Trying to replace the agitator on GE Profile washer model # WPSQ4160TAWW. How do I remove the agitator?
    President:
  • 949 Answers
The GE agitator is held on by a pressure fit (no screws). A couple things to try.
- Take a belt and put under the agitator as close to the center of it as possible, pull on the ends of the belt, be careful that your face is not right above the agitator, when it breaks loose it can pop you in the nose.
- There is a tool called an agitamer that can be bought at an appliance parts store but it runs about $25.00. you put it under the agitator and fill it with water to put pressure on it.
- This website has a homemade tool that works pretty good if you have this stuff around the house.
GE agitator stuck
- If all these fail a lot of pulling upward will eventually get it off.
Posted on Jun 03, 2010
Coin stuck in agitator. how is agitator removed
Normally you can take the top of the agitator off with the use of a screw driver or by turning couter clockwise. Once the top is off you should see a nut or bolt. Removing this will allow the agitator to be removed.
Nov 12, 2010 | GE Profile WPRE6100G Top Load Washer
Piece of cloth wrapped around and under the shaft of the agitator. Is there an easy way to remove the agitator and possibly pull out this cloth?
I don't know if this washer is very similar to a model wpre6150k2wt. My girlfriend had this very problem happen to her with her washer that is this model. The solution was very easy, I just unscrewed and took out the fabric softener dispenser. Doing this gave me access to a bolt that attaches the agitator to the gear that turns it. I then just unscrewed the bolt and removed the agitator. I hope this helps. Again if your washer is similar to ours it should.
Oct 20, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Washer does not agitate. Will spin and drain.
bad dogs pull off center cap remove bolt carefully lift off dogs are two pieces that catch to agitate they are minimal cost and are easy to replace they wear out especially with heavy loads!!!Best of Luck to You!!
Jun 28, 2009 | GE Profile WPRE6100G Top Load Washer
Washer will not agitate or spin
HI,
you can view this site to have some ideas about your agitator problem.
http://sites.google.com/site/sublimeappliancerepair/washer-will-not-spin/agitator-woes
any further question let me know.
thanks,
Mar 29, 2009 | GE Profile WPRE6100G Top Load Washer
GE profile washing machine won't agitate it spins out, drains,
Pull the agitator out and check the drive collar splines.If you have the model I think you have just pull straight up on the agitator. Once removed you will see the drive collar with a 7/16 head bolt,remove it and pull off the collar.First before pulling it off spin it if splines are stripped it will spin freely.
Mar 25, 2009 | GE Profile WPRE6100G Top Load Washer
GE Profile washer
suspect gearcase ask for estimate first..could be more than new washer
Jul 09, 2008 | Washing Machines
Washing Machines Logo
78 people viewed this question
Top Washing Machines Experts
