Question about Char-Broil Grilling
Burner flames low. grill does not heat up
My charbroil performance series grill burner flames are very low even when turned up all the way. Tank is known full/good (used without problem on another grill).
  • 784 Answers
SOURCE: SEVERAL DAYS AGO,THE GRILL GREASE CAUGHT FIRE,TEMP
The regulator is damaged. This is the little round between the hose connected to your knob adjustment and the Gas tank. This one is not expensive. it costs less than 30 bucks. Good Luck.
Posted on Jul 06, 2009
Treefrog15
  • 127 Answers
SOURCE: low flame on burner...
Remove the burner and check the flexible tubes for kinks or blockages. The flexible tubes usually just slip over the backs of the valves. Spiders love to get in there and block them. Also check that the holes in the burners are not clogged. Be careful when reseating the flexible tubes to be sure that they are properly seated on the back of the valves. Failure to properly seat the flexible tubes can cause leakage there, and the gas can ignite at the back of the valves and not reach the burner. Be certain that the replacement burner is designed to use with your grill and the flexible tubes mate properly with the back of the valves.
Posted on Jul 07, 2009
  • 10865 Answers
SOURCE: Grill lights but flame is low
Hello. Are you frustrated because your gas grill doesn't get hot enough lately. The problem you are having indicates that you have to go through a procedure called "RESETTING THE REGULATOR". Follow these easy steps:
1. Turn the burners on for one full minute and then off.
2. Next, remove the regulator and the hose from the tank.
3. Then reconnect the tank to the regulator and hose.
4. And very slowly open the tank.
5. Last step is to fire up the burners and start cooking with you new hot flame.
The problem began the first time you opened the valve on the tank too quickly. In the future, always turn the tank valve on s-l-o-w-l-y to prevent this problem.. Joe
Posted on Mar 22, 2010
  • 2517 Answers
chech the reg is giving right pressure
Posted on May 16, 2010
  • 2517 Answers
SOURCE: Low flame burning on CharmGlow 4-burner gas grill,
check burners are not bolcked check orffice is not blocked also check reg is giving right pressure
Posted on May 17, 2010
Side burner lights but not main burner on gas grill
If you smell gas, don't attempt to light the burner. Instead, turn the gas off and inspect the fuel tank, lines and burners once the smell of has has cleared. Always grill where you have adequate ventilation and perform all repairs only after the grill has fully cooled from use.
home lights
Jun 07, 2012 | Char-Broil CharBroil Master Flame Gas...
I had my charbroil grill for 2 yrs and I now when I turn on the propane tank and ignite, I hear hissing followed by it lighting then flames proceed to come out the front middle burners. Do I need a new...
Before buying anything, look into the burners for spider webs. The webs block gas from getting to the burner and will fire back. This is dangerous. Look carefully where the gas nozzle enters the burner tube.
Gary
Sep 04, 2011 | Char-Broil CharBroil Master Flame Gas...
I cleaned my grill to try and solve this problem. I blew out the burner and there's no debris in it. I put everything back and connected to the propane. I still only get a flame that is on low. ...
To get a high flame, do the following:
Be sure you have adequate gas in the tank to maintain combustion. If that checks out OK, start with step # 1.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling!! Thanks for choosing FixYa.
Aug 09, 2011 | Char-Broil CharBroil 4637318 Grill
The burners will not light. It appears that they are no getting any propane from the tank. Unfortunately, I have missed the manuel and this is a brand new grill. First time trying to use it and have...
The problem is more than likely the OPD Valve in the gas tank. To solve this problem, turn the Tank Valve OFF and disconnect the hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the tank valve ON VERY,VERY SLOWLY (Slow motion, slow). Once it's fully open, light the burner farthest from the tank first and turn it to it's highest setting. Does the flame height look correct? If so, light the remaining burners following the same procedure. Now, to all the flame heights look correct? If so, you solved the problem. Just remember to always turn the tank valve ON very, very slowly. If it didn't solve the problem, make sure you have adequate gas in "old propane tank from the other grill."
To further help you, I have included a link to your Owner's Manual that you can download and print for future reference. http://www.charbroil.com/bps/char-broil/char-broil/knowledge/463247310%20english.pdf
In addition, here is a link to Troubleshooting Gas grills
http://www.charbroil.com/Support/Troubleshooting_Level2/4/Gas-Grills.aspx?Model=463247310
I really hope all of this information has helped you solve the problem. Please let me know and Happy Grilling.
May 22, 2011 | Char-Broil Grilling
I just purchased a brand new tank of propane and i still have the same problem that the propane burns out of all 4 burners but at a really low flame even on high. I can not get the grill to heat up...
Turn the tank off. Disconnect the grill hose from the tank. Wait 5 minutes and reconnect the hose to the tank. Turn the LP tank valve on VERY, VERY SLOWLY until it's fully open. Now, light each burner one at a time and turn it up to the highest setting. If that didn't solve the problem, repeat the previously listed steps.
If after the second attempt the burners still only maintain a low flame, you will need to replace the grill hose/regulator.
Hope this solved your problem and Happy Grilling!
Feb 27, 2011 | Brinkmann Charmglow Stainless Steel LP...
I have a gas grill that has set for about two years and now it has a low flame when gas is set to high. Is it the burner or the regulator
I shut off the gas at the tank and grill. Removed the regulator from the tank and turned on the knobs on the grill for one minute. Then turned off the grill reconnected the gas line to the tank and opened the tank knob slowly.
Oct 31, 2009 | Char-Broil CharBroil Master Flame Gas...
I have a charbroil, advantage series grill. It isn't lighting.
How rusted are the burners? It is possible there is rusted metal blocking the gas ports. I don't have enough information from you regarding the problem...do you hear the gas flowing when you turn the burner open and the gas bottle is open?
Go to your user's manual, there should be an illustrated parts list. From there you can order new burners...you can also do this at Char-Broil's website.
Burner replacement is easy: take the grills out, then remove the flame tamers (the tent looking thing that sits over the burner to prevent flame-ups), the burners are screwed in to the grill at the back, remove the screws then grab the burner, pull towards the back of the grill and then up...this will disengage it from the gas valve in the front of the grill. Putting in a new one is the exact revers of this procedure...just make sure when you put the new ones in you make sure the burner's gas intake is connected to the valve at the front of the grill. Once done, you should be good to go.
Sep 07, 2009 | Grilling
Flames only come out very low on both sides
disconnect tank, hook tank back up, then open valve slowly. When opened to fast it thinks valve is leaking and shuts down.
Jun 11, 2009 | Char-Broil CharBroil Master Flame Gas...
Charbroil master flame gas grill the flame is either very high or very low
How old is the grill? The size of the holes in the burner is critical. As burners age, the holes rot out, and get bigger. The velocity of the gas exiting the holes has a large effect on flame size. New burner is the most typical solution.
Mar 08, 2009 | Char-Broil CharBroil Master Flame Gas...
Grilling Logo
81 people viewed this question
Top Char-Broil Grilling Experts
paulcarew
Gary Kenady
Gary Kenady
Dean Gruber
Are you a Char-Broil Grilling Expert? Answer questions, earn points and help others
