Question about kawasaki Full Suspension Mountain Bike Men
I just bought a bike an 83 Kawasaki 750 no battery but does have a kick start when kicking it doesn't turn over where should i start trouble shooting?
If you are holding the clutch in when kik starting the motor will not turn over. try not holding the clutch in it will turn over for sure, but does not mean it will start.
Posted on Jul 13, 2010
Check spark plugs
Posted on Jun 19, 2010
  • 10,319 Answers
This bike does needs a battery to fire the coils for spark to the plugs to start it up
Posted on Jun 03, 2010
Kawasaki wiring
check your kick stand switch
Jul 11, 2014 | 1993 kawasaki VN 750 Vulcan
Vulcan 750 1992 wont start after when i just turned it off.
Forget the other answers bud...here is a link to kawasaki vulcan riders club where some real bikers n experts to guide ya through buty I also added few links to free repair manual downloads.....got tons of links for other bike stuff if ya need...
http://www.vulcanrider.se/en/
http://www2.vulcanrider.se/DL/VN750ManualandParts.pdf
http://www.tocmanufacturing.com/Files%20for%20Download/VN750%20Manual%20and%20Parts.pdf
http://www.vn750.com/
the one below has loads of manuals for everything ya can think of inc bikes=
http://www.manualslib.com/k/kawasaki+z750.html
finally lots of vn parts are cross compatible and this site does a nifty bit of kit that finds part numbers and then sees if its used on other models...it isnt free but might as well be...saved me a packet at breakers=
http://www.zedder.com/
1992 Kawasaki ZX750 Ninja ZX 7R Parts Accessories
I do have a thick leather waistcoat full of vulcan riders patches, badges, rally badges etc with extenders on but not enough to make it fit again if ya want it...m
Nov 13, 2013 | 2003 kawasaki VN 750 Vulcan
Fuse box kawasaki junction zzr600
bad earth connection on engine to frame
Nov 11, 2013 | 2008 Zongshen Storm V250
Kawasaki brute force 750 cranks over then locks up it won't turn over by pulling the rope
sound to me you got faulty security switch check them 1st, specially the kick stand, most bike locks up if you try to place it in gears while the kick stand is still on. hope it helps
Dec 24, 2012 | Motorcycles
2010 Z1000 in Australia. bike was 100% fine less than a week ago, got it out last night and it wouldn't start. The dash lights up, but doesn't show neutral light when it's in neutral. Also the...
get the dealer to sort this out as taking it apart yourself could invalidate the warranty. its classed as third party interferance, and as you are not a kawasaki mechanic they could wash their hands of the warranty.
Sep 08, 2011 | 2010 kawasaki Z1000
Hello my 2006 kawasaki zzr 600 wont start. I havent started this bike since before winter and am now experiencing problems. the bike has been tarped but in the cold. I found out yesterday the battery was...
The most common issue of bikes not starting after they have sat for a while is the carbs have gotten gummed up from the gas sitting in them. Gas breaks down and gums up the fuel and air passageways in the carbs after it sits for awhile. You need to remove and overhaul the carbs.
This is the single most common repair we see as motorcycle techs.
To be certain it is fuel related, it doesn"t hurt to spray some carb spray into the engine and see if it fires up briefly. If it does then you know its fuel related.
Nov 30, 2010 | 2006 kawasaki ZZR 600
My 2002 kawasaki ninja 250 is having trouble starting. (electric start) At first it was just giving me this clicking sound kinda like when your car wont turn over and start. So I replaced the battery for...
The oil light is on because the engine isn't running to build any oil pressure. Sounds like the new battery may need to be charged fully. After the battery is fully charged, and the 'clicking' noise is back (or not) check the battery connections for corrosion--especially at the positive terminal. If ok, you should get one solid click when trying to start. If ok, but still not starting, jump the two heavy terminals of the solenoid (click source) with a heavy wire which should bump the starter motor. If nothing, then the starter motor needs service--usually the brushes inside fail to make contact with the armature due to brush wear, or weak springs. Most dealers will likely only sell you a new starter--no internal parts. Hope this helps!
Oct 04, 2010 | kawasaki Ninja 250R Motorcycles
Bike wont kick start or idle , it will coast
first drain the carby, then set your air mixture screw 2 turns out, from the fully turned in position. The starting proceedure is as follows, when the engine is COLD, turn on fuel, pull on the choke fully, and kick the engine over. DO NOT use any throttle, when the engine is cold, and the choke is on. Remember Choke on, NO throttle.
When warm, no choke, and a little throttle when kicking.
May 12, 2010 | 2003 kawasaki KX 125
Trouble starting RM 250
i got a 2000 rm 250 and it used to be a cow to kick over i used to spend at least 20 min kicking to start it until i rebuilt the top end with a new piston and rings now it starts on the fourth or fifth kick if that doesnt help you need a new cpu good luck!!!!
Apr 29, 2009 | 2004 Suzuki RM 125
kawasaki Full Suspension Mountain Bike Men Logo
116 people viewed this question
Top kawasaki Sport & Outdoor - Others Experts
Wayne McNeil
Phillip Edwin
Level 1 Expert
Are you a kawasaki Sport and Outdoor - Other Expert? Answer questions, earn points and help others
