Question about Frigidaire Washing Machines
I have a Kenmore/Frigidaire 41744142300 Front load washer, the cheap one with the mechanical timer push pull type knob. It goes all the way through the cycle and the final spin, but it never stops. it will spin forever if I don,t shut it off. I has to be the timer sticking right?
  • jedhaft Jun 03, 2010
    GREAT,FAST ADVISE. THANKS
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. Yes, you are right. If the washer won’t complete the cycle i.e. if it will fill, wash, drain, spin but the timer won’t advance then it is the Timer that should be replaced
. Please check this link for its parts. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 03, 2010
    Thats what I thought, but is it possible that the motor control is not suppling voltage to the timer to make it advance?
  • Rylee Smith
    Rylee Smith Jun 03, 2010
    As I said if the motor control would not have been supplying the voltage then the timer wont even advance after filling the water. Usually in that case the water just fills and drains out and the timer wont even start the cycle, so thats why I think it is the timer.
WHAT HAPPENS IF A TIMER IS OUT ON KENMORE WASHER
you push the timer in and turn it to the setting you want,when you pull the timer knob out the washer should run
Jun 20, 2014 | Kenmore 24032\24036 Top Load Washer
Kenmore front loader stops/freezes in pump out mode just before final spin
For a detailed Washing Machine illustration, click below.
redarrow.gif Top Load Maytag Style
redarrow.gif Top Load Whirlpool Style
redarrow.gif Top Load GE Style
redarrow.gif Front Load Maytag Style
redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Warning! To avoid personal injury or even death, always disconnect your appliance from its power source--that is, unplug it or break the connection at the circuit breaker or fuse box--before you do any troubleshooting or repair work on your appliance. Also, because some components may have sharp edges, use caution while working on your appliance.
Some problems that can occur with your top-loading washing machine are:
There's an error code on the digital display
It doesn't work at all
It won't drain
It doesn't spin
It doesn't agitate
It's noisy
It leaks
It's off balance
There's no hot water
There's no cold water
It's slow to fill
There's no water at all
The clothes are wet after spinning
The cycle doesn't advance
There's no delicate or regular spin or agitate
It's overfilling
It's underfilling
The water temperature is incorrect
Aug 01, 2008 | Frigidaire GLTF2940ES Front Load Washer
How can I remove the timer knob from a Frigidaire Washer
Knob PN 131592001 Just looking at replacements it appears to just push on. If pulling on it does not get it off then rotate it CCW in an attempt to unscrew it. Just be VERY careful that the timer stem does not rotate if you turn the knob CCW or you will be buying a new timer. Open the top and hold the stem if you have too. (easier said than done) Worst case... if you have a bad knob and have a replacement knob in hand... break the defective knob. If your changing the timer look at the stem on the new timer. If it is threaded on the end the knob unscrews. If it is not threaded it pulls off.
Kelly
May 11, 2011 | Frigidaire FWS833A Top Load Washer
Model: 110.29822800 Cycle Control knob seems loose. When turn knob clockwise and pull knob, it seems like out of position. For example, I set at Normal, rinse and pull knob. It rinse a minute or two and...
Could be one of two things. The knob or the timer. Both knobs and the timer through sears parts direct are under 100 probably with shipping. If the knob that you pull out and push in does not feel sloppy when you turn it then i would guess timer is faulty.
Feb 27, 2011 | Kenmore 24032\24036 Top Load Washer
Where is the ON button?
Pull the timer knob out to start, or push the knob in on some models. Good luck Appliance Specialist
Dec 16, 2010 | Frigidaire ATF6000ES Front Load Washer
How do you pull out the timer to a model # 110.26852501
First, see the Sears parts site for your washer.
http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11026852501/0582/0153200?pathTaken=
Then see the following Whirlpool / Kenmore Service Manual for top load, direct drive washers:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
Also see the following for how to release the console.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=bd565b63d8f8c39014f7aa79d1722163
Depending on the type of timer that you have (See the Whirl[pool manual) you may need to hold the shaft that goes through the timer to the knob with a thin needle nosed pliers in order to un-screw the knob before unbolting the timer.
Nov 12, 2010 | Kenmore Washing Machines
Older style kenmore top load washer wont do anything....
This machine has an on/off switch built into the timer that is activated when you push/pull the knob.
Either something therein is worn or broken causing this switch to not function. I myself could probably fix this problem and have done so on occasion, but an inexperienced person might find it to be a challenge.
Replacing this timer is expensive unless you can find a used part somewhere.
Jul 23, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore Washer, Loose Timer Knob
There should be a spring clip that holds the timer knob on. It or the timer knob may need replaced. Here is a picture of the timer knob and the spring clip. Sure hope this helps and best wishes.
Jul 23, 2009 | GE WBSR3140DW Top Load Washer
How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Mar 02, 2009 | Kenmore 24032\24036 Top Load Washer
I can't get the timer switch off
on the inside of the timer switch hold the shaft that the Knob is on with a pair of needle nose pliers and pull the knob from the front. " Gently"
Dec 03, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
111 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
