Question about Samsung Televison & Video
I just mounted my new 55" Samsung lcd television and noticed that when the screen is very dark a large section in the middle is noticeably brighter than the rest of the screen. The oval shaped section is only noticeable when most/all of the screen is very dark so for most normal television viewing it is fine. Is this an issue I need to get resolved/repaired? Or is it to be expected with these sets?
  • reed_josh_j Jun 03, 2010
    Thanks for the response, but this issue occurs from all input sources, so there is no one cable that could be causing the issue.
    Champion:
  • 217 Answers
Hi good day! just a tip and it might help try to check on the cables if they are properly plugged or you can try to check on the contrast as well, just a tip hope it would work good luck!
Posted on Jun 03, 2010
  • Griffin Keith Gonzales Jun 03, 2010
    hi!i do have a samsung tv as well ive to check on for configuration that might actually adjust the settings for that problem but ive found none so might be best to try call samsung so that they could check it out.
    Goodluck!!!
Blurry, purple bar across middle of plasma tv screen
Plasma screens are extremely susceptible to getting broken from any impacts to the face of the screen. What you are describing sound very much like distorted or dead pixels. It may not be a fixable issue, you may have to replace the entire unit or live with the purple bar. The reason you don't notice it as much when the screen is dark is because purple is on the darker end of the spectrum, and will be most visible in contrast to lighter ad brighter colors.
Apr 01, 2016 | Samsung Televison & Video
When powering on my Samsung 55 inches LED TV, the middle/bottom light panel just flash/blink and there is no picture on the TV screen dark/black screen. I would have to let the TV on for 1-2 hours to
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 06, 2015 | Samsung Televison & Video
Bottom of screen purple "haze"
Check the site linked below, and see the screen shots of defective LCD TVs, Surf it with patience. This should be a panel fault I assumes. http://electronicshelponline.blogspot.com/
May 20, 2013 | LG 55LX9500 55 in. 3D HD-Ready LCD TV
Bright Spot
A fixed blue area on screen may be a display panel (main screen unit)
Here is a link for the boards etc this set uses--take your pick:
http://www.shopjimmy.com/sceptre-x460bv-f120
May 17, 2012 | Sceptre 46 X460BVF120 LCD TV
My tv is dark on the sides and light in the middle
Hi
ok you have defective RGB at the CRT board! the suspect is the variable resistor in green section and red section!
Thanks!
Dec 26, 2008 | Samsung TX-R2735 27" TV
Samsung LCD Question
The model is a LN-S4041D. A 40 inch LCD. I can send you a photo but I can't get the file size small enough to post
Feb 09, 2008 | Televison & Video
Samsung 101cm lcd Mounting??
Yes they are the mounting holes but I would not trust a universal mount to hold an expensive TV set on a wall.
Nov 26, 2007 | Televison & Video
Red spot when screen is black
Your light engine will need to be replaced as you have a LCD panel failure. Here is the link to the part number for the model 50V500 if you have the 50V500A it has a different part number. http://www.partstore.com/ProductDetail.aspx?ProductSKU=8286849&ProductType=PART&ModelID=374014
Mar 14, 2007 | Hitachi 50VX500 Television
Televison & Video Logo
75 people viewed this question
Henry  Thomas
Henry Thomas
