Vertical Bar on JVC VM42WV74
Vertical bar full height of screen. Present most of the time but not always. Took it to repair shop and tech says it is a component that goes the full horizontal length of the screen but refuses to name component.
  • 4,234 Answers
A vertical bar can be caused by a number of things. A couple of possibilities:
1) Bad connection to panel at that vertical location.
2) Defective processing chip.
3) Bad panel
Any of the above could be the problem. Some experimentation and measurement would be necessary to determine the exact cause.
Dan
Posted on Apr 09, 2008
Vertical bar about 3/4" from top to bottom of monitor
panel is done. economical to repair. new panel is about 90 percent the cost of the tv new
Jun 03, 2009 | Fujitsu Plasmavision PDS-4233 42 in....
Vertical black bar across the screen
sounds like the screen settings are out, try changing the screen settings, not sure which button it is though i rarely play around with laptops
May 19, 2009 | Dell Latitude D800 Notebook
Intermittant vertical black bars on 42HP84
there is a good chance that I can solve your problem, although for me and others this problem usually shows itself as black bars that go from top to bottom, not just half way.  go to the following link and read the entire thread, it is very good info.  I have done this and it worked perfectly on a gateway plasma, but it also works on numerous others.  there is a guy on ebay that sells a fix for $80, and it appears to be exactly what i did.
http://www.avforums.com/forums/plasma-televisions/462873-black-line-fault-hyundai-hpt4240-fixed.html
enjoy!
stephen
Apr 03, 2009 | Toshiba 42HP84 42 in. Plasma HDTV
Dark Grey Vertical Bar
1. try connecting laptop to an external monitor and check if this vertical dark gray bar appears. if yes it means video is the problem. you need to boot in safe mode then uninstall the video driver. boot to notmal mode then download and install the latest video driver. if still same problem then replace video card. if video is built in with motherboard you need to replace motherboard.
2. when the vertical dark gray bar did not appear in the external monitor then it means issue is with the LCD panel. Do this turn off laptop. press and hold D key then press Power button at the same time or Press and hold on the Fn key then Power button check if the test will run. Color displays full screen when you keep pressing on N key when the colors appears check the vertical dark gray bar if still exist in the test, this means LCD panel and LCD cable needs to be replaced.
Oct 31, 2008 | Computers & Internet
Vertical bar on Daewoo Plasma screen
try this, can't hurt!
st
Sep 04, 2008 | Samsung HP-R4252 42 in. Plasma HDTV
Broad vertical bar appears on TV screen
You should send the set to the factory service rep, and not an independent TV service. They will need to have the boards to test the set. The independent service tech would have to buy the boards to test, and he would not have the factory setup to properly diagnose the set.
Your set is definately serviceable if the service tech is properly trained for your model type, and has the proper tools and spare parts to troubleshoot the set.
This fault can be in the main screen video processor board, or the address processor area, or the backplane processing area. Depending on the model, there can be a number of boards to cover these areas.
Once the defective board is determined, it can be swapped for a new one, and the factory level setups as required just have to be performed. The set should then be working properly.
Be prepaired that this type of service may be expensive. Some of these boards can cost a number of hundreds of dollars. They are not supported to be serviced at the component level.
Jerry G.
Jun 28, 2008 | Televison & Video
JVC AV-27870 TV Image Problem
Hi Bruce,
Sounds like you have shorted or open Vertical Filter Capacitors. ( you may also have a bad vertical drive chip now since you've waited to replace the capacitors). You'll need to replace the bad capacitor/s and if the problem doesn't go away, replace the chip also. And as always, check for any cold solder joints ( bad lead connections to the printed circuit board ) as you replace the bad components.
I Hope this has helped.
Ed
NC Electronics
Mills, Wyoming
Have a Great Presidents Day
Feb 17, 2008 | Televison & Video
ILo-26HD Tv
take your set to a tech you are having problem in your vertical output circuit.leaky filter or coupling capacitor,or defective B+ regulator transistor or IC .buffer transistor or IC,or supply resistor, they need to be replace.good luck
Mar 26, 2007 | iLO 2600 Television
White bar on top of screen
It only 1 bar in the middle horizontal? They Call it Vertical Line, sometime looseboard, defectiveVertical IC, Leak capacitor in vertical section. need a Repairman Tech.
Nov 19, 2006 | Sony FD Trinitron WEGA KV-20FS120 20" TV
Vertical black bar in the middle of the screen
GREEETING FROM bELIZE YOUR SET NEEDS TO BE TAKEN TO A QUALIFIED TECH IT IS HAVING A VERTICAL PROBLEM OR A PROBLEM IN THE POWER SUPP PROBABLY A FILTER IN THE POWER SUPPLY.GOOD LUCK.
Oct 27, 2006 | Samsung TXN3071WHF 30" TV
Televison & Video Logo
277 people viewed this question
Top Televison & Video Experts
