Question about Bose Wave Radio
Replace fuse Bose Wave Radio
I need to replace the fuse in my Bose Wave Radio. In order to do this, I must remove the PC board so that I can solder in a new fuse. Does anyone know how I disassemble the radio to get to the PC board? I can remove the top cover, but I cant see how to expose the PC board.
  • jon68 Apr 20, 2008
    I have an Bose Wave radio, AWR1-1W that won't power up, makes a loud pop when unplugged.
    I know the fix for the newer version of this radio is the 5vdc power supply transistor.
    Do you have any suggestions. If you can offer some info I'd appreciate it. Thanks
For the AWR1-1W turn it over and there are 4 screws that you must remove. When your looking at the circuit board the fuse is just below the power supply and back of radio. If the radio makes a ‘POP’ sound when you unplug it may not be the fuse as power is getting past the fuse. I have the same trouble with mine. I called BOSE Tech and he said if it makes that ‘POP’ sound after unplugging it is not fuse or power supply. They will not even allow me to send it in for repairs as the radio is over 15 years old and considered unserviceable.
Maybe someone else can give us a quick fix.
Posted on May 06, 2008
I have same problem. I don't know the fix but I certainly would not take Bose service tech at his word. Bose simply has goal to sell new units.
Posted on Jul 12, 2008
Where is the fuse for bose wave radio
Upon opening the Bose Wave radio.. 4 screws only from the bottom. The fuse is located at the top side of the PCB. It is a small fuse. Kindly inform me if you need a picture. I am repairing one now
Aug 07, 2009 | Bose Wave Radio
Grand kid's spilled pop onunit.bad r222 +c209 mod #awrc-1p bose.
Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. There is, however, a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Apr 08, 2009 | Bose Wave Radio
My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Mar 26, 2009 | Bose Wave Radio
Bose wave radio signal fades in and out, cd stops and starts
i would check the power supply for bad solder joints or cracks in the traces on the printed circuit board, possible around the heaviest components (usually a transformer) or a loose connector.You can use the eraser end of a pencil to push on components to see if any of them cause the problem to manifest, and if so, turn off the power and reheat the solder connections to that component.
Jan 07, 2009 | Bose Wave Music System CD Shelf System
Bose radio
There's a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Dec 18, 2008 | Bose Wave Radio
BOSE wAVE rADIO mODEL awpc1g
Bill B.
Oct 10, 2008 | Bose Wave Radio
Power
Sep 16, 2008 | Bose Wave Radio
In line fuse
I suspect that the fuse is 0.75 A, and I believe that it is soldered in place. Can you see that it is blown?
Mar 27, 2008 | Bose Wave Radio
Bose Wave Radio/CD Model AWRC1P
Yes There is a pigtail fuse in unit. It solders to main board. In order to replace you have to pull main p.c.b to get access to bottom of board.
Jan 18, 2008 | Bose Wave Radio
Boes wave radio
All Wave Radios have a Pigtail fuse on main board. May just be Fuse. I have seen alot of them that when dead have water damage as root cause. These radios are very reliable and water damage failure seems to be the most common. Bose has a flat rate repair service on these radios http://www.bose.com/controller?event=VIEW_STATIC_PAGE_EVENT&url=/contact/index.jsp&ck=0
kstahl65@att.net
Jan 14, 2008 | Bose Wave Radio
Bose Wave Radio Logo
2,269 people viewed this question
Top Bose Audio Players & Recorders Experts
jjcicala
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
