Question about Toro Lawn Mower With Toro Power Tools
My 3 year old 22 inch walk behind mower will not start, I replaced the spark plug, there is no spark when I pull the hand start
  • 404 Answers
Replace the flywheel key by removing the rewind housing, the flywheel nut and then remove the flywheel by using a small engine universal puller (cheap) and install a new key.
Posted on Jun 04, 2010
What is spark plug gap on toro lawnmower model#20332?
Toro has your manuals here depending on year of purchase. If they don't mention the gap, I would use to the contact page to ask.
https://www.toro.com/en/homeowner/walk-behind-mowers/22-personal-pace-20332
22 56 cm Personal Pace 50 State 20332
Apr 14, 2016 | Toro Power Lawn Mower
How to remove spark plug
I have attached an article about how to change the spark plug on a walk behind mower.
The directions should be roughly the same despite the difference in brand and model.
I hope this helps!
How to Change the Spark Plug on Toro Recycler Self Propelled Mower
May 05, 2014 | Mtd 22" Yard Machine Push Mower
Toro 6.5 HP Self propelled walk behind 22
take the top cover off the engine. you will see the coil on top there. unplug the wire that plugs into it. put the cover back on and try to start it. if it starts it is not the coil. try a different spark plug first. pull the cord with the plug out to get all the gas out of the engine.
Mar 20, 2017 | Garden
Lawn Mower runs rough & dies has black sooty spark plugs
A good place to start would be to remove air cleaner assembly and give it a good wash and service and take a close look at choke assembly/lever to be sure it isn't sticking in on position, while trying to run it with air filter off..
Nov 25, 2011 | Mtd 22" Yard Machine Push Mower
MTD Yard Machines 22'' mower, pull cord won't extend
From what you describe it sounds like the line may be tangled, remove the rewind housing in order to inspect the line up close.
Jun 03, 2010 | Mtd 22" Yard Machine Push Mower
My MTD walk behind lawn mower won't start. There's gas and spark (I think---when I looked at spark plug, it was pretty dirty and had a lot of dark greasy residue on it so I cleaned it off, but it still...
Make sure you have fresh clean fuel in the mower. Has the mower been setting for a while? Make sure your air cleaner is not plugged. Try starting with fresh fuel and the air cleaner off. Let me know if the cord tries to pull back or you have hit anything with the mower blade recently.
Nov 28, 2009 | Mtd 22" Yard Machine Push Mower
I have an old Craftsman 6.75 hp walk behind
Not sure where to look for the model number. But here's a few things to check.
1. If the gas is old (from last year), drain it out of the tank, carb and lines and replace with fresh. Gas can go bad and won't ignite properly after it has been around too long.
2. Replace the spark plug.... sometimes they look good and aren't.
3. Clean the Air filter. Take the filter element out of the housing and give it a good cleaning with compressed air. If it's plugged up with debris and dust, your trimmer won't run.
4. Make sure the oil level is correct. Many of the current motors won't run if the oil is low.
hope this help ya
k
Sep 15, 2009 | Craftsman Garden
My walk behind mower wont start..has no spark with new plug or old one could it be a rusty magneto
Rust on the magneto has no bearing on the output of a spark. The magneto or the points if it has them could be the problem. If the unit has points they may be under the flywheel. If so equiped, that would be the logical place to start. If no points, I would replace the magneto. When you place the new one on, place a piece of paper between the flywheel and the magneto. When you tighten the magneto, pull out the paper and turn the flywheel by hand. If the magneto turns without touching, put everything together and try it out. Good luck...Lee
Sep 09, 2009 | Garden
Toro self propelled lawn electric start lawn mower does nothing
I pull the rope and it seems like it wants to start.It will not start with rope ? are you sure your brake control cable is adjusted right if not it could cause it not to start,you said after you pulled rope and trys to start you used it twice when ?
May 15, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
257 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
