Question about Kenmore Elite HE4 Electric Dryer
Kenmore 90 series
Sears 90series dryer will not start
  • 2 more comments
  • nicnick Apr 20, 2008
    I have power but my dryer still does'nt start.
  • colocali22 Sep 09, 2008
    our dryer will work for maybe half a load...but then it stops...the power button makes a humming noise...then after sometime...it will start..but for about 5 min. then stops....then the humming sound....then if you keep pushing the start button a few times...it just makes no noise at all....then come back awhile later..and the whole cycle repeats.....can you help... thanks-- lud
  • mommamac2067 Sep 14, 2008
    Samr problem. Electric dryer suddenly willnot start. All I get is a hum. Seems to be a slight hot smell. I unplugged. What's up?
  • Anonymous Jan 10, 2009
    I have the same exact problem. Dryer runs for a few minutes, shuts itself off, slight burning smell and hum. Then turns itself back on after few minutes. Then turns self off again after few minutes with same smell and hum.
I have no solution, my dryer won't start but the buttons light up and it makes all the sounds but won't start? It's gas by the way if you have a solution pleasee-mail me back, or if you know someone who can fix it. HELP!!!!!!!!!!!! sheri
Posted on Dec 01, 2008
Sears 90 dryer does not start
My home video I made on youtube.
Dec 09, 2013 | Maytag Dryers
Need help with gas dryer Kenmore 90 series serial
Check the lint caught in the exhaust vents. If it is clear replace the spark ignitor if no click is hear upon starting up
May 14, 2010 | Kenmore 73952 Gas Dryer
Sears Kenmore 90 series dryer
If you have a gas dryer.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 17, 2010 | Dryers
Kenmore 70 Series Dryer not heating and not cutting off
I had an identical problem to yours this weekend with my Kenmore dryer. There were 2 problems.
1. Timer was broken. Does not advance to "OFF" position on timed dry, however it still works for auto-dry.
2. Thermal fuse was blown. Upon replacing, dryer heated up normally.
I believe when the timer broke, the dryer had kept running and blew the thermal fuse. On Sears' website, thermal fuse is $5.30, timer is roughly $80.
Kenmore 70 Series gas dryer, M# 110.76752500
Jan 01, 2010 | Dryers
Kenmore dryer- remove fan to change motor on dryer.Do I need a gear puller to remove ? 7 yr old 90 series dryer ,seal drum came lose from damage to dryer when purchased. Did not relize damage until motor...
The wheel has left handed threads. Use an impact wrench and an adjustable wrench to get it off or get a vice grips or pipe wrncha nd lock down the shaft then get a stick of wood or a hammer handle and shove it in between two fins at the 3 oclock position. Slam downwards on the wheel and it should pop loose.
Mar 22, 2009 | Kenmore 659 Electric Dryer
Kenmore 90 Series Dryer start button humms, but that's it.
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Mar 06, 2009 | Kenmore Dryers
Finding the year my dryer was made.
kenmore dryer serial # is MU 3636958. what year was it made
Jan 08, 2009 | Kenmore 75944 Gas Dryer
Kenmore Elite HE4 Electric Dryer Logo
463 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De GO PATS
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
