Question about HP Compaq Presario V2000 Notebook
My HP Compaq Presario V2000 PC Notebook start and stay's on the windows xp splash screen. I have tried loading it in safe mode and last good config but none works.
  • 748 Answers
Hi
Of course without seeing it I can't make an exact diagnosis. My first though is that you have a bad sector on the hard drive which keeps Windows from loading because the head can't recover data under the bad sector. Slave this hard drive to a good one and back up the data. Download a copy of hdtune.exe. You can confirm the status of the hard drive with this. If you find bad sectors - replace the drive
Posted on Jun 03, 2010
I want to remove win7 from my compaq cq57 laptop (intel core) and replace it with xp pro
In your case try the RAM part 1st.
Blue Screen Of Death
  • You may need to roll back system with System Restore (press F8 during boot and choose safe mode).
  • Uninstall last program(s) that was installed, again in safe mode.
  • Re-install Windows. Clean install works best.
  • Test one DIMM at time. One slot at a time. To eliminate possible bad RAM.
  • Lastly you may have other hardware problems. If it does another blue screen after reloading windows, especially with a clean install.
Oct 01, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
Compaq Pressario V2000
If you know how ?reset the memory and restart the computer
at the boot press F8 if the menu appears try last known good confiuration that worked if this does not work you need to format and reinstall the os the blue screen is and indication of driver failuer or hardware conflick and if the system.last good config will only work 1 time after that it will wipe out the os and you will have to restore from the restore disk,and the best way to do that is to reformat the drive and do a clean install ,but if you have windows there is a restore mode your disk will say press F2 to restore now
Mar 28, 2009 | HP Compaq Presario V2000 Notebook
My Compaq Presario V2000 will not start.
Ok, this makes sense. If this was a legit dvd, then it most likely had extra content on it (like wallpaper, sounds, etc) that installed something that crashed a driver.  If it wasn't legit, then the "player" that was used to play the movie installed something that crashed a driver.
If you can. I would reinstall some drivers to start.  Have you tried the "Last known good configuration" option?
Then if reinstalling drivers doesn't work, I would just restore the Windows OS.  But remember to BACKUP YOUR FILES.....once you restore it will be erased.
That compaq is a good machine unless you really want another PC this is fixable.
Feb 15, 2009 | HP Compaq Presario V2000 Notebook
Windows XP is not starting.
your operating system may have been corrupted , try 2 go 2 safe mode if you can and restore your computer at earlier time by system restore. if this doesnt solve your problem you can repair it using your installer.
Jan 27, 2009 | HP Compaq Presario C500t Notebook
I have a compaq prsario v2000 laptop that won't get past the windows start up screen.
Try booting the computer in SAFE MODE and if that works click on a few program to see if running OK the reboot
Jan 22, 2009 | HP Compaq Presario V2000 Notebook
Screen goes blank after windows loads
Hi there
If you tried in safe mode and still no joy you will have to perform a system recovery with the recovery disk you got with the laptop or the recovery partition, Please be aware that you will loose data.
Good luck
Jan 19, 2009 | HP Compaq Presario V2000 Notebook
I want to install xp on existing vista,also wanted to remove vista on hp dv2000 labtop
If Vista it is working well on Safe Mode, you have to check it out what is going wrong there instead of downgrade the system to XP.
Remember: Which was the last program that you've installed?
When was the last time that the system started normally?
You can try uninstalling the last programs
Also clean the computer and be sure that your pc is not virus or spyware infected.
Nov 07, 2008 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 boot problem
Bios is not on an hard drive, is on a memory chipinside computer. Your main problem is not with Bios, but with system.
On many Compaq you can start the recovery tool by pressing f10 or f11 on startup. The system recovery tool it is located on hard disk, if it does not start it had been deleted or is damaged.
In your case Windows is corrupted, that is the reason why it is freezing , and then giving the blue error screen.
You need to get a Windows setup disk and reintall Windows. If you install windows from a generic setup disk you will need to install drivers after installing.
Drivers can be downloaded from HP website.
Another solution is calling the phone number listed on the user manual to contact HP. you can buy from them an original recovery CD, in this case you won't need drivers.
Otherwise you can ask a quote to a local repair shop for a system reinstall, I think it is about $80.
Sep 02, 2008 | HP Compaq Presario V2000 Notebook
No screen after Boot
Try booting to the safe mode (f8) and see if there is any difference. If there is no difference, the video adapter is most likely failing.
If you can boot into the safe mode, then reboot and try the vga mode on the same menu, if you can boot to the desktop, then try to increase the resolution. if it fails, try a new video driver.
Jun 01, 2008 | HP Compaq Presario V2000 Notebook
Windows XP fails to load and Computer will not start up.
Boot from startup floppy disks or CD-ROM, choose repair option during setup, and run Recovery Console. When you are logged on, you can run FIXMBR command to fix master boot record. This should solve your problem.
Sep 20, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario V2000 Notebook Logo
76 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
