Question about Frigidaire GLTF2940ES Front Load Washer
Need motor control board - Frigidaire GLTF2940ES Front Load Washer
    President:
  • Frigidaire Master
  • 662 Answers
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Pl rate me.
Posted on Jun 03, 2010
What does F11 error message stand for on my Whirlpool awo 9565 washing machine?
The F11 fault code indicates a serial communication error between the Machine Control board and the Motor Control board. This can be caused by several different problems.
A failed Machine Control board could be failing to provide the Motor Control board with proper voltage. If this is causing the F11 code, then the Machine Control board would need to be replaced.
The Machine Control board could also be failing to supply proper voltage to the door lock assembly. The Machine Control board would need to be replaced for this failure as well.
Voltage flows from the Machine Control board to the Door Lock Assembly. The Door Lock then energizes and closes the Door Lock MAIN Switch. Voltage flows out of the Door Lock Main Switch to the Motor Control board. So if you have power into the Door Lock Assembly but not out of the Main Door Lock Switch, it will give you an F11. If so, you will need to replace the Door Lock Assembly.
You could have a bad Motor Control board that is causing this failure. A bad wiring connection between the Motor Control board and the Machine Control board could also cause this fault code. A bad wiring connection between the Motor Control board and the drive motor is also a possible failure. A failed drive motor could also cause the F11.
With so many possible causes for this failure, I recommend calling a service technician to diagnose and repair the problem in your washer. If you are able to unplug the washer and check the wiring connections, you may be able to find a loose wire harness connection that is causing the problem. Much of the diagnosis for the potential problems noted above requires live voltage checks. I do not recommend conducting these types of checks yourself. Unless you want to take a chance and replace the Machine Control board and the Door Lock Assembly,
Aug 15, 2014 | Whirlpool Washing Machines
Error codes 660 & 595, all functions perform, new motor from Icon, but motor will not go
please test the output voltage from control board motor, for voltage measure in terminal motor, if there are NOT voltage in output the control board is faulty.
2) Test if there are voltage terminal motor, if there are the motor need to be test. Loose the belt and try again. and if the motor RUn YOU need to LUBE the deck belt board.
Oct 15, 2013 | Nordic Track Nordictrack C2050 Treadmill...
Error code 660 & 595
test the output control board motor, if there are NOT voltage for to input voltage terminal motor, the control board is faulty, replace.
2) If there are voltage terminal motor, the motor need to test, take out the belt, and try again if the motor RUN the problem is deck belt board, LubE IT. see my personal TIPS for motor.
What does F06 mean?
F06 error code indicates a motor tachometer failure on most Kenmore Elite front load washers. There are many different models, so I would need the model number of your washer to be sure.
This type of problem could be caused by loose wiring connections between the motor and the motor control board. It could also be caused by loose wiring connections between the motor control board and the main machine control board. Other problems that could cause this fault code include:
A failed drive motor.
A defective motor control board.
A failed main machine control board.
Hope thie helps (remember to rate and comment this answer)
Jul 02, 2011 | Kenmore Elite 45986 Front Load Washer
MC2100 control board won't power on. Is it possible to test this board?
hi,
the regular complaint comes in treadmill motor controlling card is igbt fault. igbt will be fitted on the heatsink replace the same. also check the related driver transistors in its gate rail. instead of motor u can connect a bulb for testing board. u need the controlling circuit also to test the motor controlling card. because motor on ,off, speed controls commads are cumming from control circuit.
ok
Dec 22, 2010 | Nordic Track Mc2100wa Treadmill Motor...
Dryers stops after 30 seconds of running.
#5 post_old.gif September 24th, 2009, 08:49 AM jake.gif?dateline=1263924303 Jake user_offline.gif Appliance Tech - Admin Join Date: Aug 2004 Location: Springfield, Oregon Posts: 32,822 Thanks: 48 Thanked 1,244 Times in 1,238 Posts reputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_pos.gifreputation_highpos.gifreputation_highpos.gifreputation_highpos.gif icon1.gif So you need the motor control board #17 here?
http://c.searspartsdirect.com/lis_pn...2059-00001.png
Here's the motor control board for your model:
Manufacturer's Number: 8544799
Jun 30, 2010 | Kenmore Elite Oasis 7808 Gas Dryer
New motor or control board?
you need to locate the tech spec sheet under the top cover and run the troubleshooting tips to determine which is the problem,in my own opinion i will say its the control board more likely than the motor due to the nature of the 3phase pulse operated motor that gets its power from the control board
Mar 18, 2010 | Frigidaire ATF6000ES Front Load Washer
My washer has a f1 code will not spin or wash
OK, your unit is quite unique. this unit has a integrated control design that houses the main and motor control board. both are combined on the same board. this error code represents a failed Machine and motor control board. this single control board works as the main controller and, as the motor controller as well. This board has failed in your unit and, you will need to replace this board asap if possible.
May 30, 2009 | Whirlpool WTW6400SW Cabrio Washer
The tub that holds the clothes does not spin. The water goes in and it takethe soap and softner but will not spin. The timer works and it seems to go through the cycles and fillls and emptys but the tub...
I've only seen one of these belts break in my 7 years of fixing Neptune's. I have replaced dozens of motor/ motor control board kits. Maytag upgraded the washer motors about 5 years ago, if yours is older it's probably got the older style motor. If that's the case you need to verify that the motor control board is getting power from the main control board, if it is, then you need to replace both the motor and motor control board (it comes as a kit). If it isn't you need to put 120 volts to the motor control board and see if the motor spins at 50 rpm (normal agitate speed), if it does, you just need the main control board, if it still doesn't run you need the main board and the motor/ motor control kit. If it has the newer motor, you would also need to test and replace the motor and/ or the motor control board separetly.
Jul 15, 2008 | Maytag Neptune MAH5500B Front Load Washer
Maytag washer issues
Could be just about anything. It's all designed to prevent it from spinning if there is a problem. If the motor is still turning, but never gets up to spin speed, check the out of balance circuit. There are two cabinet strike switches and an inertial unbalance switch. Or check the door latch assembly, it's possible for the door to lock enough to turn the 'door lock' light on, but not move far enough to actuate the 'spin enable' switch. Maytag has upgraded the motor/ motor control board for the older Neptunes. If the motor is not running at all, check that the main control board is sending power to the motor control board. If it is you need the motor/ motor control kit (just one part #) If the main board is not sending power to the motor control board, you need a main control board, but you still need to test the motor control board. Take a test cord and put 120 volts to the motor control board, the motor should start turning at 50 rpm (normal agitate speed) if it doesn't you would need the motor/ motor control kit as well.
Jul 06, 2008 | Maytag Neptune MAH5500B Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
55 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
