Question about Watts Onan Portable Generator - 4000 , Model# 5500
WHEN I START THE GENERATOR I HAVE TO HOLD THE START SWITCH ON TO KEEP THE GENERATOR RUNING.
  • parlapanov Jun 03, 2010
    Do You have some alarm indication or speed indication on the control panel?
    Scholar:
  • 142 Answers
The switch should be three positional.
The upper position is only for starting. Continuous running is in the middle (self holding) position. Lower position is to stop the generator.
If left in middle position it is not running you may have the switch bad, or the generator is stopped by low oil level.
Posted on Jun 03, 2010
Where the shut-off switch is located
sorry no make or model no help can we look for .
Aug 20, 2015 | Cars & Trucks
How to fix onan 6.5 rv nhm gasoline generator starts but won't keep running unless you hold in start switch on
The power for the run side of start switch is not making it to the coil. Check wires and switch.
Jan 17, 2015 | Cars & Trucks
My kohler 5000 generator will not run unless I keep the starter button depressed
First thing to do is get a "Wiring Diagram" for your Unit.
Once you get the diagram, just Follow the DC Ignition Power path from
the Battery, on thru to the Ignition Coil. Somewhere you aren't getting
12Vdc to the Ignition Coil, UNLESS the Start Switch is in the Start Position. It shouldn't take longer than about a hour, with a VoltMeter to find where the circuit isn't being "Made", and fixing or replacing that part. More solutions to different engine and generator problems at http://solosmallengine.blogspot.com/ and http://solo.ecrater.com
Jun 07, 2012 | Electrical Supplies
No 120V output
Please test the following and get back to us. Repace the receptical with one from a electrial store have found that many of them turn out to be bad once you replace it retest for voltage. If it still has no voltage then get back to me by posting a responce here to this question.
Jul 14, 2009 | McCulloch 13HP 338 Cc Portable Generator #...
My "KDE19STA3" Kipor generator keeps showing fault "L&H Freq.What could be responsible and what can i do? It shuts down about 30seconds after dispalying the fault.
this is telling you that the power frequency is above or below the safe limit and so shuts down.
do not run a load but
press the function button and hold then switch on but dont start keep holding until ph2 or similar is displayed then start read the frequency and adjust the engine speed until it reads correct then try will full load and adjust accordingly 1 or 2 hz either way will be ok
Jun 16, 2009 | Kipor Electrical Supplies
Only runs if I hold the start switch
The problem is that you are not creating voltage. Remove front cover. Place a volt meter on the breaker. Start genset and you will see no voltage present. The problem could be with the brushes, rings, rotor, stator, voltage regulator, or control board.
Apr 10, 2009 | Watts Onan Portable Generator - 4000 ,...
My Kohler Confidant IV generator starts and runs great for about 30 seconds and then dies,, starts right back up and does same thing, what is up with that
Kohler generators feed the generated voltage back into the control circuit board to tell it to keep the fuel pump (electric) runing and the ignition on. IF there is no voltage generated (bad brushes or?) then the symptom you describe will occur. The motor runs fine, but it isn't generating electricity.
Jim Russell
Mar 30, 2009 | Electrical Supplies
Starting the engine
you mean you turn the key of and engine keeps runing? if that's right posible some one conect you radiator fan to a ignition power and that keeps engine runing because the fan keeps turning and acts like generator putting power back to system, but if not let me know and don't mark my answer as inapropiate,
just can figure your question, you know what's bad? with this web page, than i'm here i will say may be waisting my time trying to help people for free and then after that people still mark my answers as inaproiate, is that fair? whell good luck and let me know, good luck
Jun 08, 2008 | 1993 Mitsubishi Expo 4 Door
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
708 people viewed this question
Top Watts Electrical Supplies Experts
Steve
Jim London
Jim London
Ottoniel
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
