Question about Acer AX3810B3801A Aspire Mini PC Bundle with 20 LCD Monitor PC Desktop
Hi experts, item : LCD monitor of acer aspire 4050 - 300512 issue : LCD monitor of the laptop suddenly went out. CPU still running. Last night was ok, after boot on the next morning, the LCD didnt display anything. Any way i can trouble shoot this? Thanks.
  • jen_nashadi Jun 03, 2010
    Hi experts,
    appreciate your comment too, on the issue above? thanks.
  • jen_nashadi Jun 04, 2010
    thanks guys!
    President:
  • 4,070 Answers
Hi! If the LCD monitor doesnt show any display, the fault will be on the ribbon. You will need to have the ribbon replaced. Once replaced you'll be good. Hope this helps and have a good one!
Posted on Jun 03, 2010
    Brigadier General:
  • 3,513 Answers
There can be three possible causes:
1.your wire connecting moniter and host is lost.
2.your graphics is very hot
3.your memory has some problem needed a further check!
It is suggested to power off for a while and then start it! check it again!
It can be the mother board problem too. Try pressing the num lock key when ur pc is on n mointor has blackedout , if the num pad key light (green) light lights up( there r 3 small lights on the key boards)specially the 1st one then ur motherboard is ok. but if not give it for a repair.
Or
check the data cable of your monitor on some other working system if it is ok then you must check your graphics card using some other monitor.
let us know if you want somethin more else please accept the suggestion.
Thank You for contacting Fixya.com
    hi, need ur help to verify some of the items :
    1) when u mention "memory got some problem" are u referring to the RAM? mybe i will try to open it and wipe it with rubber..any better tips for the RAM?
    2) to narrow down the issue, i attached one monitor to the monitor port of the laptop, and and this new monitorcan display as per normal..i assume the motherboard is ok. rite?
    3) u mentiond to "check the data cable of ur monitor on some other working system". This advise is for desktop i guess? or u suggest me to open the laptop and find for the data cable inside my laptop?pls advise, as i am not sure how to locate the cable inside. Some hints maybe?
    Thanks much ~ -jenz-
Acer aspire 4736Z suddenly went black
Ram chips may be bad. Test it using an external monitor. If the problem does not occur on external monitor then you lcd screen may be going bad
Dec 24, 2013 | Acer Computers & Internet
I have an acer aspire 4310 laptop. but the monitor went white and when i got it checked, th technician suggested that i get an external monitor for my laptop to save on cost. when i finally did, my...
It sounds like your screen went out. I would just suggest getting a new laptop. whats the point of having one if you cant take it everywhere with you
Jun 23, 2011 | Acer Aspire One PC Notebook
A green vertical line suddenly appeared on the right side of my acer aspire 4736z. i've been using it for a year now, acer warranty expired. i'm extra careful with my laptop, didn't drop it nor bumped it....
It is definitely screen related. It is either the LCD cable, the inverter or the LCD screen itself.
The amount sounds about right from an authorized dealer although using a company like eBay could be cheaper.
Regards.
Jan 12, 2011 | Computers & Internet
There is a sudden change in the hue of my lcd- acer aspire 4740
It can be an issue with the display cable or the LCD panel itself.
U will have to check with a local tech.
May 31, 2010 | Acer Aspire 4720 Notebook
Acer Aspire 5610. LCD very dim all of a sudden.
That sounds just like an inverter problems. There is a slim chance the bulb could be a problem, but I would replace the inverter. It is not too hard to do, no soldering involved.
You have to remove the screw covers on the frame of the LCD frame, and then carefully pop off the frame. The inverter should be on the bottom center of the screen.
Be careful, there is a high voltage in that little baby. Just get the full numbers, and do a search on the internet and buy yourself a new inverter to replace the old one.
Apr 08, 2009 | Acer Aspire 5600 Series 5630-6951 Laptop
Acer Aspire 5050 screen is blank
Hi, if it works with an external monitor it's more likely an LCD problem. When you push the power button, noting comes up on the main LCD screen? not even the Acer logo etc.?
Did you set your video card to use an external monitor and disabled the primary LCD? If so, you need to go to display settings, advanced and go to ATI Display and make sure that the notebook monitor is on.
Apr 02, 2009 | Acer Aspire 5050 5430 Laptop
Acer aspire one will not work.
If you get a post screen with Acer written on it at startup, and the screen turns off when loading the system (Windows or Linux), then you need to reinstall the system using an external USB cd unit and the recovery disk that was provided with your Acer.
If instead the display has no screen at all , try connecting an external monitor to test the laptop.
If you get picture on external monitor, then the Aspire One has a faulty LCD ribbon cable or a faulty LCD display or inverter.
If you get no picture on external screen , then you have a faulty motherboard, possibly faulty video chipset on motherboard.
In any case check your Acer One warranty, all the faults listed are covered by Acer warranty for one year.
Contact Acer at the number listed on documentation to have the computer repaired.
Mar 13, 2009 | Acer Aspire One PC Notebook
Acer Aspire 5585 Laptop LCD Problem
Have you tried booting into "Enable VGA" mode via the "Windows Advance Option" screen? By press F8 before Windows XP loading screen comes up. In this mode the Video Card drivers are disabled. So if your screen appears normal and not white in this Mode then it is your video card drivers which are causing the issue.
Aug 19, 2008 | Acer Aspire 5610-4648 Notebook
Black Screen after sitting for awhile
Might be that the graphics card is overheating.
Nov 08, 2007 | Acer Aspire 5100 Notebook
Acer AX3810B3801A Aspire Mini PC Bundle with 20 LCD Monitor  PC Desktop Logo
24 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
