Question about Mitsubishi WS-65513 65" Rear Projection HDTV
When tv is turned on, for 1 to 2 minutes there are heavy wavey lines (like a mirage) then they go away. Any guesses?
  • 748 Answers
Hi
Could be convergence chip or associated capacitors going bad.
Posted on Jun 03, 2010
Component 1 has wavey lines all other conections
For component 1 on the tv I just changed from 1080i to 480i on the Verizon Fios set top box and that corrected the problem...
Aug 29, 2009 | Protron PLTV-26 26 in. HD-Ready LCD...
Wavy colored lines of captioning at all times, can't turn off
Try first unplugging the power cord for fifteen or twenty minutes , see if this can reset and fix the problem.
Sep 11, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Horizontal wavey lines in projection TV picture
what brand? could be a ground problem or bad crt
Aug 22, 2009 | Televison & Video
I have a toshiba big screen with three bulbs and the picture has wavey lines on the screen. Does this mean tubes are going out?
Most of these Toshiba sets have a "hyper board" that processes all the signal and a lot of them are going bad---lots of surface mounted filter caps on the board dry out and usually it begins that lines in the picture and after several minutes the problem slowly clears up and or goes away---as time goes on it takes longer and longer for it to go away----For most of these sets the only way to repair is remove the board and send it out for rebuild--rebuild of the board and labor may be more then the TV set is worth.
Jul 10, 2009 | Toshiba 42H83 42" Rear Projection...
When turning on tv it looks wavey for a few minutes then it goes away. Also it seems like its not wanting to turn on sometimes.
could be the DM board or convergance or possibly power supply capacitor is wearing out. Further testing of capacitors will have to be done to diagnose problems. You can use a capacitor tester or voltmeter to test capacitors. Also look for burn marks or swollen capacitors.
Jul 08, 2009 | RCA D52W19 52" Rear Projection Television
Wavey lines in tv
sometimes wavey lines can come from your cable or satelite connections because the wrong size cable was used or there is just a bad connection in the cable somewhere..
Nov 15, 2008 | Proton MM2701VT 27" TV
Wavey lines
Sounds like your set has dried caps in the Power Supply, take it to a decent tech, its not something you should try to do yourself as dangerous voltages can still be present evn if the set is unplugged.
Jul 25, 2008 | Panasonic PT-47WX49 47" Rear Projection...
Have Westinghouse 32"LCD TV. When its very hot and humid after being on for approximately 30 minutes black, heavy vertical wavey lines appear on the screen. Sometimers I can make the lines disappear...
I had the same problem these LCD TV's are designed poorly and have very little ventilation my warranty was up so i took it apart and installed cooling fan have no problems what so ever now.
Jul 17, 2008 | Televison & Video
Long warm up time
you have a bad capacitor in the deflection circuit.You will need some diagnosing and testing to find which one. An ESR meter will make short work of that but they are expensive meters.
Mar 22, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Mitsubishi WS-65513 65" Rear Projection HDTV Logo
75 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
