Question about Brother MFC 210C All-In-One InkJet Printer
Dma How can i turn on the dma?...
  • 813 Answers
Hi friend
here is link 4 u see how to enable it
Posted on Apr 09, 2008
Tip
Turn Direct Memory Access (DMA) on or off You must be logged on as an...
You must be logged on as an administrator to perform these steps.
is usually turned on by default for devices such as CD or DVD drives that support DMA. However, you might need to turn on DMA manually if the device was improperly installed or if a system error occurred.
  1. Click to open Device Manager. If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
  2. Double-click IDE ATA/ATAPI controllers.
  3. Under IDE ATA/ATAPI controllers, for each item that has the word Channel as part of its label, right-click the item, and then click Properties.
  4. Click the Advanced Settings tab. Under Device Properties, select or clear the Enable DMA check box, and then click OK.
on Dec 14, 2010 | Computers & Internet
It is very slow, is not in DMA mode
if you have xp :device manager-ide ata/atapi controller-select your hdd controller-properties-advance sttings-see if are dma available, if not set it.
Apr 19, 2010 | Samsung SpinPoint P80 SP0802N 80 GB Hard...
Dma 2100 wont connect to computer or router
Hi
Did you install DMa software in your machine ? if you did and is not working .Try this install windows 7,8 and it will pick the signal
May 18, 2017 | Linksys DMA 2100 Media Center Extender...
How do you change dma for xp to default
1.
Open Device Manager.
2.
Double-click IDE ATA/ATAPI Controllers to display the list of controllers and channels.
3.
Right-click the icon for the channel to which the device is connected, select Properties, and then click the Advanced Settings tab.
4.
In the Current Transfer Mode drop-down box, select DMA if Available if the current setting is "PIO Only."
If the drop-down box already shows "DMA if Available" but the current transfer mode is PIO, then the user must toggle the settings. That is:
• Change the selection from "DMA if available" to PIO only, and click OK.
• Then repeat the steps above to change the selection to DMA if Available.
Sep 23, 2009 | Microsoft Windows XP Home Edition
Micro star mainboard ms-6163
Hi
MS-6163 Pro Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports up to Ultra DMA 33 operation mode.
MS-6163 Pro - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=340&maincat_no=1
**** Other MS-6163 ****
MS-6163FC Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163FC - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=341&maincat_no=1
MS-6163VA - Systemboard IDE controller utilises VIA VT82C596B Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-6163VA - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=342&maincat_no=1
MS-BX Master Systemboard IDE controller utilises Intel 82371EB PCI Chipset and supports Ultra DMA DMA 33/66 operation modes.
MS-BX Master - http://www.msicomputer.co.uk/index.php?func=proddesc&prod_no=319&maincat_no=1
Regards
Mike
Mar 27, 2008 | MSI MS-6163 Pro Motherboard
DMA drive error.
Its a problem with the windows dma seting for drives. In "device manager", open properties for ur drive and your interface like IDE/ATA controller. There, you can check and change DMA Settings.
Allow max DMA. Do not disable DMA.
U can also check DMA setting on BIOS if ur bios supports it.
Feb 19, 2008 | Computers & Internet
Dma
DMA is Direct Memory Access : http://en.wikipedia.org/wiki/Direct_memory_access
It should be automatically enabled, but if it is not there will be no damage. DMA simply speeds up access.
Dec 22, 2007 | Intel D101GGC Motherboard
Want to know applications of DMA in real time
Good Morning
IT it a little "brige" to some sound aplications or routing signal to Printers or Sound Cards, but not for Network. Not good sometimes for Sound Cards, but you can play sometimes with settings and see what happend, you always can go back the DMA at previuos state, or simple, disable.
Carl
Nov 17, 2007 | Linare Desktop, AMD Sempron 2200,40 GB HDD...
Audio and video track are not in sync
I guess that your CDROM Device doesn't have DMA (Direct Memory Access) enabled.
From the Microsoft Knowledge Base Article:
To enable DMA mode using the Device Manager
1.
2.
3.
4.
Oct 14, 2007 | Computers & Internet
Brother MFC 210C All-In-One InkJet Printer Logo
22 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
