Question about Brother XR-65t Mechanical Sewing Machine
Sews backwards and pressing the "reverse" tab doesn't do anything.
    Brigadier General:
  • 3,513 Answers
you will need to have it serviced, sounds like an internal issue with the dial .
Let us know if you want something more else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jun 03, 2010
  • Hap H Jun 03, 2010
    so the lever is connected to a "dial?"
  • Aparajita Batabyal
    Aparajita Batabyal Jun 03, 2010
    Sorry for the inconvinience. Since the problem is internal it was a bit confusing and difficult to answer it without seein the machine in question.
    However I am giving you a general view related about the problem in your machine.
    Hope it would serve the purpose.
    The reverse mechanism is stuck. The machine has to be completely disassembled to get to the problem. It is usually not a big deal to get it "unstuck" but taking it apart can be a pain. A good machine tech. can do it easily or you can give it a shot. Just look what the reverse lever actuates and see how it is stuck in the reverse position. It is usually the stitch length/reverse block.
How do I fix a serger that sews backwards?
move the sewing direction knob /lever to forward
Sep 27, 2016 | Sewing Machines
My machine sews backwards but when I press the reverse, it goes frontwards
The feed Dogs are being driven incorrectly. Inspect the mechanism on top and below to see if you can see anything that is off line or stuck. Try a fine lubricating oil on joints and cams. If nothing frees off or isn't obviously wrong. Then I would consider getting it serviced.
Jul 12, 2016 | Sewing Machines
Sews backwards..when I press the reverse button it sews forwards
Sounds like you have the timing precisely reversed. Time to try again.
Sep 10, 2012 | Singer CE-100 Futura Computerized Sewing...
My "new" elna type 722010 only sews in reverse.
What is the stitch length lever set to (4 in the diagram below)? these models have a lever that slides from positive to negative (ie) reverse, so you need to set it to the positive area, between 2 and 3 above zero. If you move it below zero then it sews that stitch length backwards.
If this machine is new to you, you might want to join the yahoo group called "Elna Heirlooms" there is lots of helpful members who share info on these old machines there.
Jul 15, 2011 | Elna Sewing Machines
My sewing machine is sewing backwards how to put it properly?
You've most likely accidentally hit the "reverse" stitch button, which sews in the opposite direction. The button will be marked by one of these symbols: grtartst_1.jpg
This symbol indicates the reverse stitch button. Just press this button and your machine should start sewing in the right direction!
May 18, 2011 | Euro-Pro Easy Sewlution 385 Mechanical...
My husqvarna classica 90 sews backward instead of forward. Can you help with an answer why?
Make sure the stitch selector is not set on buttonhole. If the machine has set up for a long time not being used it may be that the stitch length is stuck in reverse.
Apr 19, 2010 | Sewing Machines
Only sews backwards
You probably have it in the buttonhole stitch.
Mar 23, 2009 | Euro-Pro 9000 Mechanical Sewing Machine
Backward stitching
Knowing which kind of machine you have helps alot. Just guessing but maybe the reverse mechanism is stuck and needs some oil in it to free it up. Or the buttonhole mechanism is stuck in reverse part of it.
Probably you should have it looked at.
Dec 31, 2008 | Singer 3116 Simple
Brother XR-65t Mechanical Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
