Question about Dryers
Turn dryer on and it starts to heat up and then the heat stops and within about 2-3 minutes will start to heat up and then the heating up stops.
  • 10,319 Answers
Clean out the exhaust vent tubing really good.. A moister sensor will detect any build up of lint and shut the heat off
Posted on Jun 03, 2010
  • 494 Answers
Typically, this is a symptom of a lint clogged vent or restricted air flow through an expandable, plastic or foil vent tube behind the dryer that is squished. First check your lint filter and clean it. With the filter removed, check the filter reservoir and see if there is a lot of lint that needs to be cleaned out. If not, then you will more than likely need to pull the dryer out to check the vent for blockage. Unplug the dryer and remove the vent from the back of the dryer. Using a flashlight, clean out or vacuum out the excess lint. Do the same for the vent tube you disconnected. Also check outside at the vent cap to make sure it is not blocked there and that good air flow allows the vent flap to open when the dryer is running. You can check this after you reassemble the vent inside and fire it off. Hope this helps solve your problem. Douglas
3 Suggested Answers
kdgrayson
  • 195 Answers
SOURCE: the dryer starts normally and begins to heat and
safety switch
Posted on Aug 23, 2009
KevinWhite
  • 1902 Answers
SOURCE: Frigidaire front load dryer problem:
Hello & Welcome to FixYa
If you have already tried cleaning the vent then the problem is with the Thermal fuse. When the thermal fuse goes bad it cannot be reset and replacing it is recommended repair. It is located on the blower wheel housing inside the rear panel to the exhaust duct. You can test it for continuity before replacing.Please get back to me if you have any other questions.
Kevin
Posted on Aug 05, 2011
Frigidaire dryer started loud knocking. A cpl weeks later knock stopped but it took 2-3 cycles to dry. Now it won't dry at all. What's a good place to start troubleshooting?
Hello Dondrake, thank you for your submission!
From the information you have provided your Frigidaire dryer was knocking and now it is no longer heating. This could be a potential problem within your heating element or control panel. I would suggest performing a reset on your dryer and you can do that by disconnecting the power cord from the dryer for at least ten minutes. I hope this information is helpful to your repair. -Matt
May 04, 2016 | Frigidaire Dryers
I have a Kenmore Elite HE3 model 11094834200 it heats up for about 5 minutes and than stops heating. I replaced the thermistor thinking that was the problem but it wasn't. If I try re starting t
Number 34 is the sensor strips located on the rear bulkhead inside the dryer. Clean them thoroughly with Windex or 409. Dryer sheets build a wax buffer on them sensors that moisture cannot penetrate. If no wetness is detected the control shuts her down thinking them clothes is did. Either that or you forgot to reconnect the sensor wire when puttin her back together Kimosabe.
Jul 10, 2012 | Kenmore Elite HE4 Electric Dryer
Gas dryer initially heats then heating stops
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Jul 15, 2010 | Whirlpool LGB6000KQ Gas Dryer
Have had a repair man out 3 times. Replaced igniter and gas regulator. Dryer will heat for a few minutes then stop heating. When I try to turn it back on, it will not turn on at all for about 10 minutes.
Are you saying the dryer will not start again after a few minutes? That is a motor [problem. Replace motor.
Are you saying dryer starts after a few minutes but will not heat? That is an air flow problem or a gas valve coil problem. Thoroughly clean EVERY single air passage in the dryer and vent tube. If that does not cure it, then replace gas valve coils if the igniter comes on and off.
Jul 02, 2010 | GE DCVH515GF Gas Dryer
Kenmore Dryer Mod. #110.68932792 Ser. MJ1907445 Dryer in heat cycle starts and runs 10 to 15 minutes then motor stops, after about 2 minutes motor starts back on it's own, operator doesn't have to do...
there is a motor relay in the consol part 3405281,there is also a heat relay too,you can swap em out to see if this is the problem, the one on right side with blue wires is the motor relay let me know how you make out
Nov 19, 2009 | Kenmore Dryers
Maytag atlantis gas dry is not heating up its about 6 years old
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Mar 28, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag MDG5500 - heat goes off after several minutes
Q - My gas dryer will not heat, what could stop my dryer from heating?
A - Things that could stop a gas dryer from heating:
- glow bar igniter, thermal fuse ( not all models ), coils on the gas valve, gas valve, thermostats,motor heat switch, timer, selector switch, sensor.
A page for checking gas dryers is here.
Mar 07, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Dryer heat shuts off after a few minutes.
replace the 2 black solenoids on the gas valve ..after heat up they sometimes will go bad and burner will not reignite even though the ignitor glows
Sep 23, 2008 | Dryers
Dryers Logo
126 people viewed this question
Top Dryers Experts
