Question about Maytag MSD2756GES Side by Side Refrigerator
My refrigerator side has stopped cooling. Freezer
My Maytag #MSD2756GE refrigerator side has stopped cooling. Freezer side is fine. Any ideas as to what is wrong?
    Guru:
  • 1,524 Answers
Defrost problem.
Posted on Jun 03, 2010
My maytag MSD2756GE has just recently stopped cooling. The inside lights and the indicator lights in the water/ice dispensers are on, but the refrigeration has just completely stopped. There is no sound...
check the ptc overload on the compressor it may be bad or the temperature control can be bad also,you can jump the 2 wires to this control and see if the unit starts,then if so replace the control
Mar 22, 2011 | Maytag MSD2756GES Side by Side...
My frige is not cold, just cool, turn the T stat to coldest & no good. The freezer seems fine & I looked in the back & the fan is running. It doesn't seem to be blowing cold air or...
Two thoughts. If the fan is running... and you can here it in the freezer when it is on. Then the fan is fine and it is the mixer control. IF the fan is not working, then fix the fan.
The mixer control is in the top of the fridge where the air comes out on the wall between the fridge and freezer.
I think maytag calls this a cold control / damper.
Basically it controls the air flow rate between the fridge and freezer. When it is opens it allows air from the freezer into the fridge and cools it off.
Hope this helps.
Jun 17, 2010 | Maytag MSD2756G Side by Side Refrigerator
Maytag MZD2766GEW side by side refrigerator fridge not cooling
you have a defrost problem, could be bad adaptive defrost board,t-stat heater,when you open freezer door listen for fan if fan is blowing check the t-stat,look at it and see if it has a buldge on it,sometime you can see this and tell it's bad,you'll need a meter to read out the heater and other parts to see whats bad,might be a good idea to call a tech to do this,when you find problem you have to melt everything out again
Oct 31, 2009 | Maytag MSD2756G Side by Side Refrigerator
Side-by-side Maytag lost it's cool
Is there frost on the back wall of the freezer about 1 foot from the bottom ? If so , then a defrost problem . Either a bad adaptive timer (electronic board in control section ) , a bad bimetal (locatod on top of the freezer coils. A small cylinder with 2 wires on it ) or a bad defrost heater . Usually , the adaptive timer is the problem .
Jul 22, 2009 | Refrigerators
Maytag refrigerator side-by-side model MSD2756GE freezer is working fine, but refrigerator is not cooling. can not hear a fan blowing from freezer to refrigeration side.
remove the baskets and shelves in the freezer and remove the rear panels after shutting the fridge down. If you see heavy frost on the coils then the defrost model needs replaced. If not, check the that the fans runs, and then that the thermostat works and then that the damper that allows the air to the fridge compartment is opening correctly.
Jul 12, 2008 | Refrigerators
Maytag refirigerator not freezing/cooling
Turned out to be a bad circuit board on the back of the unit which caused the refrigerator/freezer to freeze up. Replace it, thawed the refrigerator compartment, and it works fine. Cost me less than $200 including service call.
Jun 22, 2008 | Refrigerators
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Maytag MSD2756GES Side by Side Refrigerator Logo
490 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
