Question about Kenmore Refrigerators
Kenmore elite refrige | Water building up
I have a kenmore elite refrigerator model 106.74202402. I keep getting water building up below the two pull out bins at the bottom of my fridge. Why is this happening?
  • 93 Answers
SOURCE: How do I find the drain hose/plug on a 1996 kenmore refrig.
if you open the fridge door in the top you will see a small funnel typy that goes tru your back wakk this is where it normally cloged pull it out if no screws that hold it then clean it out or blw tru hose in the back of fridge if you can get access to it thanks from gille
Posted on Mar 15, 2009
  • 219 Answers
SOURCE: water in the bottom of the refrigerator
your drain hole is clogged take back panel off in back of frezzer u can get to it then take a steamer and clear ice from it
Posted on Mar 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: Kenmore Elite 106-74202402 Freezes food ice solid in the fridge
Hi
Most times this is a bad cold control, but there are other things to check for. Make sure the condenser fan is working and the coils are not covered with dust. A separated heat exchanger ( small capillary tubing soldered to the large suction line ) can separate from one another and make the fridge run too long. - tape tubing back together. A poor working evaporator fan motor could also make the fridge run too long and freeze - replace the fan motor. An inefficient compressor or refrigeration system could make the fridge run too long and freeze - have a service tech check this out. A misaligned control settings, make sure the air damper and cold control have not been bumped and are out of normal settings. Stuck open air diffusers or air dampers are becoming more and more common for allowing too much air to be blown into the fresh food section and freezing things. On all frost free fridge's the freezer temp air is blown into the fresh food section, if you have "easy" to freeze items ( eggs, veggies in water, etc ) in front of or under where the freezer temp air comes out, they could freeze - store them in a different spot. Doors not closing properly making the fridge run too long is something else to check for.
Please do rate the solution as FixYa and revert for further assistance.
Thanks
Rylee
Posted on Jun 03, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Kenmore elite - Water dripping from freezer to refrigerator
Your refrigerator has a defrost drain blockage behind the evaporator in your your freezer compartment. Some models like yours have leak in the turns as the water leaves the freezer. I recommend that you unplug and remove the cover to the evaporator and check the defrost condensate tray below the evaporator. A wet vacuum cleaner and poring a solution with clorox in the drain will help you clean locate the leak and where the blockage may be downline.. I do have the manual on yours and can help you solve this. Some times this is a factory defect and I can help you solve the freezing drain problem. Let me know, Sea Breeze
http://fixitnow.com/wp/2009/05/26/the-permanent-cure-for-repeatedly-freezing-condensate-drains-in-whirlpool-roper-kitchenaid-top-mount-refrigerators/
http://servicepartstec.blogspot.com/
Posted on Jul 01, 2009
EllaWatson25
  • 725 Answers
SOURCE: Kenmore elite fridge. Bottom freezer ice builds
You have a bad defrost system on this unit, that's why you're freezing up. Call us with the model number and we'll get the correct part out to you right away. We hope to hear back from you soon.
Posted on Oct 10, 2009
I have a Kenmore Elite refrigerator with the freezer on the bottom. The water comes out of the water valve slowly when I want to fill up a glass. Why? It's the slowest flow of water that I've...
Restriction in the line. Check the water line to make sure it's not pinched or kinked.
Often times too the water line from the refrigerator is connected to the cold water line of the house with a self tapping valve. Turn the valve off and back on a couple times to clear any restrictions.
If everything is ok with the water line to the refrigerator then you will need to replace the water inlet valve behind the refrigerator.
Aug 03, 2011 | Kenmore Elite 78722 78729 Bottom Freezer...
Kenmore elite model 52603100 freezer defrost water freezes in drain tube/plan then over flows to bottom of unit. freezes then water eventally runs on kitchen floor
You need to clean out the drain tube it's clogged that's why the water is freezing.Try using hot water and maybe something like pipe cleaners to get what's in there out.Hope this helps. On some models it may be easier to pull out the refrig from the wall and get to the drain from the back.
Jun 15, 2011 | Kenmore Refrigerators
My kenmore elite refrig keeps leaking water from what appears to be condensation. It gets so bad that the ice maker door freezes shut and water actually drips on the floor. The freezer is set to 0 while...
The high level of condensation is due to constant opening of the fridge when the frost develops. It is required to defrost off the condensation and if this has an auto mode timer for defrost , then it is possible that it is not working.
The water must drain out to the drain tank but since it is formed out of the freezer the water flows out of the collection tray.
Sep 27, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
No water coming from water dispenser.
It is possible the water control valve for that dispenser has failed and will not open. This happens a lot for those and the ice maker valves. All you need is the model number for your refrigerator and that will look like this for Kenmore. 213.564897 for example. and I will help you find the correct part number. Sea Breeze
Nov 24, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jul 01, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Kenmore Elite Side by Side refrigerator not cooling enough
it could be either gas problem or may be compressor is not working
May 14, 2009 | GE GSS20IEP Side by Side Refrigerator
Water leaking into freezer
It may be the defrost thermostat. This thermostat turns on a heater in the freezer a couple of times a day and melts the ice in the freezer which should go into a tube that leads to a pan underneath the refrigerator, where it sits and evaporates from the heat of the compressor. It could also be the timer which tells the refrigeator to turn off a couple of times a day and tells the defrost thermostat to turn on.
Mar 21, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Elite Trio model#596.73503201
I believe you may be on the right track. Usually the coil for the water is behind the crispers. You can try taking the crispers out and use a hairdryer on air/no heat to speed up the coil thawing out.
Feb 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Refrigerators Logo
93 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
