Using it as an external device, and icons will not show
I am using my monitor on my laptop, but when i turn it on the icons do not appear on my desktop. what could be the problem?
    Problem Solver:
  • 13 Answers
Are you able to drag any window to external monitor? If yes, it means that external monitor is not cloning your desktop, but extending it instead. You can set up cloning using your video driver, procedure is different for different video cards.
Posted on Jun 03, 2010
Need both laptop and monitor on at same time.
Hey Roger,
Below is information that should help you with trying to get monitor and notebook screen to work.
First make sure your laptop is equipped to be able to connect a secondary display, there should be a port for connecting a standard monitor cable on the back.
Connect your secondary monitor and reboot the laptop, the system bios should recognize that a second monitor has been added.
Then right click on your desktop and bring up the display properties dialog box.
Select "settings"
Your laptop should be identified as monitor 1 and you should also be able to see the secondary monitor as monitor 2.
Click on the secondary monitor and check the box that says "Extend my Windows desktop onto this monitor".
Set your screen resolution and color quality for the second monitor and click apply.
Directing icons and browser windows over to the other monitor is just a matter of drag and drop.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Apr 11, 2014 | Dell Latitude D600 Notebook
I tried to clean the dell vostro 1014 fan, after i assembled the fan and turned on the laptop it appear black screen with dim image on my laptop screen, When I plug in external monitor it shows boot s
It sounsd like your GPU may be BGA chip and would require a re-flow/re-ball if your laptop shows graphical distortion on both monitors.
However I would first try taking the laptop apart again and double check you have connected everything properly.
Mar 20, 2014 | Dell Vostro 1014 Laptop Computer
Unlock password
How about looking at a screen?
Use an external monitor
Briefly;
Your laptop has an external display device port. (Connector)
I do not know what it is, because you didn't state the laptop manufacturer name, and model number; Elizabeth
It may be a VGA port, or HDMI port, or Mini-HDMI port; or DVI port
http://en.wikipedia.org/wiki/VGA_Connector
(Scroll down for VGA Cable example)
http://en.wikipedia.org/wiki/HDMI
(You can click on any photo, and it will enlarge)
http://en.wikipedia.org/wiki/File:HDMI_Connector.jpg
http://en.wikipedia.org/wiki/Digital_Visual_Interface
Laptop OFF, monitor OFF, connect the external display device to the laptop.
(VGA = Monitor. DVI = Monitor. HDMI, and Mini-HDMI usually = HDTV. They all compromise an external display device)
Turn the monitor/HDTV on.
Turn the laptop on.
By factory default settings, the display should show on the external display device.
IF not;
There are at least 3 display options. For this example I'm going to use a VGA monitor.
(For a VGA monitor you can use a CRT type of monitor. Looks like a small TV. Or you can use a flat LCD screen monitor, if it has a VGA Cable attached)
The basic 3 display options using a VGA monitor are;
1) Internal monitor of laptop ONLY
2) Internal monitor of laptop AND external VGA monitor
3) External VGA monitor ONLY
Hold the Fn key down, and at the SAME time tap once on the Display Toggle-Over key.
Which key is that? Dunno. Laptop manufacturer name, and ......................
It will be one of the F keys at the top. F1 through F12.
The Function key will have a monitor icon on it, and usually an arrow on one side........Or perhaps two monitor icons sitting side by side.
(Empty rectangle is a monitor icon)
Still no display on external display device?
Hold the Fn key down again, and tap once more on the Display Toggle-Over key
[If memory serves for Display Toggle-Over key;
HP = F4
Acer = F5
Toshiba = F5
IBM/Lenovo = F8
Don't write that in stone, however.......]
Once you post the manufacturer name, and model number; then I can guide you step by step.
Post back in a Comment.
Regards,
joecoolvette
Apr 25, 2013 | Computers & Internet
ASUS K50AF no post
If the laptop boots up all the way and you don't see an image on the lcd screen or on the external monitor then the video card inside the computer is bad.
