Question about Kenmore HE2 Plus Front Load Washer
Hi I've a front loading model 970-C42074-00 that is ruining my cloths, leaving grease marks on everything. Could the cause of this be bad bearings in the drum? I have tried increasing water temperature, detergent amounts and smaller loads.
  • 56 Answers
Woo stop adding more detergant . you get a build up over time you should only be using about 2 tblps no mor half that if you have a softner . ok chexk the door seal behind the gasket at the tub is there a gray slime on the plastic tub could be brown
Posted on Jun 03, 2010
Tip
Greasy marks on clothes in top loading washing machines can also be caused by...
90% of greasy marks on cloths is due to scum build in the outer bowl of your machine...top loaders being the most vulnerable. prevention is better than cure. At least one hot wash a week on high level. If your machine is an early model one or two with a good bleach subject to manufacturers instruction...bleach is very cost effective and works well.
on Apr 09, 2008 | Bosch WFMC 3200 Front Load Washer
Sometimes there will be grease streaks on the clothes after wash.
the main bearing and seals on the drum side are faulty. this should be under warrenty
Dec 29, 2009 | LG WM-2077C Front Load Washer
My Kenmore elite front load washer leaves tan stains/marks on many of our clothing. Is this mildew/ fungus problem. I wash with hot water and vinegar approx. 1 a month.
this sounds like the bearings are wearing out,this can cause the grease between the bearrings to come into the washer,to check the bearrings open the door and you will see the silver drum inside place your hand at the top of this and gently lift it up if you feel a knocking noise then thats a sign that the bearrings have gone,hope this helps you.rgrds,paul
Jul 07, 2009 | Kenmore Elite 45986 Front Load Washer
WHERE IS THE FILTER
this sounds more like grease marks rather than sludgy marks,i bet you the bearrings have worn out,check this out by opening the door and the silver drum inside will have a knocking noise as you lift it up and down,when bearrings have worn out this causes a sludgy diposite,rgds,paul
Jul 07, 2009 | Hotpoint WMA64 Front Load Washer
Machine leaves greasy looking streaks on clothes
tub bearing water seal gone ,needs new bearings and seals.
Jun 11, 2009 | Frigidaire GLTF2940ES Front Load Washer
Brown marks on white clothes
Hi yoginiji,
The black mould might have something to do with the marks - I think it builds up if you only ever use low-temperature programmes. I believe that running the machine on a hot wash cycle - perhaps with some proprietory cleaner (but with no clothes in it) might help to get rid of it. I would suggest first removing as much as possible by hand.
Another, more serious possibility is that the drum bearing seals are leaking grease into the wash tub. If nothing is done the bearings will fail and result in a nasty repair bill. If your machine is under warranty, now is the time to contact the repair people.
Does this help? If not please give any more details you have and I'll try to think of something else :-)
Jun 29, 2008 | GE Energy Star WCVH6260F Front Load Washer
Stained clothes
there no grease in ft loading washer possible cause fabric softner
Feb 03, 2008 | Kenmore 44102 Front Load Washer
Fridgidaire Front Load Washer
This is usually an indication that the rear tub bearing is starting to go bad. The bearing is located in the rear shell of the wash tub and cannot be replaced. In order to repair, you would have to replace the entire rear shell because the bearing is actually molded into the plastic. This is common with front loader washing machines. Another possibility could be items getting caught in the rubber door boot and leaving rubber marks. However, normally this will be associated with a leak somewhere. Inspect the entire door boot and clean in behind the rubber. Inspect for any rips, tears, or places where clothes can get caught. I have experienced clothing getting snagged and actually pulling the door boot off. If the marks continue to show up on your clothes (they may even turn a brownish color) I would look into an estimate on how much it would cost to have the tub bearing replaced. It is not an easy repair, and it is not cheap. The cost usually runs around $500. I hope this helps.
Aug 08, 2007 | Frigidaire ATF6000ES Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
256 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
