Question about Goodman Heating & Cooling
How do I decipher air handler model # AWUF240516BA, serial #1002617593? Condensor model # GSZ130241AB, serial #1003505321? Sticker on equipment says Goodman. I am curious as to year manufactured, size, seer rating, etc. Thank you!
  • 116 Answers
SOURCE: Looking for rating
3 ton unit 12000 btu per ton 42 3.5 ect not sure on seer rating the year it was built is part of the serial number if you can see the compressor and get those numbers the manufacture should have a chart on the rating if bristol then 12 or less if copeland 12 or more most 12 seer had 10 yr comp warrenty hope this helps
Posted on Jun 04, 2009
james3751
  • 614 Answers
SOURCE: what is the SEER rating on Goodman Air Handler model a32-05c?
Slightly more than 10 seer . Depending on the outside unit. A30 are 10 seer. Rusty
Posted on Jun 07, 2009
  • 21 Answers
SOURCE: what is the SEER rating on the Goodman CLJ36-1C.
12 seers, considered high efficiency before 2006
Posted on Aug 13, 2009
Testimonial: "Thanks Dude- could not find the info anywhere."
SOURCE: I need to know the seer number for an air handler. I'd
On the air handler take the top panel off, look to the left on the inside, this will give you general information on the unit on a stampede plate. This will
give you the date of manufactuer as well.
On the outdoor unit, there is a stamped plate on the
condensing unit. Should have year of manufactuer, it
should also say how many pounds of freon should be
in it. The Model number is what you need to know
to find out how big it is.
024=24,000 BTU= 2ton unit
030=30,000 BTU=2 1/2ton
036=36,000 BTU=3ton
040=40,000BTU= 3 1/2ton
and so on.
My guess is that it is an older unit and since I have
been installling units since 1995 I have only known
any older units to be at least a 10 SEER and no more.
Posted on Feb 17, 2010
atocrxr
  • 135 Answers
SOURCE: I cannot find the seer rating or tonage of a
My books do not go back far enough to get you the Seer rating, it is a 5 ton unit and as the serial number shows it to be a 1999 model, it is probably a 10 SEER unit, maybe a 12 seer, but not likely, but I can tell you that it was manufactured on the 8th week of 1999.
I hope that I have helped, have a great day.
Sincerely,
Paul Gibson
Posted on Mar 31, 2010
What are the tons of a RUUD AC HANDLER MODEL UBHA-17J11 SO SFFA SERIAL NUMBER MOO500 03485 and what type of CONDENSER & TONS CAN IT HANDUE WITHOUT PROBLEMS?
You can find the tonnage in the model number which increases by increments of 12, so if the model number is 24 =2 tons. Model number on your a/handler is 17. Thats a ton and a half. Really should match the evap and condenser for the best efficiency. ...
Sep 24, 2015 | Ruud Heating & Cooling
Need wire diagram from T-stat to Air-Handler then cond unit
green goes to g on air-handler,white goes to w on air-handler yellow goes to outside condensor, red from air-handler goes to rh-rc on thermostat, whire off c on air-handler goes to outside condensor.
May 13, 2014 | Ruud Heating & Cooling
York Air Handler
you will need to look at front tag were you got the model number..it will tell you if it is a 1/3 hp or bigger,,also 48 y frame..230 v an rpm of motor like example 1100 rpm...hpoe this helps...if need more help ,just one call away...its free..michael doctor airr appl.repair ....843-384-8474...
Mar 27, 2010 | Heating & Cooling
No ac
please check if you have a drain line float switch, if your drain line plugged up it will tripped it, normaly it is located on main or secondary drain line on the front of air handler...
Aug 23, 2009 | Heating & Cooling
Condensor fan wont come on
check you breaker for a/c seperate from air handler and check the contactor could have coil blown for low voltage not calling in the compressor
May 16, 2009 | Heating & Cooling
I need to know the type or size(tons) air handler
3 and a half ton S3642C6AA
42 is the unit size then you divide that number by 12
May 05, 2009 | Heating & Cooling
Heating & Cooling Logo
550 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