Shine a flashlight on the dark screen to see if you barely see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be any kind of monitor even the old big fat crt monitors as long as it has a vga cable to connect to your computer's vga port. If the video shows on the external monitor that proves your video card is ok, ,but your lcd screen is bad. The video will show on most systems when you reboot without you having to do anything. Some systems will require you to hit the FN (Function key) + F1 thru F12. Hold down the FN key then hit the correct key for displaying on the monitor (F1 thru F12). The correct key will normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works, then your screen is bad. If you see no icons by shinning the flash light and nothing shows on the external monitor, then most likely your video card is bad.
Jun 07, 2012 | ASUS K50AF Notebook
Laptop turns on but screen doesn't show
Shine a flashlight on the dark screen to see if you barelysee the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can beany kind of monitor even the old big fat crt monitors as long as it has a vgacable to connect to your computer's vga port. If so that proves yourvideo card is ok. The video will show on most systems when you rebootwithout you having to do anything. Some systems will require you to hit the FN(Function key) + F1 thru F12. Hold down the FN key then hit the correctkey for displaying on the monitor (F1 thru F12). The correct key willnormally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,then your screen is bad. If you see no icons by shinning the flash lightand nothing shows on the external monitor, then most likely your video card isbad.
May 07, 2012 | Acer Computers & Internet
Why does Sony laptop screen stays black when booting?
Mar 31, 2012 | Computers & Internet
Desktop icons stretched horizontally
Sounds like you need to set the screen resolution for the monitor. The computer should recognize each screen individually in the desktop options dialog. If it doesn't recognize the two different screens, you may want to change the resolution when you plug in the monitor.
May 14, 2017 | Computers & Internet
My icon for the battery power monitor has dissapeared from my taskbar can you help me get it back please
Do you have Windows 7? If so, you can right-click on the bottom right corner of your desktop (try right-clicking the time/date), where the icons for volume control, wireless, battery, etc... should be and select Properties. You should then see a screen where you can turn on/off the icons/notifications for battery power (sometimes my volume control disappears and i have to do this.
Otherwise you can go here, Control Panel\All Control Panel Items\Notification Area Icons and you should find the same thing. Then just turn on your battery power icon/notifications.
Hope this helps.
May 22, 2011 | Acer Computers & Internet
Is it possible for me to remover the on board screen of my laptop(MX 6956) in order to use the keyboard and HD with an external monitor?
You don't need to remove the LCD screen.
1) Laptop off connect the external monitor's VGA cable, to the VGA port (Connector) on the back of the laptop.
The VGA port looks like this,
http://en.wikipedia.org/wiki/File:SVGA_port.jpg
2) Turn on the laptop.
3) Plug the external monitor into power. Windows will recognize it as an new hardware device.
Windows will search through it's database of Drivers, and match one up.
However, if you have the installation disk that comes with the monitor, install it now.
Load the software.
(The monitor's Installation Disk (CD) has the proper drivers. It will set the resolution settings at the correct resolution for the monitor. If you do not have the Installation Disk, download the drivers from the monitor's manufacturer website)
4) Once the drivers are installed immediately Right-click on an empty area of your desktop screen.
Left-click on Properties.
5) Now Left-click on the Settings tab.
6) You will see two rectangular shaped icons. One icon has a 1 in it, the other icon has a 2 in it.
The icon with a 1 in it represents your Primary monitor.
The laptop's LCD screen.
The icon with a 2 in it represents your Secondary monitor.
The external monitor you just hooked up.
Right-click on the 2 icon, then left-click on Attached.
Go to the bottom Right, and left-click on Apply.
Now go to the bottom Left, and left-click on OK.
Oct 21, 2010 | Computers & Internet
Yea i have a gateway 450sx4 laptop and when i turn it on it stays black for a while and when the screen finally turns on it blurry and its different colors and it just shows lines how can i fix this?
It's likely that your screen is "fried" (faulty) ... try to connect your laptop to an external VGA monitor, and see if the screen shows up (on the external monitor) properly. You may have to toggle the output display (device) from computer screen to external monitor ..using Fn+F3.
If it displays on your external monitor properly, it means your laptop screen is no good. You can replace the laptop screen, or just continue to use the external monitor.
If it does the same (blurry & different color, etc.) on your external monitor, then, your video card/module on your laptop is bad. This usually happens less often.
Aug 11, 2010 | Gateway 450SX4 Notebook
Computers & Internet Logo
27 people viewed this question
David Payne
David Payne
