Question about Ridgid Reconditioned 10" Jobsite Portable Table Saw with Stand
Motor will not start on my Ridgid table saw
I hit the switch and it would not start, but it made a "click". I thought there might be a "reset button" but I could not find one. I by-passed the switch and it made no difference. Any ideas?
  • 10,319 Answers
Check the brushes and the commutator for wear and buildup between the insulated areas of the commutator..It should be clean and not full ofcopper residue.That will make the motor click only upon triggering the starter switch
Posted on Jun 03, 2010
Testimonial: "That sounds like good advice. I'll check it out. Thanks"
Why would ridgid ts2400-1 10" table saw motor race
Electrical motors do not 'race' unless there is an electrical problem... usually with the motor. One other possibility is to check the tightness of the saw blade itself. If a bit loose, it may be be slipping intermittently, causing the illusion that the motor is varying in speed. Lastly, but unlikely is that the start capacitor for the motor is defective.
Feb 03, 2018 | Ridgid Saws
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
I need a motor replacement for this saw TH100085
Motor TH100085 for Ridgid Power Tool eReplacement Parts
http://www.smallenginesprodealer.com/ryobi-ridgid/oem/active/ryobi-ridgid-th100085-motor-part-number-th100085-ryobi-ridgid-original-oem/
40.00$
Nov 09, 2015 | Saws
Can I replace Ridgid 4510 table saw with a simple light switch?
No, the saw can reach peak amp up to 30 amps, too much for a light switch controlling a 15amp circuit. Is something wrong with your switch, I might have another idea. waynehill@charter.net
Aug 09, 2014 | Ridgid Saws
Where is the fuse located on my Ridgid miter saw?
Most AC voltage saws do not have a fuse. They usually have a built-in breaker or a resettable thermal overload. Look for a pushbutton near the motor.
Dec 05, 2013 | Ridgid 10inch Compound Miter Saw With...
I am purchasing a generator to rum Ridgid 4510 table saw off grid. What is the start-up wattage?
3000 watts should work ok. Take the motor amps (12) times the voltage (120) to get watts - then double for the start current.
Feb 08, 2013 | Saws
Ridgid TS3660 10 INCH TABLE SAW TH100085 MOTOR. I need replacement part for thermal cutoff switch. I broke the red button off the switch and now the motor will not start. I cannot find a replacement...
I have been fixing table saws, compressors and other tools with similar motors for several years and I have never been able to find anyone who sells just the thermal switch on these motors. I usually use one from another motor that's burned out if I need one. You'll have to find a repair center that has motors they could take one of these switches out of and sell/give to you. Otherwise, it's a new motor to get one.
Jan 30, 2013 | Ridgid TH100085 Motor
My very old Craftsman 10" Table Saw does not power on. While rip cutting some plywood, I errored and caused the blade to bind. Before I was able to power off the saw, the motor stopped. I thought I had...
Go to searspartsdirect.com and put in your model number. Look at the motor and wiring section. Look at item 16. The motor overload protector. (probably your reset button) WIth saw unplugged, unwire one sid of this switch and test with an ohm meter. You should read through the switch. If it is open then that's why the saw doesn't work. Many of this type of oveload requires quite a push to reset as you're flexing a klixon disc back to make contact. If is open and you can't reset, it's available there although a bit high priced.
Aug 13, 2010 | Craftsman 10" Table Saw
Craftsman 10' table saw model # 137.248830 will not start
Reset button on the motor, push till it clicks. How about the breaker? What kind of switch is it? Is it plugged in? Check this stuff out. Hope it helps.
May 09, 2010 | Craftsman Saws
Ridgid Reconditioned 10" Jobsite Portable Table Saw with Stand Logo
1,686 people viewed this question
Top Ridgid Saws Experts
John Trevino
Jim Thurston
Are you a Ridgid Saw Expert? Answer questions, earn points and help others
