3 "Restore File System". This will re-install the PS3 software if it has become corrupt. Ignore any messages about corrupt hard drive, this is normal. If this step does not work try the above again but select option 4, then 5 if that doesn't work.
One of these options should get your PS3 up and running again.
Nov 07, 2010 | Sony Playstation 3 (PS3) Console
Beep - Beep - Beep - but No Picture
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries.
Sep 15, 2005 | Toshiba PDR-M60 Digital Camera
Sep 15, 2005 | Toshiba PDR-M61 Digital Camera
Sep 15, 2005 | Toshiba PDR-M65 Digital Camera
1. If the camera can not focus on a subject, or can not determine the appropriate exposure setting, the camera will beep and disable the shutter button. This is to avoid improper processing of the image. This is usually due to either poor lighting conditions or movement. 2. The camera Flash Element requires ten seconds to recharge between images. Although the camera is ready to continue capturing images almost immediately in bright (daylight) settings, if you are using Flash photography the Flash element will need to charge between shots. If you try to take a picture before the Flash is charged, the camera will beep and disable the shutter button. Once the Flash unit is fully charged (10 seconds), the camera is ready to continue. 3. The batteries may be running low. LCD Display, Flash, and Playback use much more power than taking pictures. It is possible to quickly consume battery power, even if you are not taking many pictures. Try turning the Mode Dial to the OFF position to recycle power. If the camera beeps and will not take a picture under normal conditions, you may need to change batteries. Please refer to the section pertaining to Battery Life.
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Sep 11, 2005 | Toshiba PDR-3320 Digital Camera
Hitachi 53UDX10B 53" Rear Projection Television Logo
119 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
